34dan Samba Member
Posted: Fri Jan 11, 2008 10:42 am Post subject: Cab divider bolts |
does anyone know the size of the bolts that mount the divider to the bulkhead?
thanks,
dan |
campingbox Samba Member
Joined: November 14, 2000 Posts: 10196 Location: Petaluma, CA
Posted: Fri Jan 11, 2008 11:03 am Post subject: Re: CAB DIVIDER BOLTS..... |
dgtherock wrote: |
thanks,
dan |
M6X1.0, 10mm hex head. |
34dan Samba Member
Posted: Fri Jan 11, 2008 11:21 am Post subject: |
thank you!! |
Jerry Samba Member
Posted: Sat May 09, 2020 1:56 pm Post subject: Re: Cab divider bolts |
Can someone post a couple of detailed pics of how the cab divider is attached at the top & the driver’s side of the van?
I have an “L” channel only on the passenger side B-pillar as of now.
There must’ve been an overzealous hippie needing to remove it for installing God knows what.
Thank you 👍🏼 _________________ Looking for SO34 parts.
thevwcompound *instagram* |
Dustin B Samba Member
Joined: March 29, 2007 Posts: 1017 Location: hesperia, Ca USA
Posted: Sat May 09, 2020 5:05 pm Post subject: Re: Cab divider bolts |
If someone doesn't beat me to it I'll post some pictures in a couple hours when I'm near my bus. Rondusty _________________ Wanted Victoria motors licence plate frame.
62 og paint L469 type 1
61 og paint L31 DD panel type 2
64 heilite viscount tent trailer
71 sears clamshell trailer
I <3 Brazilian busses
Original paint and patina extravaganza http://www.thesamba.com/vw/forum/viewtopic.php?t=187156 |
Posted: Sun May 10, 2020 12:51 am Post subject: Re: Cab divider bolts |
Hope this helps Jerry.
Jerry Samba Member
Posted: Mon May 11, 2020 12:54 pm Post subject: Re: Cab divider bolts |
Rondusty’s pics are enough for me to go off of I think.
Please tell Clara a friend sent the 5 Kamax bolts for the bulkhead I needed, when I bought the divider from her, she thought she may have extra, please tell her thank you. The panel she sent is amazing quality.
So, there’s a u channel at the bottom as well as the pillars & top? _________________ Looking for SO34 parts.
Clara Samba Member
Posted: Tue May 12, 2020 10:58 am Post subject: Re: Cab divider bolts |
Jerry wrote: |
So, there’s a u channel at the bottom as well as the pillars & top? |
Thanks!
No U channel at the bottom.
Just put the cab divider pretty much in place but a half inch low,
then lift up so the divider is in the channels at top and sides,
then install the five bolts with big washers.
Actually, first make sure the five threaded inserts have nice threads so the bolts thread in easily by hand. You may want to chase them with a tap, and use a little anti-seize or grease on the threads.
some pics of cab dividers/dolts:
Hausmann's Meats Panel:
see slot on B pillar for cab divider:
bolt holes visible here:
We sold the panelbuses just before the move, so I can't take more pics right now. I think I have some pics of the Acme panel, but not sure where. |
BulliBill Samba Member
Joined: July 09, 2004 Posts: 4572 Location: St Charles, MO
Posted: Wed May 13, 2020 7:06 am Post subject: Re: Cab divider bolts |
I wish someone would find an NOS box full of those weird-shaped thick foam sculpted NOS foam seals for the upper right and left corners of the divider where the divider meets the inner body "gutter". You know what I mean? They are almost always missing or deteriorated on dividers. I've got a nice used one of one side or the other stored away somewhere, but there is a definite L & R side. I don't think anyone has ever reproduced it for us poor Panel lovers who want to get every detail right! I eventually found a similar thickness sheet of similar grey closed cell foam and using my one used seal, I cut and carved out fairly close reproductions for my '59 SS Panel. But one day I'll see some in someones swap booth and dive on 'em!
Bill Bowman _________________ I'm looking for these license plate frames for my fleet:
Mission VW - San Fernando
Thornton VW - Stockton
Thanks for any help! |
Clara Samba Member
Posted: Wed May 13, 2020 9:05 am Post subject: Re: Cab divider bolts |
BulliBill wrote: |
Bill Bowman |
I've heard of people carving them out of foam, but they are fussy and I have not gone there.
Yes, there are left and right, mirror images.
here is a thread about cab divider foam wedges:
https://www.thesamba.com/vw/forum/viewtopic.php?t=373463&highlight=cab+divider+foam |
Clara Samba Member
Posted: Thu May 14, 2020 1:52 pm Post subject: Re: Cab divider bolts |
Acme Panel:
1956
