Andy Samba Member
Posted: Fri Jun 07, 2002 9:11 am Post subject: fuel pump (help) |
My 1978 Westfalia .I have never seen this problem before. How can I fix it? It appears that my fuel pump is always running, even with the key turned off. The only way I have found to turn it off is by pulling the battery cable off. When I try to start it, it is flooded although I have managed to get it running by hooking a battery charger to it for a little extra kick and cranking the heck out of it. After it started, it ran fine. After I shut it off, I couldn't start it again and the fuel pump kept running. I need help quick, I am planning a trip in this thing |
keifernet Samba Search & Rescue
Joined: May 11, 2002 Posts: 19395 Location: Samba Center for Behavioral Science
Posted: Fri Jun 07, 2002 10:46 pm Post subject: fuel pump (help) |
Sounds like it could be a stuck or defective double relay...., should be on the eginge compt firewall left side???? |
dstefun Samba Member
Joined: February 20, 2002 Posts: 3338 Location: Sacratomato
Posted: Fri Jun 07, 2002 11:01 pm Post subject: fuel pump (help) |
As I understand it, the fuel pump is controlled by a double relay which is controlled by the computer. The computer gets its signal from the air flow meter, which must be open (engine getting air) for the pump to work.
So you could have a stuck relay or an air flow meter stuck open, or a bad computer.
Good luck! The VW F.I. workshop manual is at http://www.conservatory.com/vw/manuals_nyx/L-Jetronic.html
I think one test you could do would be to disconnect the battery (DO THIS FIRST!), pull the big plug off the computer and then connect the battery. If the pump still comes on without the computer even connected, it almost has to be a stuck relay. (The other side of the relay fuel pump connection goes direct to battery +.)
NEVER connect or disconnect the computer without disconnecting the battery first or you run the chance of blowing the computer. |
