bugdozer Samba Member
Posted: Fri Dec 28, 2007 2:26 pm Post subject: throttle cable and stuff |
yesterday i bought and installed a stand off for my carburator because there was a little bit of the carb hitting my generator. now the car runs great, but i can't get the throttle cable back into the throttle body. the cable has a crimped on end peice that is about 1/8th of an inch too short. it is only a 1 inch stand off from the original position of the carb and i didn't expect any issues. do any of you guys know how to get an eighth inch out of a throttle cable short of replacing it? |
buggn Samba Member
Joined: October 21, 2007 Posts: 75 Location: Junction City, Ks
Posted: Fri Dec 28, 2007 3:04 pm Post subject: |
Check with some of the vw parts stores. Most sell extension kits for cables and they are cheap. _________________ 67 Type I
74 Super Convertible
60 Ghia Convertible
02 New Beetle
www.buggn.com |
drscope Samba Member
Joined: February 19, 2007 Posts: 15273 Location: Baltimore, Maryland USA
Posted: Fri Dec 28, 2007 4:41 pm Post subject: |
Try this
http://www2.cip1.com/ProductDetails.asp?ProductCode=ACC%2DC10%2D2569
If that won't work, or you can't wait, you can try going to your local hobby shop and buying some steel tube that will fit over the cable end. Then solder it in place. Sort of makes your own extension. _________________ Mother Nature is a Mean Evil Bitch! |
Posted: Fri Dec 28, 2007 7:15 pm Post subject: |
i talked to the guy at the local vw store and he says that i should get a new cable. i dont want to do that yet, so i think i might go with the doc's idea. thanks guys. |
