fanbelt Samba Member
Joined: July 02, 2007 Posts: 19 Location: Sanford Florida
Posted: Tue Jan 15, 2008 10:12 am Post subject: Seat frame color? |
Anyone know or have a color code for 57 seat frames? Looks like its a off white color. Super dirty and faded so kind of hard to tell.
Thanks |
djkeev Samba Moderator
Joined: September 30, 2007 Posts: 32625 Location: Reading Pennsylvania
icemanhd Samba Member
Joined: May 07, 2007 Posts: 275 Location: Camano Island, WA
Posted: Tue Jan 15, 2008 10:32 am Post subject: |
Should be the L75 Beige, wolfsburgwest sells it but there is a Krylon rattle can color (Almond) that is real close you can get at Wal Mart or wherever. I just repainted my steering column, column bracket, and turn signal lever housing in the Krylon almond and it looks much better since the PO had painted them RED.
http://www.wolfsburgwest.com/cart/DetailsList.cfm?ID=PAINTL75 _________________ 71 Drag Ghia
67 Bug, Hot VWs feature car
68 912
76 912E
87 911 Carrera |
johnshenry Samba Member
Joined: September 21, 2001 Posts: 9364 Location: Northwood, NH USA
Posted: Tue Jan 15, 2008 11:41 am Post subject: |
Thanks for the kind words djkeev, but since I wrote that article, I have learned that the L75 may not be correct. It is very close however.
Rustoleum "Almond" is a dead on for the ivory color, but that paint (and the WW rattelcan Lacquers) are not all that durable. A single stage urethane would be much better for things like seat frames. _________________ John Henry
'57 Deluxe
'56 Single Cab |
Posted: Tue Jan 15, 2008 11:47 am Post subject: |
After painting my column, bracket, and turn signal housing with a rattle can I ended up taking my seat frames to a local metal fab/powdercoating place. One of the seat lock handles had broken off the seat and needed to be welded anyway so I stopped by for a quote on the welding and powdercoating. It was more and less than I expected...
I had already ground the shaft flat on the handle where it butts up to the locking plate and indexed it by cutting a groove in the center to help hold the handle against the lock plate when they welded it so the clocking would be correct. Anyway, they quoted $30 to weld the handle (which sounded a little high) but only $40 each to blast and powdercoat my seat frames. They had a stocked almond color that matched up to the rattle can nicely and I thought $80 for both seats was more than fair.
Consider getting them powdercoated! _________________ 71 Drag Ghia
68 912
76 912E
87 911 Carrera |
