ScrapJunkie (O\U|U/O)
Joined: March 17, 2004 Posts: 3977 Location: Hutchinson, Kansas
Posted: Wed Jan 09, 2008 7:20 pm Post subject: |
sled wrote: |
boy thats going to be a really low bus when you have it on the dollies. |
That's what I was thinking. Maybe a foot or so of bar stock in between the casters and those plates might help? _________________ (O\U|U/O) Top Vw (o\UU/o) |
swervyjoe Samba Member
Joined: February 07, 2004 Posts: 968 Location: denver, co
Posted: Thu Jan 10, 2008 12:46 am Post subject: |
Germanpride wrote: |
sled wrote: |
That's what I was thinking. Maybe a foot or so of bar stock in between the casters and those plates might help? |
here are some i threw together. unless you wanted it that low.
bus guy Samba Member
Joined: November 13, 2002 Posts: 785 Location: Southsea, UK South Coast
Posted: Thu Jan 10, 2008 12:23 pm Post subject: |
Thanks guys, but I wanted it that low. I have a small low garage adjoining my workshop that I store cars in sometimes when the main workshop is full. This means if I have a lot of customer work in I can put the bus out of the way for a while, then if I want to work on it I can push it over the lift and lift it up a few feet from the floor. |
sled Samba Member
Posted: Thu Jan 10, 2008 12:53 pm Post subject: |
i figured you knew what you were doing
keep us updated!! _________________ drive your split. |
j.pickens Samba Member
Joined: December 03, 2002 Posts: 9790 Location: Exit 7, New Jersey
Posted: Thu Jan 10, 2008 2:20 pm Post subject: |
swervyjoe wrote: |
sled wrote: |
Sweet!
Is that a commercial dolly jack that you added the VW mounting plate to? _________________ Founder and Chairman Emeritus, ECMSAS
BeaterBarndoor wrote: |
i wish more people would actually drive their vws rather than just talking about what they have in the garage. |
Red Fau Veh wrote: |
If you've seen one sunroof swivel seat kombi, you've seen them all! |
Posted: Thu Jan 10, 2008 11:14 pm Post subject: |
just a trailer jack. i added the caster and the plate. adjusts from just over stock height to rediciously high. |
Posted: Fri Jan 11, 2008 6:17 pm Post subject: |
Did a bit of work on the rear bumper. Someone had cut out a section in the past with a torch, so i found the thickest metal I could and heated, bent, hammered and welded it into place. Still needs some finishing, as well as grinding the welds, but it has the right shape and you get the idea..
I guess it had a hitch on at some point, as the lower area in the center was cut and bent down and a hole was drilled. I straightened it, just have to weld up the cuts.
sled Samba Member
Posted: Sat Jan 12, 2008 12:03 am Post subject: |
very nice
is that a sealing wax red bumper bracket and splash pan? if so and you dont want it for your pg/sg bus, i have a swr bus that might want them _________________ drive your split. |
Posted: Sat Jan 12, 2008 4:25 am Post subject: |
No, It's just orange, EVERYTHING on the bus has a coat of it, underneath the gold and 'forest' green... |
Stocknazi Samba Member
Posted: Sat Jan 12, 2008 7:38 am Post subject: |
height adjustable wheel dollies, that's a really good idea _________________ WANTED:
"Resistance to tyrants is obedience to God."
Thomas Jefferson |
Posted: Mon Jan 14, 2008 12:58 pm Post subject: |
I finished up the repairs on the rear bumper, before removing the rear brackets and spash pans ready for blasting.
Both rear corners are rusted where they meet the battery trays, so I cleaned up the drivers side one ready to remove the metal.
Once the metal was removed you can see the tray needs a small repair. This side is not bad enough to be replaced (the other side will be replaced).
Finally (for today) I ground back the welds on the taillight holes ready for paint and removed the plexiglass rear 'safari' window..
stephenmullens Samba Member
Joined: January 13, 2005 Posts: 1927 Location: New Mexico
Posted: Mon Jan 14, 2008 4:16 pm Post subject: |
I like how you're making quick work of your bus...getting right down to it. Is that a wolfsburg decklid there? |
Posted: Tue Jan 15, 2008 12:40 pm Post subject: |
Thanks for the comments, it is a Wolfsburg decklid, I will try and post some pics of the inside..
I have a lot of work on at the moment, but I am trying to just give it half an hour or an hour at least 2 or 3 times a week. I figure if I do this I should have the metalwork done in a couple months. The only limiting thing will be the gerson panels - the UK importer doesn't seem to answer emails and doesn't hold stock of wheelwells, etc. I might have to get some from splitpile or metwiz and ship them, so this might slow me down - I need to sell my '68 deluxe before I can afford them |
Scotty Samba Member
Joined: July 02, 2003 Posts: 1531 Location: Northampton - Uk
Posted: Wed Jan 16, 2008 6:42 am Post subject: |
I can't wait to see the end result _________________
EverettB wrote: |
http://scottys-stuff.blogspot.com/ |
hazetguy Samba Member
Joined: April 06, 2001 Posts: 10773 Location: iT StiNgeD iTseLf tO dEAd
Posted: Thu Jan 31, 2008 7:40 am Post subject: |
that didn't take long. http://www.thesamba.com/vw/classifieds/detail.php?id=563433 _________________ thebucket: I invested in hoodride, now DBD won't return my call?
hazetguy: invested?
thebucket: Yeah Haze, its where people put money into a company in hopes of a return on their money |
Posted: Thu Jan 31, 2008 8:34 am Post subject: |
Nope. |
sled Samba Member
Posted: Thu Jan 31, 2008 9:11 am Post subject: |
well, so much for that. _________________ drive your split. |
hugheseum Samba Member
Joined: February 11, 2004 Posts: 2690 Location: oregon
Posted: Thu Jan 31, 2008 9:31 am Post subject: |
funny how many of these projects start out at full steam,i actually thought this guy was gonna finish saving this bucket from the woods,its probably like every old bus,you go so far then realize it needs absolutely everything and its literally dropping rust from everywhere as your fitting/grinding. i see the rockers look solid,but i'll guarantee they are rusty.....they all are _________________ Have a great day! |
Posted: Thu Jan 31, 2008 11:26 am Post subject: |
Well, you know, I kind of expected this from the folks who love to bitch at everyone else (hey at least I didn't bag it on fake earlies ) and maybe I walked into it. I kind of thought maybe this is a hobby and everyone is here because they love VW's. I remember a time when everyone got on in the VW scene, before the internet.
The fact is I didn't buy it to flip, as Hazetguy intimates in his post. I bought it after months of thinking about it (it was on here long enough) and planned to get it on the road. I am not selling it for profit, or because I found a lot of nastiness (I was actually pleasantly surprised when this bus arrived).
Put simply, I am trying to build up my business and realized this would take up a lot of my time that I could be spending working on customers cars, or home with my wife, who has been pretty ill the last 4 years and my 3 year old son, who we recently found out has Autism related difficulties (he is too young for a positive diagnosis)
I bought the bus for $3000
Shipped it to the UK for £1750 ($3400)
transported it from the shipper £250 ($490) including vehicle hire.
Total $6890 or £3533
I also bought some parts, such as fat base mirror arms, interior handles, etc and did some bodywork. The fact is, as I said, right now what I need is a driver, so I am looking at trades, including a single cab and a 59 Bug currently. I bought the bus last october and personal circumstances change, just remember that next time you decide to judge.
If I wanted to make a killing I could part the bus out ( already have no less than 7 people after the reflectors alone) but I want someone to take over from where I have started and do this bus justice, I am only sorry it won't be me doing it. |
Posted: Thu Jan 31, 2008 11:47 am Post subject: |
i had no other intention in my post other than showing it was for sale. after all the build up and your excitement of getting it, as well as progress pics of the work done so far, i was just pointing out it was for sale, not very long after you got it (less than a month).
things happen, i realize that. _________________ thebucket: I invested in hoodride, now DBD won't return my call?
hazetguy: invested?
