flipped tie rods
trndstter002
trndstter002 is offline
PostPosted: Wed Jan 16, 2008 6:22 pm    Post subject: flipped tie rods Reply with quote
new to the slammed look have a 67 with a shortened 6" beam read in a couple of threads about people flipping them can somebody please explain the benefit to doing this.
HERC
HERC is offline
PostPosted: Wed Jan 16, 2008 9:03 pm    Post subject: Reply with quote
When lowering the front, the tie rods become excessively angled, the drivers side(long rod)comes very close to hitting the gas tank (depending on how low you've gone)
Flipping them helps to correct the geometry by repositioning them to a straighter plane and allowing ample travel between the long rod and the tank
Herc
FireBug1966
FireBug1966 is offline
PostPosted: Wed Jan 16, 2008 9:07 pm    Post subject: Reply with quote
What exactly is involved? Is new hardware required? The tie-rod to spindle is a tapered fit...right? You can't just "flip it", can you?
Anyone have a pic?
DEFLATED
DEFLATED is offline
PostPosted: Wed Jan 16, 2008 9:51 pm    Post subject: Reply with quote
buy the sleeve kit about $20.00. yes, its tapered... You need a new 5/8 drill bit maybe 2 of them about $15.00 each... just a tip, you can do this still on the car using a 1/2 electric drill with a 5/8 bit; use water as you drill to keep the tip cool and stay as staright as possible in line when drilling...its a tight fit. If you hole gets a little sloppy use shims such as a feeler gauge to make the slleve fit tight..In a nut shell -drill out the eye on the spindle, place the sleeves (kit) in from the bottom...Then (flip) your tie rod end into the spindle from the bottom. Done
HERC
HERC is offline
PostPosted: Thu Jan 17, 2008 5:21 am    Post subject: Reply with quote
Or............Just do what I did for free
Taper the underside with a dremel or chamfered bit..
It doesn't take much, so just do a little at a time and keep checking fit with the tie rod end..
I had the dremel set on low speed and never generated any more heat than a hot So. Cal summer day Cool
Herc
FireBug1966
PostPosted: Thu Jan 17, 2008 5:22 am    Post subject: Reply with quote
Okay, that makes sense. Thanks for the info.
