joe thorpe Samba Member
Joined: November 08, 2004 Posts: 5 Location: Manassas, Va.
Posted: Wed Jan 02, 2008 8:13 am Post subject: 36hp verses 40hp |
My 36hp needs freshing up before adding a Judson. Does anyone know if 40hp pistons/cyls will work in a 36hp case?? After looking at specs for both, I noted that 36hp & 40hp pistons have the same dimensions (77.0mm) and the stroke of the crankshaft is the same also. The only difference I noted was the compression (6.1-36hp and 6.6-40hp). I do not have a 40hp piston to measure but I guess the difference would be the measure between the crown of the piston and the top of the wrist pin with the 40hp piston being longer adding the difference in compression??? Any thoughts??? Also, 40hp pistons are about half the cost of 36hp pistons. |
60ragtop Bonneville Belt Bitch
Joined: March 13, 2006 Posts: 7800 Location: Big Wonderful WYO 82401
Posted: Wed Jan 02, 2008 8:17 am Post subject: 36 |
I believe the head bolt spacing is different. _________________ Rick
Certified Mechanic by the State of Michigan in 1977
ASA certified in 1987
Certified Hunter Wheel Alignment Master Technician 1986
tasb wrote: |
I've restored a large number too, but I don't toot my horn quite as loud.
sb001 wrote: |
maybe he just snapped cause his car sucked |
splitjunkie Samba Member
Posted: Wed Jan 02, 2008 11:05 am Post subject: |
40 hp piston pins are larger diameter I believe. _________________ Chris
wmcclay Samba Member
Joined: December 18, 2004 Posts: 147 Location: Sacramento, Ca
Posted: Thu Jan 03, 2008 6:58 am Post subject: |
Talk to matt at aircooledresearch.com. He is building 36 hp engines. Has performance cams, stroked cranks etc. There is a great sticky in this forum on this subject. |
baked beetle Samba Member
Joined: September 23, 2006 Posts: 1162 Location: Alberta, Canada
Posted: Thu Jan 03, 2008 7:53 pm Post subject: |
no |
