Ferrety66 Samba Member
Joined: July 01, 2012 Posts: 31 Location: Los Angeles, CA
Posted: Mon Apr 20, 2020 8:14 pm Post subject: Re: 1200 40HP flywheel questions |
Well, it does not get more clear than that. Thank you very much for you help. Yes, I noticed the groove. Actually is not one. There are three around the crank aligned one after the other separated by about 10mm from each other. They are not very deep and I have no idea how they were formed. They do not seem to affect anything negatively but, I just wonder how they might have formed.
Armed with all this information, I am driving to Santa Ana tomorrow. This cool guy at DPR machinery told he has the 6v / 180mm / o-ringed flywheel I need.
Thank you again.
_________________ "Mit Geduld und Spucke fängt man eine Mucke."
sjbartnik Samba Member
Joined: September 01, 2011 Posts: 5995 Location: Brooklyn
Posted: Mon Apr 20, 2020 8:20 pm Post subject: Re: 1200 40HP flywheel questions |
Jose at DPR is awesome. Say hi for me from Brooklyn!
Take your pressure plate with you and have him balance the two together as an assembly while you're there. _________________ 1965 Volkswagen 1500 Variant S
2000 Kawasaki W650 |
Posted: Mon Apr 20, 2020 8:43 pm Post subject: Re: 1200 40HP flywheel questions |
Hey sjbartnik, yes that is his name I remember now that you mentioned it. He seemed cool. Thank you for the advice I will take the pressure plate with me. _________________ "Mit Geduld und Spucke fängt man eine Mucke." |
maggiolino91 Samba Member
Posted: Wed Jul 08, 2020 12:10 am Post subject: Re: 1200 40HP flywheel questions |
Hi everyone! I have a question. Does the 6v early flywheel (paper gasket) fit in a 12v engine ( D series, 1972)? _________________ 1956 strato silver L227 ragtop
1961 beryl green L478 ragtop
1973 superbeetle pastelweiss L90D |
mukluk Samba Member
Joined: October 18, 2012 Posts: 7023 Location: Clyde, TX
Posted: Wed Jul 08, 2020 11:41 am Post subject: Re: 1200 40HP flywheel questions |
maggiolino91 wrote: |
Hi everyone! I have a question. Does the 6v early flywheel (paper gasket) fit in a 12v engine ( D series, 1972)? |
Yes. The late crankshaft will work with both types of flywheel, while early crankshafts will only work with the early flywheels. The seal used is determined by the type of flywheel fitted -- you must use a paper or metal gasket with the early flywheel and an o-ring with a late flywheel. _________________ 1960 Ragtop w/Semaphores "Inga" |
Posted: Fri Jul 10, 2020 10:34 am Post subject: Re: 1200 40HP flywheel questions |
mukluk wrote: |
Yes. The late crankshaft will work with both types of flywheel, while early crankshafts will only work with the early flywheels. The seal used is determined by the type of flywheel fitted -- you must use a paper or metal gasket with the early flywheel and an o-ring with a late flywheel. |
Thank you! _________________ 1956 strato silver L227 ragtop
