Electrical Connectors
Randy in Maine
Randy in Maine is offline
PostPosted: Sun Dec 30, 2007 1:31 pm    Post subject: Electrical Connectors Reply with quote
The last time I removed my dash, I decided that I really need to come up with a much neater and better organized wiring set up back there.
What are the best and most secure connectors that I can use? Marine or aviation or just what? A link to someplace would be nice.
I have a gob of crimp on connectors in my parts bins, but they really just don't hold up all that well IMO. They seem to all get loose and just look kind of cheesey.
hazetguy
hazetguy is offline
PostPosted: Sun Dec 30, 2007 1:59 pm    Post subject: Reply with quote
are you looking for factory style, non-insulated terminal ends like this?
thebucket: I invested in hoodride, now DBD won't return my call?
hazetguy: invested?
thebucket: Yeah Haze, its where people put money into a company in hopes of a return on their money
Randy in Maine
PostPosted: Sun Dec 30, 2007 2:07 pm    Post subject: Reply with quote
I have those already.
Can you suggest something better?
hazetguy
hazetguy is offline
PostPosted: Sun Dec 30, 2007 2:10 pm    Post subject: Reply with quote
never needed anything better than that, so no, i can't help you there.
hazetguy: invested?
rccbusfreak
rccbusfreak is offline
PostPosted: Sun Dec 30, 2007 3:13 pm    Post subject: Reply with quote
Randy, you can find just the metal sleeve for a butt connection and use shrink wrap makes a smaller clean connection. I'll pull off the red and blue eye sores on spay and eyelet connectors and also use the wrap. Also if you slide the spay connector on anything existing on your bus. Clean and use some type of anti-corrosion ointment. Hope this helps.
71 Westfalia
68 Transporter
71 Transporter parts bus (the bus that keeps on giving)
LudwigUSA
Duncwarw
Duncwarw is offline
PostPosted: Sun Dec 30, 2007 3:44 pm    Post subject: Reply with quote
I've had no trouble with crimp ons but I tin, solder, crimp & shrink.
Crimp ons with the plastic sleeve suck. I remove them.
“To find yourself, think for yourself”
Socrates, 470 BC - 399 BC
pb24ss
Location: sitting around the fire with the bluegrass band - colorado
pb24ss is offline
PostPosted: Sun Dec 30, 2007 3:46 pm    Post subject: Reply with quote
i use metal crimp ons and solder. not the cheap ones with the plastic red/blue/yellow sleeves, but plain old metal ones that real electronics stores sell. always solder the connections though.
gmag69
Type2 Nutcase
gmag69 is offline
PostPosted: Sun Dec 30, 2007 4:04 pm    Post subject: Reply with quote
Has anyone ever used one of the cold heat soldering guns. I was thinking of getting on for when I do my wiring but want to know if they work or not.
Geno Very Happy
Check out my Westy resto. thread.
http://www.thesamba.com/vw/forum/viewtopic.php?t=230285
1977_L63H_P27
1977_L63H_P27 is offline
PostPosted: Sun Dec 30, 2007 4:15 pm    Post subject: Reply with quote
Geno Very Happy
I bought one of those from the "As Seen On TV" store. The tip is actually a double tip insulated in the middle, and works along the lines of an arc welder. When it makes contact with the solder, the current passes thru' it and heats it up. I haven't been able to master it yet,and it tends to darken (burn?) the solder. Peace!
busdaddy wrote:
...and try a few chubby ones until you find one you like.
1977 Westfalia P27 Green Bay Bus
you can't spell Volkswagen without SWAG
M-code Plate
Full Moon Bus Club
Karl
Karl is offline
PostPosted: Sun Dec 30, 2007 4:49 pm    Post subject: Reply with quote
The secret to crimp ons, other than soldering, is to use the correct tool to crimp them. Forget about the ones that just crush them..... vise grips work just as poorly. You want a tool that has a dull point that sits in a U.
The middle section of this tool:
http://www.doityourself.com/invt/u262995
hazetguy
hazetguy is offline
PostPosted: Sun Dec 30, 2007 4:58 pm    Post subject: Reply with quote
i use this tool for non-insulated terminals (about the only type i use). it crimps both parts at once--the part that crimps around the exposed metal strands and the part that crimps the wire covering.
you can also get different jaws for it to crimp other types of connectors.
hazetguy: invested?
mattcuddy
mattcuddy is offline
PostPosted: Sun Dec 30, 2007 5:02 pm    Post subject: Reply with quote
what he said. factory style open barrell, f-type connectors are where its at. (just need the correct crimping tool shown above from del city, german supply, etc.)
If you've been using the Pep Boys type red/blue jobbies with a standard Pep Boys type crimping tool and move to "the real deal" the difference is night and day.
If you're already using factory style open barrell than I can't think of a better option either. Though on some exposed connections (starter for example) I've taken off the soft plastic jackets that come with some of the connectors at your FLAPS (and cover teh whole terminal) and used them in conjunction with the factory style open barrell connectors. to create what is in the bottom right of hazetguy's picture.
keifernet
Samba Search & Rescue
keifernet is offline
PostPosted: Sun Dec 30, 2007 5:21 pm    Post subject: Reply with quote
This style works fine for the most common terminals... better than the cheezy ones they sell with the "kits"
http://www.mytoolstore.com/klein/1005.html
this style sucks for crimping connectors... but has other uses.
http://www.specialized.net/ecommerce/shop/layout.a...-Tool-1000
rccbusfreak
PostPosted: Sun Dec 30, 2007 5:34 pm    Post subject: Reply with quote
I like the Klein crimper. I have used the crimper that has the stripper in the handle and they have pulled apart. The Klein tool is not cheap.
71 Westfalia
68 Transporter
LudwigUSA
ccpalmer
ccpalmer is offline
PostPosted: Sun Dec 30, 2007 9:35 pm    Post subject: Reply with quote
I used to be a "only solder" guy but I am now sold on using a proper crimper with crimp-on connections. Soldering in tight areas and with smaller, older wire can be troublesome.
So I'd say get a good crimper and use the proper sized crimp-on connectors.
'71 Westy
keifernet
PostPosted: Mon Dec 31, 2007 7:47 am    Post subject: Reply with quote
For what ever reason I have three pair... and I found them all in the middle of the feeder or beside the freeway by chance and managed to stop and grab them without becoming another hit and run victim in this town!
germansupplyscott
germansupplyscott is offline
PostPosted: Mon Dec 31, 2007 8:00 am    Post subject: Reply with quote
http://www.germansupply.com/xcart/customer/home.php?cat=390
i am going to build a kit with some of the most needed terminals and the crimping tool, but for the time being we have a pretty good selection of terminals for aircooled VW's. where we need more selection at the moment is with terminals that work with the small wire gauges, some of the .25 termials are not ideally sized for small gauges (.5mm).
i agree that there really isn't anything better than the original style terminals. every single vehicle that gets worked on here leaves with about a dozen or more of these terminals crimped into the original wiring. sometimes you need to splice wires as well and that's where to solder and shrink wrap comes in handy. but if you just need new termination on the wires, use the original stuff and it will work perfectly for another 20 years.
SL
rccbusfreak
PostPosted: Mon Dec 31, 2007 8:44 am    Post subject: Reply with quote
I have used the small ones off the instrument cluster in my parts bus. Wires and all.
71 Westfalia
68 Transporter
LudwigUSA
mattcuddy
PostPosted: Thu Jan 12, 2012 9:46 am    Post subject: Reply with quote
Total thread resurrection, but here goes.
Anyone know of a decent supplier of the factory open barrel connectors (shown below) in bulk at a decent price? Everywhere seems to sell them in packs of like 4, and the ones I've been getting lately from my FLAPS are really thin and don't hold the connection to the male end very well.
Forest Ape
Forest Ape is offline
PostPosted: Thu Jan 12, 2012 9:56 am    Post subject: Reply with quote
Del's Vintage Connections.
http://www.vintageconnections.com/
'79 Adventurewagen 2.0L FI CA
Looking for a clean rear cargo hatch, email me.
