71 Wheels 14 's or 15's
Mikes 71Bay
Mikes 71Bay is offline
PostPosted: Thu May 09, 2002 12:38 pm    Post subject: 71 Wheels 14 's or 15's Reply with quote
I looking at a set of porsche rims for my 71 but I'm not sure if i should go with the 14's or 15's ??? Will the 15's change my speedo much? Will they hit the wheelwells?
Karl
Karl is offline
PostPosted: Thu May 09, 2002 9:09 pm    Post subject: 71 Wheels 14 's or 15's Reply with quote
VW bus wheels have a bolt pattern of 5 x 112.
Only VW buses, Mercedes, and Audi Turbo use this size. Not Porsche.....they are 5 x 130. And even if you figured a way to bolt them on, the offset is all wrong. Bus is an ET of 35. Porsche are either 25 or 45.
Mikes 71Bay
PostPosted: Sat May 11, 2002 3:44 pm    Post subject: 71 Wheels 14 's or 15's Reply with quote
I'm a little out of my relm. Can't I have the rotors and drums drill and tapped to fit the porsche rims? Thanks Mike
breadloafdeluxe
breadloafdeluxe is offline
PostPosted: Sun May 12, 2002 7:25 am    Post subject: 71 Wheels 14 's or 15's Reply with quote
If you go w/ the 15s,yes the speedo will be off about 10mi @ 60mi.hr. Empi makes adapters for the Porsche 5 spokes to convert VW 120 to Porsce 130, a little pricie at $80 bucks a pair. Repo center caps run $35 a pop.You can get the Drums and Roters tapped for 130mm price no idea. If you stick to a 5.5 width you won't have a prob. w/ the back space. Check CIP.com for $ and info.Hope this helps,DavidK 71Deluxe,69S/Cab
