Santana Samba Member
Joined: March 18, 2008 Posts: 146 Location: T-Town, WA
Posted: Thu May 14, 2009 12:31 am Post subject: |
keithwwalker wrote: |
They only have clear and blue in the high power so far. I ordered 3 blue, but I hope to eventually have a power socket to take the place of my lighter, and have a clear bezel so that the blue light shows through.
Do you know where to get the power socket with a clear bezel? That is exactly what I want to do. I just ordered the gowesty lighter and am not really diggin the amber color. Maybe I could find just the clear bezel? I'll let you know if I find anything. _________________ PHOTO GALLERY |
vwsyncroguy Samba Member
Posted: Thu May 14, 2009 12:39 am Post subject: |
They only have clear and blue in the high power so far. |
Anyone tried the clear bulbs ??
....I have some nice new VDO gauges....black faces w/white letters... just like the original Vanagon gauges....but their lighting is much brighter and the letters and symbols on the gauges actually look WHITE instead of yellow/orange like the lights on the old VW gauges.
I'd like to have some nice bright...as close to neutral color balance as possible....placements....so the original instruments also have bright white letters and symbols......nothing fancy...no colors.
Thx,
Warren C. |
keithwwalker Samba Member
TELEK27 Samba Member
Joined: September 23, 2006 Posts: 85 Location: MONROE NY
Posted: Thu May 14, 2009 5:21 pm Post subject: |
can somebody tell me how to get the bulb holders out I don't want to break them
Thanks _________________ 90 WESTY With a Zetec inside |
sdirghalli Samba Member
Joined: September 19, 2008 Posts: 16 Location: Long Beach, CA
Posted: Sun Oct 18, 2009 10:02 pm Post subject: Festoon for passenger side light above glove box |
I've installed superbright LEDs in the instrument cluster, above the driver's door, and in the light in the camper section of my westy...does anyone know which (if any) of the superbright LED festoons can be used as a replacement for the small light above the glove box in front of the passenger seat??? Thanks. |
syncrodoka Samba Member
Joined: December 27, 2005 Posts: 12006 Location: Santa Cruz, CA
Jamos Samba Member
Joined: July 08, 2005 Posts: 762 Location: Lake Tahoe, CA
Posted: Mon Oct 19, 2009 12:29 am Post subject: |
Maybe I missed it, but is there a good replacement for the flourescent that's in my '86 weekender?
I don't mind it too terribly, but if there's something that uses less power and looks decent, then I'd go for it.
thanks! _________________ '86 Wolfy Westy Weekender
2020 Audi Q5 |
elpedro Samba Member
Joined: April 29, 2009 Posts: 63 Location: Chico, California
Posted: Mon Oct 19, 2009 10:19 am Post subject: |
Jamos wrote: |
I believe this is what you seek: Cold Cathode swap
http://www.thesamba.com/vw/forum/viewtopic.php?t=267794 _________________ ...Peter...
89 Vanagon Bluestar to-be-named
71 hardtop westfalia Brave Little Toaster *sold* |
EL31415 Samba Member
Joined: December 13, 2009 Posts: 192 Location: Los Angeles
badgerb0b Samba Member
Joined: October 30, 2008 Posts: 74 Location: Calgary, AB
Posted: Fri May 14, 2010 12:15 pm Post subject: |
I would like to replace as many interior lights with LEDS that I can but have some unanswered questions.
So as I understand.
The 4 'B8.3D-BHP' for the instrument cluster requires no mods they are direct replacement. Driver's side overhead light no mods, the '4210whp3' - 3 or 6 light will fit but requires soldering to hold it in place.
Are the other locations 'mini wedge 74w' direct replacement or do the require some modding?
Specifically,
Defrost switch
Hazard switch
Also,
Did anyone ever figure out if I need to buy that extra part for the Environmental Controls?
Glove box map light (what size)? |
kamzcab86 Samba Moderator
Posted: Fri May 14, 2010 7:22 pm Post subject: |
Cluster: B8.3D (four of them total, direct plug-and-play)
Courtesy light: 4210 festoon (no soldering needed in mine; fits and stays just fine)
Map light: 3022 festoon
Kitchen light: 4210 festoon _________________ ~Kamz
2016 Golf GTI S
Posted: Fri May 14, 2010 7:25 pm Post subject: |
Quote: |
Did anyone ever figure out if I need to buy that extra part for the Environmental Controls? |
Yes, you need to buy the bulb holder unless your OG unit has a removeable bulb. I have only ever seen 1 piece units that the bulb isn't replaceable. |
Posted: Sun May 16, 2010 2:59 pm Post subject: |
Specifically,
Defrost switch
Hazard switch |
I had the dash out today to install a VSS for my conversion and I checked this out.
The defrost switch doesn't have a exterior bulb, it is integrated into the switch.
The hazard switch has a exterior bulb, but it isn't replaceable and it is diferent than any other bulb holder that I have seen in the van so modding it isn't possible(or easy I should say)
I figure that I should update this since I was the one that said the 74W would work in the hazard position. I should have checked more thoroughly. |
ANGOVAY Samba Member
Posted: Tue May 18, 2010 2:53 pm Post subject: |
ANGOVAY wrote: |
Here's a pic of the std light in the middle and the LEDs on each side. Much brighter.
Is that some sort of mod? I thought the rear lights were the long florescent ones but it looks like you have 3 festoons in there. |
firepilot Samba Member
Posted: Tue May 18, 2010 3:07 pm Post subject: |
I certainly do not have any flourescent bulbs in my 86 Westy, its 3 small incandescent bulbs in that. _________________ 86 Westy Syncro |
Posted: Tue May 18, 2010 5:50 pm Post subject: |
Yeah, that is why I thought my rear light was florescent but I just checked and I have the 3 spots for the incandescent bulbs. Nice!
Maybe just Weekenders are florescent? |
Posted: Tue May 18, 2010 9:02 pm Post subject: |
Must be a model year thing. I have a 1990. _________________ Mark
90 Westy 1.8T Sold
2016 Sprinter Field Van |
saxon9598 Samba Member
