type2much Samba Member
Joined: November 13, 2003 Posts: 319 Location: 65536 Missouri
Posted: Mon Jan 14, 2008 4:32 pm Post subject: Screw terminal wire caps |
does McMaster-Carr sell the end caps (or maybe they are called ferrules?) for screw terminal connections on a 60 bus? If so does somebody know the part number?
or who sells them?
thanks! |
Posted: Mon Jan 14, 2008 5:58 pm Post subject: |
this is what I mean
j.pickens Samba Member
Joined: December 03, 2002 Posts: 9791 Location: Exit 7, New Jersey
Posted: Mon Jan 14, 2008 7:02 pm Post subject: |
Try Newark Electronics or Mouser.com _________________ Founder and Chairman Emeritus, ECMSAS
BeaterBarndoor wrote: |
i wish more people would actually drive their vws rather than just talking about what they have in the garage. |
Red Fau Veh wrote: |
If you've seen one sunroof swivel seat kombi, you've seen them all! |
Campy Samba Member
Joined: January 10, 2005 Posts: 4933 Location: Chico, CA
Posted: Tue Jan 15, 2008 4:27 pm Post subject: |
They look like the aluminum pieces that get crimped on the end of a bicycle's brake cable that you can get for almost nothing at a bike store. _________________ Don't worry; be happy. (Baba) |
busdaddy Samba Member
Posted: Tue Jan 15, 2008 4:43 pm Post subject: |
Shoelace eyelets look like that before crimping.
If all else fails hit your local hobby shop for some 1/8" brass tube (gas powered model airplanes) and an exacto saw and cut your own, if your'e real crafty you could figure out how to flare the ends too. _________________ Rust NEVER sleeps and stock never goes out of style.
Слава Україні! |
codeMechanic Samba Member
Joined: April 13, 2007 Posts: 876 Location: Bellevue , NE
Posted: Tue Jan 15, 2008 5:10 pm Post subject: |
Campy wrote: |
They look like the aluminum pieces that get crimped on the end of a bicycle's brake cable that you can get for almost nothing at a bike store. |
aluminum is not good for conductivity. |
Stocknazi Samba Member
Posted: Tue Jan 15, 2008 5:35 pm Post subject: |
alunimum is a great conductor of electrictity; however, it will corrode easier than brass/copper. dielectric grease would help that.
i was going to melt a little solder to the ends of my broken wires, but some of the crimp on ferrels would be awesome. _________________ WANTED:
"Resistance to tyrants is obedience to God."
Thomas Jefferson |
Posted: Tue Jan 15, 2008 6:00 pm Post subject: |
They're plated copper, and they are available at Mouser.com _________________ Founder and Chairman Emeritus, ECMSAS
cdennisg Samba Member
Joined: November 02, 2004 Posts: 20278 Location: Sandpoint, ID
Posted: Tue Jan 15, 2008 9:47 pm Post subject: |
FWIW the eyelets on a shoelace are called aglets. _________________ nothing |
Rain's Westy Samba Member
Posted: Wed Jan 16, 2008 12:57 am Post subject: |
this is a good topic ...I need to spruce up
the OG wiring in the engine compartment of my 56 and this is what I need to do it good to know where to get these little things!... COOL! |
dstefun Samba Member
Joined: February 20, 2002 Posts: 3338 Location: Sacratomato
Posted: Wed Jan 16, 2008 2:45 am Post subject: |
type2much wrote: |
this is what I mean
This Digi-Key ferrule is available from digikey.com for about 7 cents each in 100 quantity. They charge an extra $5 handling fee if your order is under $25. The ferrules are available for wire sizes 14-16-18-20 AWG, 0.5-2.5 mm2, so you can have 6 different size ferrules depending on wire size and ferrule length.
Mouser has Phoenix Contact ferrules that are similar but they are around 11 cents each in 100 quantity, and they do not charge extra for orders under $25.
Newark has a $25 minimum order, period. I try not to go there. In 18 AWG ferrules they list a minimum package order of 1000 for $41. It's really the best price at 4 cents each but that would certainly last you and all of your friends for a bus or 2.
And yes, McMaster has them too, for the next best price, and 29 different sizes....
# 9681K56 Non-Insulated Crimp-on Wire Ferrule 18 Awg, .47" length, $5.77 for a box of 100. |
Posted: Wed Jan 16, 2008 5:06 am Post subject: |
thanks for all the good info. Is 18 guage the right size for most of the bus wires? |
Posted: Wed Jan 16, 2008 11:09 am Post subject: |
type2much wrote: |
thanks for all the good info. Is 18 gauge the right size for most of the bus wires? |
I only picked 18 gauge in my post above to be consistent with your digi-key picture above that. There are obviously many different wire sizes in a bus. You can look on the wiring diagrams (here or at vintagebus.com) and the little numbers next to the wires are the wire sizes in mm2.
Looking at a 59 bus diagram, wire sizes are all over the place - like the 4 wires going back to the tail lights are 2 @ 0.75 mm2 (20AWG) and 2 @ 1.5 mm2 (16AWG). The light switch has 7 wires - 3 @ 0.5 (22AWG), 1 @ 1.5(16AWG), 1 @ 2.5(14AWG), & 2 @ 4.0(12AWG).
I've never had a screw terminal bus so I don't know how the early harnesses are made. Do they have a separate ferrule on each wire, or are several wires crimped and soldered together in a larger ferrule when they need to be?
Conversions to AWG are only approximate:
0.5 mm2 = 22 AWG
0.75 mm2 = 20 AWG
1.0 mm2 = 18 AWG
1.5 mm2 = 16 AWG
2.5 mm2 = 14 AWG
4.0 mm2 = 12 AWG
6.0 mm2 = 10 AWG |
Posted: Wed Jan 16, 2008 5:04 pm Post subject: |
This is not my bus but it has the the same screw terminal wiring. My wiring was attacked by the hack monster, I am sorting it out using the bently manual and pictures like this one. Most of the wires each have their own ferrule, a few are crimped together in the same ferrule.[/quote] |
Posted: Wed Jan 16, 2008 6:28 pm Post subject: |
the wire diagrams in the technical section are much more helpful than the ones in the bently. i like to put them on a floppy disk and have the local kinkos/office depot enlarge and print them. laminate them to keep them clean. i don't understand why bently did not publish the diagrams in color in the reprint manuels. _________________ WANTED:
Thomas Jefferson |
BulliBill Samba Member
Joined: July 09, 2004 Posts: 4573 Location: St Charles, MO
Posted: Mon Nov 18, 2013 9:33 am Post subject: |
Okie-Dokie! Time to re-open this old thread about connector ends...
I'm about to go through the hell of converting a Wire Works later spade connector harness for a 1959-63 Type 2 to a "screw-terminal" style harness for a 6 volt 1959 Bus. We just pulled the old original wire harness yesterday and pulled the new Wiring Works harness from rear through the chassis and into the front cab and to the fuse box. When I purchased this new harness (many years ago) from Bob at a SOTO show, the harness came with later-style spade connectors, getting one with screw-terminal connectors wasn't an option. My question is: Has anyone else done this before? Cut off the spade connectors and successfully attached screw connector brass ends onto the bare wire ends? My hope is to try to duplicate the look and function of the original connection ends as much as possible/practical.
If so, what was your process? Do you solder the bare wires first and then slip on "purchased" connector ends. Do you crimp or solder the ends to the wire? If crimped, any particular crimper tool needed? Can you describe and/or provide any photos the process for all of us amateur VW electricians? I'm assuming that it might be a good idea to put a little dielectric grease on the connector during assembly to halt future corrosion. Fill us in on any of the hazards and tips about doing this if you can. Thanks in advance for sharing any of your experience and expertise!
Bill _________________ I'm looking for these license plate frames for my fleet:
Mission VW - San Fernando
Thornton VW - Stockton
Thanks for any help! |
RPGreg2600 Samba Member
Joined: November 07, 2010 Posts: 1657 Location: Vallejo, CA
Posted: Mon Nov 18, 2013 10:21 am Post subject: |
If you're not too picky, you can cut all the spade ends off of the terminals on your new harness leaving just the part that is crimped over the wire end. This part will fit right into the screw terminal holes. It will look just fine but not quite like original. A hell of a lot easier/cheaper though! |
Ian Samba Moderator
Posted: Mon Nov 18, 2013 12:28 pm Post subject: |
My recommendation is to cut the spades off, strip a little wire, and solder the end. Then stick the soldered end in your screw-terminal connection. I prefer this method as the solder is really soft and the screw terminals get a great bite into the end of the wire.
Never seen those ferrules for sale around these parts....must be a geographical oddity.... _________________ All your Buses are belong to us.
Love and good roads!
IN LOVING MEMORY OF ROB CRESS 1968-2012
**ACHTUNG DO NOT USE AA BRAND PRODUCTS OR BUY ANYTHING FROM PACIFIC PARTS INTERNATIONAL IN CALIFORNIA** |
Posted: Mon Nov 18, 2013 3:34 pm Post subject: |
I wish I had the time or patience to use the ferrules, but I just cut, stripped, tinned with solder, and installed. Seems to have worked OK. The right and left front turn signal wires are too short when you cut the ends off the wiring works harness, they fit, but are strung kind of tight. The only other problem was figuring out what to discard from the emergency flasher harness to an earlier harness. _________________ Founder and Chairman Emeritus, ECMSAS
Posted: Mon Nov 18, 2013 5:31 pm Post subject: |
i cleaned up an og wiring harness for my bus; cutting off a small piece and dabbing a little solder on; worked really well; solder your fusebox and headlight switch at the same time if you have not done so already
the t/s wires were super short on my og harness as well. barely made it on the p/s
screw terminal wiring is so much easier to clean up vs the spade terminals
parts are harder to find though _________________ WANTED:
Thomas Jefferson |
