KrisBalfe Samba Member
Posted: Sat Mar 14, 2020 1:59 am Post subject: Re: Off road modifications for your bus FAQ |
If I felt it needed a battery door hinged on the rack bolts it would get one. Is there such a thing as bay window purists? If so I suggest not looking any further into this bus and apologize, as hurting them was not my intent. Yours truly the hacking hacker of hackville. |
Brian Samba Moderator
Posted: Sat Mar 14, 2020 2:02 am Post subject: Re: Off road modifications for your bus FAQ |
ngl (not going to lie) my drivers side battery compartment is hacked up with a big old hole. I was thinking of doing a pulley system to raise and lower a spare battery without a complicated door majigger _________________ Wash your hands
'69 Bug
'68 Baja Truck
'71 Bug
'68 Camper
Only losers litter |
notchboy Samba Member
Joined: April 27, 2002 Posts: 22463 Location: Escondido CA
Posted: Sun Mar 15, 2020 5:11 pm Post subject: Re: Off road modifications for your bus FAQ |
Now lifted on Wagens West front/rear lift kit. 215/75/15's.
Now the fronts don't rub at all on the sway bar, the turning radius is now super tight. I have longer throw shocks coming, but for now the rears have extenders on them.
t3kg wrote: |
Jason "notchboy" Weigel
1964 1500 S
1964 T34 S Convertible
Posted: Sun Mar 15, 2020 8:07 pm Post subject: Re: Off road modifications for your bus FAQ |
Earl Bay Samba Member
Joined: October 26, 2015 Posts: 91 Location: France 38
Posted: Mon Mar 16, 2020 8:57 am Post subject: Re: Off road modifications for your bus FAQ |
looks the nuts! |
ImAddicted Samba Member
Joined: April 24, 2012 Posts: 1195 Location: Unorganized Territory, Maine
Posted: Sun Apr 12, 2020 5:57 pm Post subject: Re: Off road modifications for your bus FAQ |
Had a little time today and the weather held for a few hours. $1 feabay LEDs “daytime running lights” make decent perimeter lighting, especially for the cost . Not really stealth but I think inconspicuous enough that won’t detract too much visually when off. Still planning one a few flood lights on the corners for after dark excursions. Think these little ones will do ok for camp lighting. Have on both sides, wired to be able to be switched on side or side or both.
_________________ 1979 Transporter (sold)
KC1MUR
strfish7 wrote: |
Original condition, which means something different on this forum than anywhere else! |
VOLTWAGEN Samba Member
Joined: May 24, 2014 Posts: 118 Location: Perth, Australia
Posted: Thu Apr 16, 2020 5:59 am Post subject: Re: Off road modifications for your bus FAQ |
Looking to change my diff, I will be looking at using my van more on dirt roads and sand, maybe some beaches, not much if any mud, will be running BFGoodrich AT's, looking to get to some more remote campsites in Western Australia
What're the thoughts on what would be more suitable/best, a true LSD like the ZF or a ATB like Quaife or Peloquin
Van is a 72 with a modified 2L and a 6 rib trans |
airkooledchris Samba Member
Posted: Thu Apr 16, 2020 1:09 pm Post subject: Re: Off road modifications for your bus FAQ |
notchboy wrote: |
hot damn that looks good. does turning the front end at speed feel squirrely at all? |
Posted: Thu Apr 16, 2020 1:17 pm Post subject: Re: Off road modifications for your bus FAQ |
airkooledchris wrote: |
notchboy wrote: |
Not at all. I have an HD sway bar anyways as well. Im sure that helps a lot. Bonus on my whole lift project. The turning radius is now amazing. The combo of the tire with the lift is perfect. Just went through all the front brake stuff. Next is ball joints and tierods.
t3kg wrote: |
1964 1500 S
vwwestyman Samba Member
Joined: April 24, 2004 Posts: 5688 Location: Manhattan, Kansas, USA
Posted: Thu Apr 16, 2020 1:40 pm Post subject: Re: Off road modifications for your bus FAQ |
Dude, that looks pretty sweet!
Stuart told me he can barely touch the ground when sitting in the open slider door. (I think that may be a slight exaggeration!)
I'm curious about a couple things.
What's it like in the wind, being taller?
Are the tires noisy?
I told Stuart yesterday that I had swapped back to stock tires (just flip-flopped with the set on the '73) last fall because I was towing the Thing and wanted to bump the RPMs, but I was also pleasantly surprised that the stock tires seemed much quieter than the General Grabbers that were on there. So they've been swapped ever since.
My front beam is pretty bad and needs replaced. So now I'm thinking about the best way to go about that. And whether that might include things like raise spindles or some other way to raise it. (Weld in adjusters, maybe?)
Hmmm... _________________ Dave Cook
1973 Wild Westerner
My Thing |
Posted: Thu Apr 16, 2020 2:44 pm Post subject: Re: Off road modifications for your bus FAQ |
I haven't really driven it in the wind. It's taken a lot to get it here. It still needs ball joints as the ones on it are shot. So any sway issues could be attributed to that.
The tires have noise, but not bad. That's like the biggest question people ask? To me its like a shot in the arm. Everyone asks does it hurt. Sure, a little. Off-road and AT tires make noise. They have a bigger tread. I don't mind it and since they are not mud swampers or some other BS, the noise is minimal. Look at some of my vids on youtube. Just changing the VS muffler to a stock one has made the ride lots quieter. I will be going back to the VS though.
As I said, I have no real performance data. It's all too new and costs so much, I've spread it out. Who said it here? This is a connoisseur/hobbyist bus?
Some real data.
This last brake overhaul -
Rebuild calipers $150
Rebuild FAG kits $25
Rebuild Vac can $225
Master, pads, rotors, soft lines $178
WagensWest Lift kit - $1661
Hankook DynaPro MT RT03 Off-Road Tire - 215/75R15 101Q - $556.78
4 steel 15" AUDI rims - $100
Machining them - $160
KYB Rear shocks - $60
Brake fluid - $12
It's still not 100% - Close but not dialed in till the ball joints/tie rods are done.
That's $3,127.78 in the last 3 months? Mostly just to raise it? This does not count labor done by Stuart or myself. Misilanious shit like blots, cleaner, paint, carne asada burritos. _________________
t3kg wrote: |
1964 1500 S
isaaccarrel Samba Member
Posted: Wed Apr 22, 2020 6:27 pm Post subject: Re: Off road modifications for your bus FAQ |
Heres a look at the most recent modifications. Ej22 so no problem spinning these things no lift a little hammering of the front wheel wells and they fit. They are utv tires that are dot approved and have 10 ply sidewalls but it still feels lofty even with brand new suspension front and rear as well as upgraded swaybars front and rear. I plan on downsizing to the grabblers listed in this thread.Heres an overnight camping trip at sugar bowl
yellowCOwesty Samba Member
Joined: April 16, 2016 Posts: 97 Location: Rocky Mountains
Posted: Wed Apr 22, 2020 9:01 pm Post subject: Re: Off road modifications for your bus FAQ |
I did about a hundred miles today on the Grabbers and they are a bit noisy but not terrible.
Also have a back dated exhaust and VS and it sounds so much better that the bungled and welded together stock leaking 78 system it had. _________________ _______________________
'78 Westy
Currently yellow and white "Sunny"
A few other air cooled VW and Porsches over the years |
cdennisg Samba Member
Joined: November 02, 2004 Posts: 20278 Location: Sandpoint, ID
Posted: Wed Apr 22, 2020 10:19 pm Post subject: Re: Off road modifications for your bus FAQ |
In automotive nomenclature, the words "stanced", "lifted" etc. are common.
I think we need a new term.
Stuffed! _________________ nothing |
Posted: Thu Apr 23, 2020 5:51 am Post subject: Re: Off road modifications for your bus FAQ |
cdennisg wrote: |
Stuffed! |
Like stuffed crust pizza...
...this looks delicious _________________ 1979 Transporter (sold)
KC1MUR
strfish7 wrote: |
SamboSamba22 Samba Member
Joined: August 06, 2015 Posts: 2772 Location: Benton, Arkansas
Posted: Thu Apr 23, 2020 6:46 am Post subject: Re: Off road modifications for your bus FAQ |
ImAddicted wrote: |
cdennisg wrote: |
Stuffed! |
...this looks delicious |
This is freaking sweet. I can only dream of the days on the mountain if I would’ve had this rig when I was living in the valley. Powder days would’ve been AMAZING. _________________ The Bus Barn Ltd. Co.
Oct. ’67 Double Cab (’68 Crew Cab)
[url=http://www.vw-mplate.com/mplate-44412.png]Click to view image[/URL]
March '69 Delivery (Panel Bus)
[url=http://www.vw-mplate.com/mplate-44414.png]Click to view image[/URL] |
borninabus Samba R&D Dept.
Joined: May 18, 2006 Posts: 4539 Location: Arizona Highways
Posted: Thu Apr 23, 2020 5:24 pm Post subject: Re: Off road modifications for your bus FAQ |
VOLTWAGEN wrote: |
my understanding is that a TBD, like a peloquin, will lose traction when a wheel lifts and that a true LSD is a much better option. _________________ 88 Van WBX, A/T - 13 JSW TDI 6M/T - 2012 Touareg TDI Sport |
klcarrie Samba Member
Posted: Thu Apr 23, 2020 6:29 pm Post subject: Re: Off road modifications for your bus FAQ |
VOLTWAGEN wrote: |
Have you considered a less expensive route of adding a steering brake? _________________ Pritchin'
Currently looking for:
- Bay Bus Pinion Nut Socket
- 64-67 big nut (rear) drums and brake parts, 46mm axle nuts (Big Nuts)
'55 Wolfburg Pannel Project
'55 Wolfsburg SC Project
'71 Westy |
Posted: Thu Apr 23, 2020 6:35 pm Post subject: Re: Off road modifications for your bus FAQ |
borninabus wrote: |
VOLTWAGEN wrote: |
my understanding is that a TBD, like a peloquin, will lose traction when a wheel lifts and that a true LSD is a much better option. |
Yep, understand that, gut/heart says a true LSD, wallet says in this climate TBD or nothing, but it's only money, can't take it with me |
Posted: Thu Apr 23, 2020 6:37 pm Post subject: Re: Off road modifications for your bus FAQ |
klcarrie wrote: |
VOLTWAGEN wrote: |
Have you considered a less expensive route of adding a steering brake? |
Have thought about it as well, just looking to see options before I put the new box in as this is the time to do it, would rather do it now than in the future |
