Kombijeepman Samba Member
Joined: July 17, 2017 Posts: 2 Location: Sydney Australia
Posted: Fri Jun 08, 2018 6:13 am Post subject: Re: Off road modifications for your bus |
hrtm wrote: |
My personal favorite off-road Bay ....
https://www.youtube.com/embed/WBXRlmnSdL0
video claims it's a stock '74 w/ modified transmission (how so??) & obviously some AT/MT tires.
wish I could find more detail on what changes were made to the transmission (Peloquin diff perhaps?). |
Hi there, that is my bus! Just saw your post. Back then it had a 4.38:1 1st gear, stock 2nd, 3rd and 4th and stock open diff with 31" BFG mud terrains rear and 215 75 15 BFG all terrains front. Suspension is lifted 1" |
Jim Bear Samba Member
Joined: March 25, 2006 Posts: 670 Location: Watkinsville, GA
Posted: Fri Jun 08, 2018 6:33 am Post subject: Re: Off road modifications for your bus FAQ |
Back then? What is the kombi looking like these days? _________________ "You're either on the bus, or you're off the bus." ~kk
'85 Vanagon Westy - George In the Stable 2020-?/'74 Weekender - Ophelia In the Stable 2007- ?/'69 Beetle Convertible - SOLD 2017-2020/'67 Beetle - September SOLD 2013-2016 /'67 SO42 Westy - Sage SOLD 1996-2001 /'69 Transporter - Baby Blue SOLD 1995-1995/'72 Westy - Nelly - SOLD 1990-1995--STOP FRACKING |
Posted: Fri Jun 08, 2018 7:21 am Post subject: Re: Off road modifications for your bus FAQ |
I should have mentioned it is actually a '79, the gearbox is an 091 and the engine is a 2 litre type 4 with Kadrons. It still looks pretty much the same today give or take a bit more rust and a few battle scars but gearbox now has a 5.38:1 diff, 0.85:1 top gear and a Syncro diff lock vacuum actuated. It is still my daily driver. Rear tyres are currently 30" mud terrains but I have been wanting to fit 16" tyres for a long time. 15s get too wide before they get tall; not keen to cut the body, 31's fit in the rear but that is pretty much the limit. I did run 33 10.50 15s on the rear for a while but they only cleared on the street. My current wheels are 15x7 rear and 15x6 front on stock 14" centres. I really like this look but I have not been able to find a way to have 16s that look like stock 14s and can fit the stock hub cap. I really want to fit 235 85 16s in the rear. I have a set of factory Syncro 16 inch wheels but they don't look stock so haven't gone there yet. I haven't figured out how to post pics on here yet.[/youtube] |
bnko Samba Member
Posted: Sat Jun 23, 2018 12:27 am Post subject: Re: Off road modifications for your bus FAQ |
Here is my 1973 Baywindow , V6 powered (ford cologne from an old bronco) .
[/img] _________________ barbecue,fire and matte black.https://www.instagram.com/pacifist_northwest/ |
frenchymanxter Samba Member
Joined: December 21, 2006 Posts: 81 Location: france (Europe)
Posted: Sat Jun 23, 2018 3:41 am Post subject: Re: Off road modifications for your bus FAQ |
bnko wrote: |
[/img] |
love your bay... |
inhabor Samba Member
Joined: September 09, 2012 Posts: 194 Location: florida
Posted: Sun Aug 12, 2018 4:46 pm Post subject: Re: Off road modifications for your bus FAQ |
Now I have the power to go off road. |
ImAddicted Samba Member
Joined: April 24, 2012 Posts: 1195 Location: Unorganized Territory, Maine
Posted: Sun Sep 16, 2018 6:25 am Post subject: Re: Off road modifications for your bus FAQ |
inhabor wrote: |
And apparently make it look nice before you leave...
_________________ 1979 Transporter (sold)
KC1MUR
strfish7 wrote: |
Original condition, which means something different on this forum than anywhere else! |
KrisBalfe Samba Member
Posted: Sat Sep 22, 2018 5:02 pm Post subject: Re: Off road modifications for your bus FAQ |
Oh hey. |
guzzirider Samba Member
Joined: May 01, 2005 Posts: 107 Location: Durango CO at last
Posted: Sun Sep 23, 2018 8:09 pm Post subject: Re: Off road modifications for your bus FAQ |
I have run General Grabber 27 x 8.5x 14 with good results. They rubbed until I did a 2" lifted spindles and cranked up rear
[/url] _________________ 69 doublecab with 2" lift
Suzuki DR650
2016 Dodge Crew 1500 4x4 |
Posted: Sun Sep 23, 2018 8:11 pm Post subject: Re: Off road modifications for your bus FAQ |
Suzuki DR650
cdennisg Samba Member
Joined: November 02, 2004 Posts: 20271 Location: Sandpoint, ID
Posted: Sun Sep 23, 2018 8:57 pm Post subject: Re: Off road modifications for your bus FAQ |
Those tires should not rub up front at stock height. You may have some broken torsion leaves. _________________ nothing |
Posted: Sat Oct 06, 2018 5:10 pm Post subject: Re: Off road modifications for your bus FAQ |
Winch install and finally found out how heavy she is.
jacwri Samba Member
Joined: July 02, 2017 Posts: 7 Location: Gwinnett, Georgia
Posted: Sun Oct 14, 2018 5:22 pm Post subject: Re: Off road modifications for your bus FAQ |
Tell me I'm crazy but I may have begun solving the big issue with lifting buses: CV angle. If we could make bolt on portal axles: thus the outer cv joint would connect like 4 inches higher, we could lift way higher before the angle became a wear issue.
Obviously custom fabrication cost and all that, but why wouldn't this work? Axle comes out, connects with standard CV joint at top of portal axle, drives meshed gears directly downward (two types: one with standard direction of 091 transmissions, then one with reversed direction for subaru/other transmissions). where the bottom gear connected to the hub at the same spot the outer CV normally does.
Tell me I'm crazy and shouldn't look into this more. |
Posted: Sun Oct 14, 2018 5:41 pm Post subject: Re: Off road modifications for your bus FAQ |
jacwri wrote: |
Myself and a few others discussed this in the split bus forums a few years ago, in an effort to gain more ground clearance. CV angle wasn't the issue there, but the same basic physics apply.
I had thought of a double roller chain system with a direct ratio, but it proved to be an issue for highway speeds.
There is an agricultural machine known as a spra-coupe. They are still built today, but when they were first developed in the 70's they used an industrial type 1 style engine with a 3 rib bus tranny. Those axles were connected to a (I think) roller chain drive system that allowed the machine to sit high above the row crops it need to spray. As I recall, the center-to-center of the CV axle and the drive axle was nearly two feet. I'll dig for a photo. _________________ nothing |
Posted: Sun Oct 14, 2018 5:44 pm Post subject: Re: Off road modifications for your bus FAQ |
Here's an old spra coupe. You can just make out the high rise transfer case/portal axle thingy inside the rear wheel.
1970fun Samba Member
Posted: Mon Oct 15, 2018 9:21 pm Post subject: Re: Off road modifications for your bus FAQ |
cdennisg wrote: |
That thing looks like the Colonial Viper spacecraft in the Battlestar Galactica |
airkooledchris Samba Member
Posted: Tue Oct 16, 2018 10:18 am Post subject: Re: Off road modifications for your bus FAQ |
How much of this is actually Vanagon?
EDIT: nevermind, I checked your gallery. The only thing I can't (and don't want to) picture is where you store the balls it took to tackle this project.
absolutely killer! |
Posted: Wed Oct 17, 2018 7:00 am Post subject: Re: Off road modifications for your bus FAQ |
How much of this is actually Vanagon? Just the parts that had to be.
It actually went pretty well all things considered. If I were to do it again I think I could save myself some time and headaches... if I bump into the right syncro my wife's hightop is doomed. |
jeronimovw Samba Member
Posted: Sat Oct 20, 2018 11:27 am Post subject: Re: Off road modifications for your bus FAQ |
Hi, who at home has installed a rack and pinion on are t2
Thanks |
Gubdonem Samba Member
Joined: October 04, 2013 Posts: 39 Location: Ensenada, Mexico
Posted: Sun Oct 21, 2018 10:12 pm Post subject: Re: Off road modifications for your bus |
jokgel wrote: |
How much you have on your offroad- bay?
Take a picture in the same fashion . |
Is that the T2 Synchro Bus? |
