Bobnotch Samba Member
Posted: Wed Jun 17, 2020 10:06 am Post subject: Re: Mid engine Notch Speedster getting more updates... |
vwfye wrote: |
It's alive! Now... tuning the new carbs, running the valves and trying to get the tach and shift light to share a signal. |
Cool. You might just make it to the track this year then. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
vwfye Samba Member
Posted: Tue Jun 30, 2020 10:20 pm Post subject: Re: Mid engine Notch Speedster getting more updates... |
So, a bunch of the changes I made (non-engine/drivetrain) do not work as laid out. So, have to do a bunch of moving and resorting. No $, just time. _________________ 64 No'back Speedster "Pearl"
1980s Sand Dragster "The Plunger"
LME "Little Giant Killer 3" |
vwfye Samba Member
Posted: Sat Aug 01, 2020 4:20 pm Post subject: Re: Mid engine Notch Speedster getting more updates... |
Man, this stuff is humbling. I have been dealing with a dead cylinder. Weeks of frustration... I checked for intake leaks when this appeared with carb cleaner and couldn't find any sign at the dead whole. So today, I rebuilt a different carb that I had, put it in place, tighten everything down and fired off the engine, only to have the exact same problem. Augh!!!
So I decided to use a propane torch to see if I had missed something, and as soon as it got near cylinder number 2, at the base of the intake manifold, the cylinder came to life. After 3 carb rebuilds on the 1st carb, rebuilding an entirely different carb and putting it in, it comes down to what I and others had thought it was in the 1st place. A freaking intake air leak.
I am not sure why the carb cleaner didn't find it, but I am using propane for now on! _________________ 64 No'back Speedster "Pearl"
Tram Samba Socialist
Joined: May 02, 2003 Posts: 22728 Location: Still Feelin' the Bern- Once you've felt it you can't un- feel it.
Posted: Sat Aug 01, 2020 11:10 pm Post subject: Re: Mid engine Notch Speedster getting more updates... |
vwfye wrote: |
I am not sure why the carb cleaner didn't find it, but I am using propane for now on! |
Carb cleaner just doesn't work on a manifold/ head gasket. WD-40 or silicone spray will. Best way though is to read the plugs. If one is normal and the other white on the same side it can't be the carb. _________________ Немає виправдання для війни! Я з Україною.
Bryan67 wrote: |
vwfye Samba Member
Posted: Thu Aug 06, 2020 5:55 pm Post subject: Re: Mid engine Notch Speedster getting more updates... |
After tearing 2 gaskets trying to open them for the heads, the 3rd is on and all 4 cylinders live! I can race Saturday!
Now, to change the slave cylinder and bleed it so I have a clutch, put the seats back in, find the old engine cover, fix the access cover so it stays closed, put the tonneau cover studs back in so it is rain resistant, torque the lugs, adjust the fuel pressure, tighten the linkage, add the breather, and... whew, that's still a list!
Oh, and this time, the STF engine has great oil pressure! _________________ 64 No'back Speedster "Pearl"
Posted: Fri Aug 07, 2020 7:05 am Post subject: Re: Mid engine Notch Speedster getting more updates... |
vwfye wrote: |
Oh, and this time, the STF engine has great oil pressure! |
Sounds like you need to get off the Samba and get back to work. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
vwfye Samba Member
Posted: Fri Aug 07, 2020 9:13 pm Post subject: Re: Mid engine Notch Speedster getting more updates... |
The initial reward for the thrash.
A clean, no broken parts, pass is all I want. _________________ 64 No'back Speedster "Pearl"
vwfye Samba Member
Posted: Sat Aug 08, 2020 9:41 pm Post subject: Re: Mid engine Notch Speedster getting more updates... |
Lots of tire spin... I was going to run high tire pressure to protect the transmission, but after sitting in the lanes for an hour, they tire pressure climbed way too high.
Second run, dropped the pressure down to where I wanted the 1st pass, but still too much and spun bad again.
Posted: Sun Aug 09, 2020 8:59 am Post subject: Re: Mid engine Notch Speedster getting more updates... |
vwfye wrote: |
Well, even a bad day at the track is a good day. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
vwfye Samba Member
Posted: Sun Aug 09, 2020 9:03 am Post subject: Re: Mid engine Notch Speedster getting more updates... |
Bobnotch wrote: |
Well, even a bad day at the track is a good day. |
Yes, yes it is! _________________ 64 No'back Speedster "Pearl"
vwfye Samba Member
Posted: Sun Aug 09, 2020 9:36 am Post subject: Re: Mid engine Notch Speedster getting more updates... |
My second pass was funny. I dropped the tire pressure and launched at the same rpm. I missed 2nd gear, found 4th and just puttered through. 13.49 @ 43 mph. Here is the funny. Last year, the bone stock squareback, with perfect shifts ran a best of 14.22 @ 42 mph. So, I was still faster than last year! _________________ 64 No'back Speedster "Pearl"
Posted: Mon Aug 10, 2020 1:10 pm Post subject: Re: Mid engine Notch Speedster getting more updates... |
vwfye wrote: |
My second pass was funny. I dropped the tire pressure and launched at the same rpm. I missed 2nd gear, found 4th and just puttered through. 13.49 @ 43 mph. Here is the funny. Last year, the bone stock squareback, with perfect shifts ran a best of 14.22 @ 42 mph. So, I was still faster than last year! |
Yeah, that's a funny alright. Makes you wonder how much lighter this car is compared to the Squareback. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
vwfye Samba Member
Posted: Mon Aug 10, 2020 4:23 pm Post subject: Re: Mid engine Notch Speedster getting more updates... |
I know. 75lbs. The ladder system and roll bar seem to have made up for the roof and glass. _________________ 64 No'back Speedster "Pearl"
vwfye Samba Member
Posted: Mon Aug 10, 2020 6:44 pm Post subject: Re: Mid engine Notch Speedster getting more updates... |
I have decided, after missing a gear again with the cable shifter, I am done with trying to race his car.
The midengine is great for much, but for quick fixes at the track and servicing it between events just doesn't work.
Going to make it a cruiser again... _________________ 64 No'back Speedster "Pearl"
Posted: Tue Aug 11, 2020 1:23 pm Post subject: Re: Mid engine Notch Speedster getting more updates... |
That might be a good plan. But then it'd been over a year (maybe 2) since you last drove it, which means it sounds like you're out of practice with it. Rob has that issue when he goes back and forth between his Civics, as 1 is a 5 speed car, and the other is a 6 speed manual car. _________________ Bob 65 Notch S with Sunroof
Tram wrote: |
Tram wrote: |
vwfye Samba Member
Posted: Tue Aug 11, 2020 1:26 pm Post subject: Re: Mid engine Notch Speedster getting more updates... |
The shifter is so vague, that even when driving it without speed shifting, it can be a pain in the butt. _________________ 64 No'back Speedster "Pearl"
vwfye Samba Member
Posted: Wed Sep 16, 2020 7:51 pm Post subject: Re: Mid engine Notch Speedster getting more updates... |
This Saturday/Sunday (weather) is it. If the rain comes, it is still it. The last race for the car. After that, back to a street only car. I'm sad, and happy. I'm looking forward to the next version of the car though... _________________ 64 No'back Speedster "Pearl"
vwfye Samba Member
Posted: Sat Sep 19, 2020 4:06 pm Post subject: Re: Mid engine Notch Speedster getting more updates... |
Loading in a couple hours, after the showers pass... _________________ 64 No'back Speedster "Pearl"
vwfye Samba Member
Posted: Sat Sep 19, 2020 8:01 pm Post subject: Re: Mid engine Notch Speedster getting more updates... |
Loaded for the last hurrah...
