keithwwalker Samba Member
Posted: Thu Apr 10, 2008 10:43 pm Post subject: |
Well SUCCESS, the B8.3D instrument LEDs SuperbrightLEDS are a direct fit!
The only snafus were that the electrical leads had to be bent upwards a little with tweezers to ensure good contact. Luckily the leads are malleable.
They are also directional, so if they don't work one way, they have to be rotated 180 degrees to reverse polariztion.
Compared to another blue LED that was done by a chap in England, the superbright's are more of a paler shade (left). See photo
another view:
I also installed the rear side markers, the dome light and the cigarette lighter.
I am not too satisfied with the rear side markers (BA9s), they don't diffuse the light too much. But then again the specs said 32 degree angle. In the future I may consider the 90 or 180 LED's
The dome light is much brighter, but the rocker switch actually moves the bulb back and forth, and enough switching will rotate the led array out of alignment. Another bugger is that my retaining clip bounced off and is now inside the upper rail, and a second one as well....
larrytrk Samba Member
Joined: July 22, 2007 Posts: 377 Location: Central NJ & MA
Posted: Fri Apr 11, 2008 4:30 am Post subject: |
Any problems with dimming the LEDs? _________________ It's all in your mind.
I Hate BAMBI!
87 Westy full camper "Bluie" aka-"busturd"
JUST SOLD HER, WESTYLESS!
Good by cruel world! |
Posted: Fri Apr 11, 2008 9:10 am Post subject: |
They advertise as fully dimmable, but my headlight dimmer wheel only turns a 1/4 turn. Even the incandescent lamps don't dim fully.
That said, the superbright LEDs do dim, I would reckon 1/3 their intensity. That is enough for me, especially in the blue and red colors. |
Jamos Samba Member
Joined: July 08, 2005 Posts: 762 Location: Lake Tahoe, CA
Posted: Fri Apr 11, 2008 9:57 pm Post subject: |
I just ordered 5 blue, and 2 ambers from superbrightleds...
thanks very much for the link and for the assurance that these do indeed work well.
I figure I'll go for an amber in the clock, and blues for the rest.
I remember I was messing with this about 4 years ago before LED's were quite as widespread (esp in auto applications), and I was soldering resistors to fit inside the little black plastic housings and it was a bitch.
Very happy to give these guys $15 and have a drop-in solution. _________________ '86 Wolfy Westy Weekender
2020 Audi Q5 |
Raynor Shine Samba Member
Posted: Tue Apr 15, 2008 4:24 pm Post subject: |
Keith- I am getting rady to order these, thanks for the write -up. can you tell me which one is for the cigarette lighter. Also would which one would be for the clock.
Thanks |
ProvoCyclist Samba Member
Joined: December 07, 2004 Posts: 593 Location: Murray, Utah
Posted: Wed Apr 16, 2008 6:34 am Post subject: |
I just swapped put all my dash lights, 3 blues, 1 red (in the clock). I found the red to be too dim in there, i may swap it for the blue in the idiot light symbols and see how i like it.
Other than that, im friggin happy with how it turned out!
Oh yeah, i ordered 3 new domelights yesterday. _________________ Clark
Current: 1986 Tintop GL 2wd, stock 2.1L, manual trans, Flash Silver LP7Y.
Past: 1985 Sunroof GL, 2wd, Subaru 3.3L, manual trans, resprayed to Diamond Silver L97A |
Posted: Fri May 16, 2008 11:37 pm Post subject: |
I just made the connection that the blue superbrightleds.com are the same shade as the blue high beam light. They are not as dark as the usual blue leds... |
Steelhead Samba Member
Joined: February 25, 2007 Posts: 1791 Location: Kentfield, CA
Posted: Tue Jan 06, 2009 12:41 am Post subject: |
Has anyone found a direct LED swap (or close) for the light socket behind the environmental controls (heater panel)? Or is it the same base as those in the instrument cluster? What about the fan switches...are they the same base as the heater panel? thanks _________________ '77 Bay Window / '89 Caratsburg (aka. the Stormtrooper) |
Posted: Tue Jan 06, 2009 5:52 am Post subject: |
The environmental & lighter bezel lights are special OSRAM light/housings. To fit an LED, you would have to use the OSRAM housing and leads & solder an LED bulb to it. I started this project, but not finished it.
Steelhead wrote: |
Has anyone found a direct LED swap (or close) for the light socket behind the environmental controls (heater panel)? Or is it the same base as those in the instrument cluster? What about the fan switches...are they the same base as the heater panel? thanks |
Robw_z Samba Member
Posted: Tue Jan 06, 2009 6:47 am Post subject: |
keithwwalker wrote: |
So what is the verdict on using the LED's in the dome light? This mod is what I am most interested in, I would love more interior light, but if it isn't going to work...?
-Rob |
a914622 Samba Member
Joined: July 29, 2004 Posts: 840 Location: Westend of HWY2 , Wash
Posted: Tue Jan 06, 2009 9:09 am Post subject: |
Robw_z wrote: |
-Rob |
I have added/switched the back lights over to this 6 led light. WOOOOW!
Great upgrade!! I would get a 3 led one for right above the drivers seat. 6 led might be a little bright.(yes its that bright) I went with a Blue above the drivers seat. A must do for any vw.
And as a side note to how good Superbrite leds is to work with, After seeing them is the vanagon, friend ordered 14 of this exact light for his sail boat. Turned out the size was 37mm. They exchanged all of them no problems.
jcl |
syncrodoka Samba Member
Joined: December 27, 2005 Posts: 12008 Location: Santa Cruz, CA
Posted: Tue Jan 06, 2009 4:44 pm Post subject: |
I installed the 3 high power led's in my dome lights (added one to the passenger side- hole is already there) and they are much brighter than the stock bulbs. I could not imagine how bright two of the 6 led lights would be. I checked that it worked and then soldered the fixed side of the bulb(not the side that goes to the switch) to the holder. This little mod keeps the led arrangement from turning in the holder. Thanks keithwwalker for doing the homework and posting the links. |
joetiger Samba Member
Joined: January 27, 2005 Posts: 5078 Location: denver
Posted: Mon Jan 12, 2009 7:12 am Post subject: |
Yes, the freak blizzard this morning made the drive to work terrible, but I kept looking down at my cluster thinking, 'that looks SO COOL."
Thanks for all of the posts on this. I ordered the bulbs from superbrightleds.com on Tuesday, they got to me Friday, installed yesterday. Outstanding! _________________ Joe T.
'04 GTI 1.8T
'04 Golf R32
Available Now! Vanagon to Louisiana--A Two-Lane Reckoning Through Past and Present
www.josephtrussell.com |
Posted: Thu Feb 12, 2009 1:08 am Post subject: |
I was able to find a holder for a led bulb from volkscafe that will fit behind the heater controls. The holder takes the same size replaceble bayonette bulb as the cig. lighter and emergency switch. The holder fit a little too tight into the heater control bezel so I sanded it a little to fit better.
The LED that I bought from superbrightleds.com is a #74 bulb and it the same dimensions as the original bulb for the bolder. There are different lumen rated bulbs and I would buy a brighter one next time because this is a little dim for my taste.
The holder for the bulb is white and not black like the original holder so light transfers through the body and it is a little annoying so I will paint it with some black plasti dip paint that i have around. I am happy with the results but i have noticed that the dimmer does not work as well with all of the dash bulbs converted to LEDS. I never dim my cluster so it isn't a issue for me. I didn't go for any fancy colors, I stayed with white which I really like. I bought red, blue, green and white and I could see the cluster and clock the easiest with white. It is nice to get rid of the yellow tint of the old bulbs and the LEDS throw a pretty good white. All of my bulbs have been converted to leds including the locker controls
Posted: Thu Feb 12, 2009 10:44 am Post subject: |
Where on the site are those bulb holders, and how many did you get? Your setup looks really sharp now! _________________ Clark
Posted: Thu Feb 12, 2009 8:42 pm Post subject: |
I actually walked in and asked for the part and that is what they gave me. They don't have the part in the online store as far as I can tell. GoWesty has the part for about $5
http://www.gowesty.com/ec_view_details.php?id=3587&search_phrase=bulb&start=
They are found in the rabbit/golf convertibles '79-'93, early jettas through '84 and all sciroccos as well if someone wanted to get the part through the auto wreckers. $5 for a new part is a lot easier than digging through a junk yard though. |
danfromsyr Samba Member
Posted: Thu Feb 12, 2009 8:50 pm Post subject: |
syncrodoka, nice illuminated headlight switch, and I thought I was the only one modding them with translucent watercooled switches.
I wired mine to a constant + with a green LED, so i can find it easiest when I get in the van. there's a always hot on the light switch itself.
nice LED work _________________
Abscate wrote: |
Jamos Samba Member
Posted: Thu Feb 12, 2009 9:27 pm Post subject: |
danfromsyr wrote: |
nice LED work |
So your green LED is on 24/7? _________________ '86 Wolfy Westy Weekender
2020 Audi Q5 |
