Off road modifications for your bus FAQ
Page: 1, 2, 3 ... 71, 72, 73  Next
bikedk88
bikedk88 is offline
PostPosted: Fri Dec 21, 2007 9:23 am    Post subject: Off road modifications for your bus FAQ Reply with quote
To link to this post copy and paste
Code:
[url=https://www.thesamba.com/vw/forum/viewtopic.php?t=270489&start=0&postdays=0&postorder=asc&highlight=]Off road modifications for your bus FAQ[/url]
I have a 71' bus and was wondering if anyone had done any mods to their buses for off roading. and i have 14s on my bus.. Mad does any one know any good dirt tires that fit on a 14?
Happy off roading!!!!
I get by with a little help form my friends.
I get high with a little help from my friends.
I know i cant spell.
71 Sunroof Deluxe
Traveling Writer
Samba Scribe
Traveling Writer is offline
PostPosted: Fri Dec 21, 2007 9:43 am    Post subject: Reply with quote
I think the bus is amazing as is for offroading! Although that said, I've put knobby tires on the 14 rims, just because I do take the old boy onto fire trails and two-tracks in the mountains around Colorado quite a bit. But the stock ground clearance, the stock torque (especially with SMALLER tires), and the rear-engine/rear-drive setup give the bus the chops to keep up with most of your friends' jeeps or other SUVs. And they won't be able to pop the top and cook dinner after they get where they're going, either. But you know that already!
As for tires, I think the perfect bus tire that won't rub, or reduce torque too much, and fit on 14s is NLA, the BFG All Terrains. There might be a couple out there somewhere in a warehouse, but as for all of the online discount tire places, don't bother--I've been through them all, and even when they say they have some online, you'll get an email saying oops later.
Finally, check the tire sticky, because someone will say that sooner or later.... Razz
Cheers,
Davi
1977 2.0 FI Westy
2011 1200cc Yamaha Super Tenere
1976 Feet (they work surprisingly well)
jrbo
jrbo is offline
PostPosted: Fri Dec 21, 2007 9:57 am    Post subject: Reply with quote
I (Just my two cents) would try to keep it as close to stock as possible....with that said...some tire mods can be done without rubbing...read tire sticky(I said it first after you????)...
Traveling Writer
Samba Scribe
PostPosted: Fri Dec 21, 2007 10:25 am    Post subject: Reply with quote
Richard Atwell's site is also a great resource, not just for tires, but for everything bus.
http://www.ratwell.com/technical/Tires.html
Cheers,
Davi
1977 2.0 FI Westy
visibleink
visibleink is offline
PostPosted: Fri Dec 21, 2007 10:37 am    Post subject: Reply with quote
I'm going to put on 195R14 the Hankooks and hoping the slightly larger helps the bus in off road conditions. But I just want to find some off the charts camping spots.
Been on the samba so long I remember petting that dog to see VWs, WYHI, and green bug girl.
jmstu76
jmstu76 is offline
PostPosted: Fri Dec 21, 2007 12:43 pm    Post subject: Reply with quote
For offroad mods, I would start with tires as well. I have a set of the BF Goodriches. Since they are no longer available, I will probably try the Cooper SRM II's. 195/r14. They are a true D rated tire and are almost as tall as my BF's. I think wyomingriviera is running a set and they look good. Good Luck.
James
'76 Deluxe Sage Green Westy 2.0L Fuel Injected with '78 ECU and AFM, ACN SVDA Distributor, Hydraulic Lifters (boo hiss), 27in General Grabber AT2 All Terrains, Berg Shifter, stock '76 exhaust HPC Ceramic Coated.
'73 Type 181 1776cc Scat crank, rods, cam. Solex 34 Pict 3 rebuilt/bushed by Voksbitz
First VW engine I've ever built and it's still running strong. 80,000 plus miles and counting. Built in 2004.
[email protected]
View user's profile Send private message Send e-mail Yahoo Messenger MSN Messenger Instagram Gallery Classifieds Feedback
atvaz333
atvaz333 is offline
PostPosted: Fri Dec 21, 2007 12:44 pm    Post subject: Reply with quote
I'm going to be using my bus in less the perfect conditions once its completed. Dirt roads, snow, sand, etc. I asked the off road tire question also.... heres the link to the thread.
http://www.thesamba.com/vw/forum/viewtopic.php?p=2683195&highlight=#2683195
The widest tires you can get on your rims the better. The whole greater surface area deal I guess...
JMazier
JMazier is offline
PostPosted: Fri Dec 21, 2007 2:24 pm    Post subject: Reply with quote
Hey,
I also have a set of the BFG All Terrains and they have been excellent. Otherwise make sure that everything in your suspension is in top condition. Strong shocks are a must including the steering stabilizer… Finally if you do have a case of rear bus sag now is the time to fix it.
Cheers!
Jérôme
’79 Cali Westy 2.0 F.I.
'74 Honda CB 350 Four
'78 Honda CB 750 K
'12 Golf GTI
'11 Ural Patrol
atvaz333
atvaz333 is offline
PostPosted: Fri Dec 21, 2007 2:45 pm    Post subject: Reply with quote
Good advice. Right now my bus is stripped on the inside except for the front seats/dash. Would it be smart to watch the weight of the bus if its going to be seeing a lot of off road driving?
JMazier
JMazier is offline
PostPosted: Fri Dec 21, 2007 2:59 pm    Post subject: Reply with quote
Sure, the more weight the harder it is on your bus however really you still want to have all the gear in the bus that you need in order to enjoy it (camping gear, etc...) so find the balance between offroad and overall fun factor.
Cheers!
Jérôme
'78 Honda CB 750 K
'12 Golf GTI
'11 Ural Patrol
fukengruvenoval
fukengruvenoval is offline
PostPosted: Fri Dec 21, 2007 3:15 pm    Post subject: Re: Off road modifications for your bus Reply with quote
You may have a hard time making sharp turns off-road with a seventy-one foot long bus...
Check out my video series at www.youtube.com/midnightoilgarage
Current: 12 Fiat 500 Sport, 09 Ford Flex, 76 Westfalia 2L FI, 72 Euro Super Auto-Stick, 69 Type 1 Cal-Look, 56 Type 1
Past: 94 Jetta Diesel, 92 Golf, 79 Bradley GT, 74 Thing, 73 Super Euro Spec, 72 Super, 68 Type 1 Convertible, 66 Single Cab, 65 Beetle, 57 Type 1 Parts Car, 57 Porsche Speedster Kit Car (CMC), 00 New Beetle GLS
DubKru
DubKru is offline
PostPosted: Fri Dec 21, 2007 5:28 pm    Post subject: Reply with quote
Length joke number 2.
2L, Raby cam, HAM Heads, Mallory, Dual Dell 40's, Porsche discs, Fuchs (Colored matched not to my bus),tunin' the crap out of it, slammed on Wagenswest suspension.
Polish Rifle wrote:
I like to take care of my engine and find a nice speed to cruise in on my bus, but sometimes.....you just get in the mood to run the piece of crap into the ground.
atvaz333
atvaz333 is offline
PostPosted: Fri Dec 21, 2007 5:48 pm    Post subject: Reply with quote
haha seen that one before...
Bursch
Bursch is offline
PostPosted: Fri Dec 21, 2007 6:11 pm    Post subject: Reply with quote
I'm going with slightly larger tires, Vredestein Comtrac 205/82R14.
Raises the bus about an inch and has a nice wide footprint.
1978 T2b ASI Riviera Plan I // Camper Special with MegaSquirt & EDIS // 091 with 5.14 R/P and Peloquins LSD
Powered by Just Kampers, German Supply, Busted Bus & Aircooled Technology
2008: Amsterdam - Beijing - Olympics -- 17.500km
2010: Amsterdam - Cape Town - FIFA World Cup -- 26.000km
2014: New York - Rio de Janeiro - FIFA World Cup -- 28.000km
Camper Special Club Member
4Doora
4Doora is offline
PostPosted: Fri Dec 21, 2007 6:28 pm    Post subject: Reply with quote
I love the look of off road buses Cool
Get some meaty tires, a nice roof rack, and some auxiliary lights and you'll be looking fine....
I just wish my garage were big enough to fit such modifications Sad
edit:
Found a cool picture:
'69 Bug,'71 Bus,'61 Bug ,'56 Bug, '66 Panel
atvaz333
atvaz333 is offline
PostPosted: Fri Dec 21, 2007 6:42 pm    Post subject: Reply with quote
I just fell in love again..... with that bus.
bikedk88
bikedk88 is offline
PostPosted: Fri Dec 21, 2007 7:42 pm    Post subject: Reply with quote
Thats what i want mine to look like! but thanks to everyone for your ideas. thats pretty much what ive been thinking about doing to mine, the tires and lights, roof rack will come when i get the funds. im just glad to see other off road bus people cuz everyone thinks im crazy when i tell people i go on trails with it. haha they have no faith till they see me, it may go a little slower but slow and stedy wins the race.
71 Sunroof Deluxe
barrysmith
barrysmith is offline
PostPosted: Fri Dec 21, 2007 7:57 pm    Post subject: Reply with quote
edit:
that bus rules....there is an Aussie website with massive offroad bus pics but I forgot what it is Rolling Eyes
nebe
nebe is offline
PostPosted: Fri Dec 21, 2007 9:42 pm    Post subject: Reply with quote
I think this is the same bus-
what tires are those??
Also, does anyone know where to get the gravel guards that are on the headlights of that bus??
Bay74
Bay74 is offline
PostPosted: Fri Dec 21, 2007 10:04 pm    Post subject: Reply with quote
I have been looking for those too.
I can't find em either
Don't call it a van.
Page 1 of 73
