breadloafdeluxe Samba Member
Joined: February 12, 2002 Posts: 418 Location: Birthplace o Tx. Brazoria Co.
Posted: Sun Mar 10, 2002 6:44 am Post subject: Vinyl Cleaners |
Anybody know a vinyl cleaner/restorer that's not slipperie? Thanks DavidK 71Deluxe |
JDogg Samba Member
Posted: Tue Mar 12, 2002 9:04 pm Post subject: Vinyl Cleaners |
Lacquer thinner cleans anything off of vinyl, and instead of a slippery surface, you're left with a permanently sticky surface. Great for keeping you in those factory lowback during hard cornering. Once you get tired of leaving leg hair on your seats, you'll be ditching that bread box for a type 3. Happiness will ensue.
JDogg |
Posted: Wed Mar 13, 2002 6:14 pm Post subject: Vinyl Cleaners |
JDogg thanks for the advice but I think I'll try the Armoral Greasless first. As for the type 3, I'm headin to Cal. tomorrow to check out a 70 S/Cab if that deal dos'nt happen I've got a 67 Fastie to check out so I do'nt go home empty handed, just to cover expences, but after drivin 1400mi.hey I may keep it! DavidK 71Deluxe |
Posted: Thu Mar 14, 2002 6:55 am Post subject: Vinyl Cleaners |
Try Marine Clean from the people who make POR15. I used to use Armorall cleaner, but it doesn't work nearly as well. You can get Marine Clean from RMMW or go direct to www.por15.com. Since this is a concentrated cleaner, you can mix it to the strength you need. No sticky or slippery residue... |
