128vw Samba Member
Joined: April 05, 2006 Posts: 222 Location: Western Massachusetts
Posted: Tue Dec 25, 2007 12:17 pm Post subject: head cc |
I,m building a 1914, 94X69. I have a pair of 043 heads with 40-35.5 valves. I measure the cc's at 48. Does this sound right? I have a deck of .122 and this gets me a 7.9/1 comp. Would I have to cut the heads .030 to get to 8.5/1. I have a engle 110 cam and 40idf carbs. |
iltis74 Samba Member
Joined: November 20, 2003 Posts: 826 Location: Anchorage, AK
Posted: Tue Dec 25, 2007 1:05 pm Post subject: |
They could be 48cc, though that's not a lot. You're math is right, but to get to 8.5 you need to either take .030 off the deck height, or drop the heads to 42cc. I would leave the heads alone. |
vwracerdave Samba Member
Joined: November 11, 2004 Posts: 15309 Location: Deep in the 405
Posted: Tue Dec 25, 2007 1:15 pm Post subject: |
With the W110 cam I would leave the compression at 7.9. You will not gain any notacible amount by increasing it to 8.5 _________________ 2017 Street Comp Champion - Thunder Valley Raceway Park - Noble, OK
128vw Samba Member
Posted: Tue Dec 25, 2007 1:17 pm Post subject: |
To lower the deck do I cut the top or the bottom of the cyls or machine the case? Thanks for the reply. |
Posted: Tue Dec 25, 2007 5:31 pm Post subject: |
Always modify the cheapest part. The cylinders cost less then the case, so you should shorten the cylinders. If you screw it up, it is cheaper to buy a new set of cylinders then a new case. _________________ 2017 Street Comp Champion - Thunder Valley Raceway Park - Noble, OK
Joined: August 15, 2002 Posts: 4394 Location: Brew City
Posted: Wed Dec 26, 2007 8:42 am Post subject: |
vwracerdave wrote: |
Always modify the cheapest part. The cylinders cost less then the case, so you should shorten the cylinders. If you screw it up, it is cheaper to buy a new set of cylinders then a new case. |
X2 |
128vw Samba Member
Posted: Wed Dec 26, 2007 9:52 am Post subject: |
Can I just chuck up the cylinders in my lathe and take off .030 from the top? |
miniman82 Samba Swamp Donkey
Joined: March 22, 2005 Posts: 9515 Location: Southern Maryland
Posted: Wed Dec 26, 2007 11:17 am Post subject: |
I turned .030" off the botoms of mine with a brake lathe.
Tedious, but effective. _________________ Build thread: http://www.thesamba.com/vw/forum/viewtopic.php?t=212747
Glenn wrote: |
satterley_sr wrote: |
I just wanted to bitch but I'm getting no sympathy. |
Welcome to the Samba. |
