davevickery Samba Member
Joined: July 16, 2005 Posts: 2887 Location: Fort Collins, CO
Posted: Wed May 01, 2013 11:51 am Post subject: |
19+ inches sounds high. Is that what they are supposed to be or do you have shims too. An inch and a half lift would be like 17.5" wouldn't it? Or do they need to settle? 19" just sounds high for a 2wd camper. |
luVWagn Samba Member
Joined: February 21, 2008 Posts: 1340 Location: Snoqualmie (WA)
Posted: Wed May 01, 2013 5:48 pm Post subject: |
davevickery wrote: |
Seems fairly common, see earlier in this thread:
djs94124 wrote: |
Ride height as measure from wheel centerline to fender lip is as follows:
Front: 18.5"
Rear: 18.5" (slightly less on the left side as previously mentioned) |
So i'm not far off of that, and this is on a fresh install. I may have spacers in the rear (I know I ordered them), but they wouldn't add much. _________________ '91 Syncro 16 Reimo Hightop Conversion, eTDI |
PDXWesty Samba Member
Joined: April 11, 2006 Posts: 6243 Location: Portland OR
Posted: Wed May 01, 2013 6:27 pm Post subject: |
Keep in mind this thread was started in 2008. The springs GW sells today are different than the ones they sold 5 years ago. Your numbers now may vary from 5 years ago. _________________ 89 Westy 2.1 Auto |
tarandusVDub Samba Member
Joined: August 27, 2010 Posts: 1649 Location: Between Here and There
Posted: Wed Jul 17, 2013 10:19 am Post subject: |
PDXWesty wrote: |
Keep in mind this thread was started in 2008. The springs GW sells today are different than the ones they sold 5 years ago. Your numbers now may vary from 5 years ago. |
PDXWesty, did you end up getting the newer 1.5" lift springs? I'm installing tomorrow and am wondering if I need to put in spacers in the rear too. Will of course be including the ball joint spacers... _________________ 1990 Syncro 16" DoppleKabine 2.1 DJ 112i
________________________
Sold: 1972 Bay Campmobile; 1984 Westy, base model, 2WD. |
Posted: Wed Jul 17, 2013 11:44 am Post subject: |
tarandusVDub wrote: |
PDXWesty wrote: |
PDXWesty, did you end up getting the newer 1.5" lift springs? I'm installing tomorrow and am wondering if I need to put in spacers in the rear too. Will of course be including the ball joint spacers... |
I never did install GW springs. _________________ 89 Westy 2.1 Auto |
Posted: Wed Jul 17, 2013 1:45 pm Post subject: |
OK thanks PDX...
I'm interested in feedback from those who installed the gowesty 1.5" springs...I'm installing them this week in my '84 westy, and am wondering if I need to use a pad in the RR to counter the highest corner, the FR.
Right now with stock springs my van sits at: LF: 16 1/8; LR: 16 1/2; RF: 16 7/8; RR: 16 1/2.
So my rear is even, but the FR is the highest of them all. Is this due to westy lean? I would expect the LR to be lower than the RR, but its not...Would a gowesty 1/2" pad on the RR spring level things out?
Thanks _________________ 1990 Syncro 16" DoppleKabine 2.1 DJ 112i
madspaniard Samba Member
Posted: Wed Jul 17, 2013 1:47 pm Post subject: |
OK thanks PDX...
Thanks |
How did you measure? westy tank full of water? empty cabinets?...camping gear? _________________ 1991 Westy auto w/ Peloquin TBD
"The only difference between me and a madman is that I'm not mad” - Salvador Dali |
Posted: Wed Jul 17, 2013 1:48 pm Post subject: |
Good question!
Empty everything ~ no water, no gear, no humans, etc.... _________________ 1990 Syncro 16" DoppleKabine 2.1 DJ 112i
ezee Samba Member
Joined: July 21, 2013 Posts: 14 Location: Vancouver, BC
Posted: Tue Feb 11, 2014 10:03 pm Post subject: |
I recently installed the GoWesty 1.5" lift springs, after reading a diverse range of experiences (which almost made me return the springs instead of installing them!), so I thought I would share my own experience.
'85 Vanagon Camper 2WD. Height from hub to fender ranged from 16-16.5" with the old springs. After installing the new ones, ride height increased by a solid 2", so now sitting at 18-18.5". At the same time I installed new OEM Sachs/Boge shocks from Bus Depot.
Installation of the springs was pretty pricey, took a professional shop 4 hours. I installed the shocks myself. The westy now drives so much tighter, not too soft not too hard. Hardly tips when cornering, and dips far less when breaking. It used to feel a bit like a boat. It's been about 2 weeks, and so far so good.
Now I just gotta find some bigger wheels and tires... |
Sitka Samba Member
Joined: August 24, 2013 Posts: 35 Location: British Columbia
Posted: Tue Feb 11, 2014 10:44 pm Post subject: |
Not to highjack the thread but has anyone installed the GW lift springs on a tiptop?
Contemplating using them on my 2wd Doka |
GreggK Samba Member
Joined: May 17, 2008 Posts: 897 Location: Colorado/Philidelphia
Posted: Wed Feb 19, 2014 7:38 pm Post subject: |
Im in the process of installing GW 2wd lift springs in the rear of my tin top. I have GW zero lifts on the front with Koni shocks. That brought the front up considerably. I had syncro.org springs in the rear and with the zeros it was almost level. I want to replace the rears and GW suggested using the lift spring in the rear after I told them I have a subaru motor along with GW steel plate bumpers and the hitch.
Ive got one side on now and its looking a bit higher than the front but I also have my drive train out right now. Im worried its going to be too high and effect my CV joints. They did tell me at GW that I could swap them out with zeros if I wasent happy. I was going to get matching konis for the rear but found out they are too short for the springs. So now Im looking at Rancho rear shocks and worried that if i switch back to the zero lift springs.... Ill be stuck with too long a shock . Maybe I should start a new topic asking that question. |
Goldie86 Samba Member
Joined: September 09, 2010 Posts: 20 Location: Portland, OR
Posted: Thu Feb 20, 2014 9:17 am Post subject: |
Thanks for the post ezee. I'm ordering the 1.5" lift springs from go westy today along with Bilstein shocks and 16" rims. Can't wait to see how it changes the handling and ride. _________________ Goldie-but-Goodie, 86 AT Westy, 2.5 Subi power |
Posted: Fri Feb 21, 2014 3:04 pm Post subject: |
Goldie86 wrote: |
Thanks for the post ezee. I'm ordering the 1.5" lift springs from go westy today along with Bilstein shocks and 16" rims. Can't wait to see how it changes the handling and ride. |
This is exactly my setup since summer 2013 and results and I love it. Have Yokohama Geolandars on the rims. We've put probably 4000 miles on the setup. I do drive a bit more slowly on curves ~ we have a big sweeping 90 degree turn in the road home and I used to do 65 on it, now slow down to 55 or so. It took me a bit of getting used to so now I'm more confident, but the improvement in handling is well worth the slight change in feeling of height and stability. _________________ 1990 Syncro 16" DoppleKabine 2.1 DJ 112i
Posted: Fri Feb 21, 2014 9:25 pm Post subject: |
Goldie86 wrote: |
This'll be different shocks though than ezee's, and i've heard some folks complain about the Bilstein HDs with lift-springs - not clear to me what the best combo is.
I have the GW lift springs, but i'm NOT happy with the ride - but I'm hoping that is because of my shocks. So I keep wondering which shocks I should order (front+back) so that my lift is more drive-worth... _________________ '91 Syncro 16 Reimo Hightop Conversion, eTDI |
Posted: Tue Feb 25, 2014 6:45 pm Post subject: |
Bump!
Could anybody chime in with what shocks they're running on combination with the GW lift-springs, and if you're happy with the results?
Thank you! _________________ '91 Syncro 16 Reimo Hightop Conversion, eTDI |
levi Samba Member
Joined: February 11, 2005 Posts: 5522 Location: Las Vegas
Posted: Tue Feb 25, 2014 8:03 pm Post subject: |
I'll tell you that I have h.d. bilstein with 1 1/2" lift and I am NOT content with that combo, way too soft and springy front end. _________________ One of these days I'm gonna settle down,
but till I do I won't be hangin round.
Going down that long lonesome highway,
gonna see life my way
https://youtu.be/cSrL0BXsO40 |
1621 Samba Member
Posted: Wed Feb 26, 2014 1:40 am Post subject: |
I've got a number of changes, including the GW Springs, Koni adjustable shocks, a larger front Whiteline sway bar, and added a rear Addco bar to balance things out. This combo, along with the E-rated Nokians, have improved the ride of a heavy van considerably. Take note though, the Konis are shorter by enough to make shock extensions necessary, but relatively easy with a donor pair of shocks. I have a picture in my gallery of a rear extension design I fashioned after some Tristar Eric made.
The combination is fantastic, firm but not harsh. The wallowing I experienced with the Bilstiens is gone, and the van tracks well. It took some fine tuning, but all is well afterwards. _________________ '85 Westy |
Steve M. Samba Member
Joined: July 30, 2013 Posts: 6829 Location: Fort Lauderdale, Fl.
Posted: Wed Feb 26, 2014 1:15 pm Post subject: |
1621 wrote: |
a larger front Whiteline sway bar, and added a rear Addco bar to balance things out. |
Where did you find the Whiteline Sway Bar? Thanks. |
insyncro Banned
Posted: Wed Feb 26, 2014 2:05 pm Post subject: |
Drive some vans with different setups.
Suspension feel is subjective and many online descriptions don't match the general consensus. |
coclimber Samba Member
Joined: July 18, 2013 Posts: 245 Location: Morrison, Colorado
Posted: Wed Feb 26, 2014 11:31 pm Post subject: |
luVWagn wrote: |
Bump!
Thank you! |
1.5" GW lift springs, HD Bilstein Shocks, 16" GW alloys, and Michelin Defender tires = HEAVEN
Its like riding on glass.
Higher ride has been nice for ground clearance camping
Saved $ on my Subaru conversion because I didn't need to buy a shortened oil pan since my gnd clearance was high enough _________________ '83.5 Westfalia Camper - SOLD
'86 Westfalia Weekender
2001 Subaru Legacy 2.5L donor
Rocky Mountain Westy kit |
