a914622 Samba Member
Joined: July 29, 2004 Posts: 840 Location: Westend of HWY2 , Wash
Posted: Wed Sep 30, 2009 2:24 pm Post subject: |
Ya I had the "VANAGON H4s" and thought the improvement over the =black-hole us spec lights = was not worth the 450.00 they sell for over here in the states. This thread was all about putting in a US spec sealed beams or the H4-sealed beams with the flat face.
For reference look at the pic gallery. Find a good pic of the front of a US spec vanagon. The lights have a dark spot in the middle. When you add light form a bulb the dark spot intensifies until the light is being sucked IN like a mini black-hole. ( I may have exaggerated a little??? )
jcl _________________ 87 gl powerd buy 2.5subaru
75 914 getting 2.2t subaru scratch that SVX subaru |
K58 Samba Member
Joined: July 01, 2006 Posts: 1173 Location: Santa Barbara
Posted: Wed Sep 30, 2009 9:56 pm Post subject: |
I'm still planning to retrofit projectors in the Westy like I did with my Jeep
I'll use the same headlights from an Infinity FX45
here's a couple pics of the Jeep
allsierra123 Samba Member
Joined: August 19, 2006 Posts: 1462 Location: Tecate, Baja California MX
Posted: Thu Oct 01, 2009 4:48 am Post subject: |
Nice eventually I will be swapping my H4 hella's out for some HID's. _________________ 95 GMC Yukon 6.5 TD 2 Door Tow pig/ Daily driver.
91 Vanagon GL. 1.9TD Conversion Sold
81 Vw rabbit 1.6 Diesel. Sold |
I am Wildcat Samba Member
Joined: February 03, 2011 Posts: 318 Location: SF Bay Area
Posted: Wed Mar 30, 2011 11:31 am Post subject: |
K58 wrote: |
Did you ever end up installing these lights in your van? _________________ No more van. Wildcat has a new home.
1997 Land Rover Defender 90
2005 MB SL55 AMG
2014 Tesla Model S P85+ |
K58 Samba Member
Posted: Mon Apr 23, 2012 12:24 am Post subject: |
Well after many months I've finally got some progress on my retrofit of hid projectors in the Westy. I wired the harness today and test fired so here's some teaser shots. More to follow.
r.e.wing_fc3s Samba Member
Joined: April 16, 2010 Posts: 591 Location: Vanagon Capitol USA: Bellingham, WA
Posted: Mon Apr 23, 2012 12:28 am Post subject: |
do want _________________ Reference Automotive: NW Washingtons Vanagon Specialist. (360)366-6965. referenceautomotive.com |
Orbitald Samba Member
Joined: August 12, 2004 Posts: 320 Location: Oakland, CA
Posted: Wed Jul 03, 2013 3:08 pm Post subject: |
FYI I found these Ford headlight adjusters on ebay. They look like they might work.
http://www.ebay.com/itm/Ford-Torino-Ranchero-Galax...mp;vxp=mtr _________________ '87 Syncro Westfakia, 1.9TD ADE (AAZish), 068 Injection Pump, K03 turbo, 2.5" exhaust, Mercedes nozzles, SAAB Blackstone charge-cooler w/ 800cfm fan, Micro-1000 EGT sensor pre-turbo, boost at about 13psi, 235/70/16 with stock gearing |
K58 Samba Member
Posted: Wed Jul 03, 2013 3:55 pm Post subject: |
Whatever you do not buy those adjusters! I bought a similar style and had to replace them. The adjusters from the auto parts stores work just fine and are much sturdier. _________________ Westy HID Projector Retrofit |
VanaConn Samba Member
Joined: August 15, 2004 Posts: 64 Location: Cochranville PA 19330
syncrogreg Samba Member
Joined: November 08, 2009 Posts: 742 Location: USA (Nashville TN)
Posted: Sat Nov 04, 2017 11:23 am Post subject: Re: H4 lights in a vanagon |
I have been melting a few relays. From bus depot... As well as harnesses. So now I'm building my own high output relay 70AMP and thick gage wires. Also the weak part was the bulb socket I need to source a material that doesn't melt like that.
Or do I have something wrong in my harness where the bulb would overheat? _________________ conversions: www.boxeer.com Common rail TDI and NOW PDK transmissions!!
travel pictures:
http://instagram.com/crepeattack/
- the Pastis build: http://www.thesamba.com/vw/forum/viewtopic.php?t=434656&highlight=subaru+diesel |
Zeitgeist 13 Samba Member
Posted: Sat Nov 04, 2017 12:18 pm Post subject: Re: H4 lights in a vanagon |
It would be nice if we could source some ceramic bulb sockets _________________ Casey--
'01 Weekender --> full camper
y u rune klassik? |
K58 Samba Member
Posted: Sat Nov 04, 2017 5:23 pm Post subject: Re: H4 lights in a vanagon |
VanaConn wrote: |
How are you keeping the 5x7 headlight secure with only two tabs left for the retaining ring on saab buckets ? Ford econoline buckets seem to have slightly different tab locations |
I'm able to use 3 out of 4 on mine and it works just fine.
erste Samba Member
Joined: March 29, 2013 Posts: 1110 Location: San Francisco
Posted: Sat Nov 04, 2017 8:26 pm Post subject: Re: H4 lights in a vanagon |
Zeitgeist 13 wrote: |
It would be nice if we could source some ceramic bulb sockets |
Lots of ceramic H4 connectors on ebay if that's what you're looking for. Easy and cheap to swap. |
syncrodoka Samba Member
Joined: December 27, 2005 Posts: 12007 Location: Santa Cruz, CA
Busdepot Samba Member
Posted: Mon Nov 20, 2017 9:34 pm Post subject: Re: H4 lights in a Vanagon |
We will have brand new square E-code H4 headlight assemblies for '86-91 Vanagons early in 2018. This is brand new aftermarket production and should be in the $325 range for a complete set. I will have more info in a week or two. _________________ - Ron Salmon
The Bus Depot
www.busdepot.com |
shagginwagon83 Samba Member
Joined: February 07, 2016 Posts: 3803 Location: VA/TN
Posted: Tue Nov 21, 2017 6:36 am Post subject: Re: H4 lights in a Vanagon |
Jay Brown is the man. He sold me these bulb sockets, relay kit, and recommended Cibie lenses and Osram Hyper 85/80W h4 bulbs. Wow it is literally night and day difference. I'll post a picture when the van gets rolling again soon _________________ Brandon
Instagram @joannthevan |
raoul mitgong Samba Member
Joined: July 05, 2009 Posts: 1338 Location: Denver, CO
Posted: Tue Nov 21, 2017 9:53 am Post subject: Re: H4 lights in a Vanagon |
Busdepot wrote: |
We will have brand new square E-code H4 headlight assemblies for '86-91 Vanagons early in 2018. This is brand new aftermarket production and should be in the $325 range for a complete set. I will have more info in a week or two. |
GREAT timing! I was about to put my whole square grill/headlight/bucket combo with extra bulbs up for a 6-pack of microbrew. Are these H4 and are there any mechanical modifications required?
-d _________________ 84 Westy with a 2.1 (Groover)
86 Tintop Syncro (Crow)
86 Tintop Syncro to Westy project (Tom Servo)
91 Westy (Only the top 12 inches of this van (a burn victim)) |
gbrandt Samba Member
Posted: Wed Nov 22, 2017 10:40 am Post subject: Re: H4 lights in a Vanagon |
Are the campervanculture right hand drive? Therefor blinding drivers in the US?
