purplepeopleeater Samba Member
Joined: July 23, 2005 Posts: 3117 Location: E. Washington
Posted: Fri Dec 09, 2011 9:20 am Post subject: |
Looks beefy, and looks like both our driveshafts will be fun to find u-joints for too. |
insyncro Banned
Posted: Fri Dec 09, 2011 9:23 am Post subject: |
Thanks again.
As of late...replacing motor, trans and front diff mounts has been the best way to totally eliminate all vibes.
My next propshaft order will include a GW donutless shaft and I will document how it works. |
ski_bum Samba Member
Joined: January 10, 2012 Posts: 1 Location: Wenatchee, WA
Posted: Tue Jan 10, 2012 3:40 pm Post subject: the-shaft |
I'm new here, and have read through this excellent thread. My syncro started vibrating recently, vehicle speed related. Not any noise like I'm used to with bad bearings, but very bad vibration at 25-35mph, then it clears up until around 45-55mph, then smooth right at 60. I was thinking it was the tires, which have an agressive tread, and perhaps mis-allignment, but it even does it when driving on snow. All c-v joints are newer Lobro. Well, it looks to be the DREADED DRIVESHAFT. (by the way, it has always clanged when engaging the clutch).
I need the AWD to even get in and out of my driveway, so I don't want to take it off to troubleshoot it. I'm thinking about one of the newer splined replacement driveshafts. (Vanagain, GoWesty, AA, VanCafe, Driveline Svcs of Portland...) Any advice/feedback will be appreciated. |
hans j Samba Member
Joined: May 06, 2006 Posts: 2715 Location: Salt Lake City UT
Posted: Fri Jun 22, 2012 6:54 pm Post subject: |
Thanks for the part number guys. I have been getting a significant vibration on acceleration and nothing on deceleration. Suspected a CV but pulled the driveline last night and found a bad u-joint.
A coworker actually did all the hard work for me since he has done hundreds over the years, just took him a few minutes. But one thing we decided to do was to actually make it servicable.
Drilled a hole in the end just large enough to get the grease gun in there.
I forgot to get a pic of the box but it was just over $20 at Six States Distributors (local 4x4/everything supply store). We called over and just asked for a 813 u-joint, fits perfect. It's made in China, but looks decent.
I'll get it installed tomorrow and see how it feels! _________________ 1986 Canadian Syncro Westy TDI - 1989 Syncro Single Cab - 2001 Audi S4 - 1981 VW Caddy ABA - 1980 VW Caddy EV - 1973 VW T-181 |
ragnarhairybreeks Samba Member
Joined: October 26, 2009 Posts: 1890 Location: Sidney B.C. Canada
Posted: Fri Jun 22, 2012 7:01 pm Post subject: |
Dammit! Having done the same U-joint replacement I'm chagrined about not thinking doing same mod.
nice job
alistair _________________ '86 7 passenger syncro, converted to westy pop top, project still in progress
https://shufti.blog/
Old address still works...
http://shufti.wordpress.com |
T3 Pilot Samba Member
Joined: January 10, 2011 Posts: 1507 Location: Deep South of the Great White North
Posted: Fri Jun 22, 2012 9:10 pm Post subject: |
Last time I replaced one of those joints, I spent hours looking for a 45 degree grease nipple that would fit. This idea is so much better.
Well played sir. _________________ 1988 Vanagon
The most important part in every vehicle is the nut behind the wheel...... |
whip618 Samba Member
Joined: October 16, 2002 Posts: 761 Location: Albuquerque
Posted: Fri Jun 22, 2012 9:59 pm Post subject: |
Using the NEAPCO replacement joint does not leave much room for a zerk, even a 45 degree would not allow the joint to swivel.
so a couple of stub adapters allows me to grease the joints in place by using a high pressure needle fitting
Phil _________________ Life is simple....either you're qualified or you're not.
USSVI.......Pride Runs Deep
USSVI Life member and Holland Club member
Samba Member No. 3307 |
IdahoDoug Samba Member
Joined: June 12, 2010 Posts: 10251 Location: N. Idaho
Posted: Fri Jun 22, 2012 10:05 pm Post subject: |
Nice! Very nice. Particularly so since my shaft is at a local shop getting new joints at this very moment. He did another Syncro recently, so he's built a jig specifically to balance the Syncro drive shaft - high speed balance. Looking forward to it. My shaft was smooth as glass, but while cleaning it up on Monday, I noticed two of the 4 bushings on the rear joint showed red dust. So while it is smooth now, that means dry bearings and in a month or two things are going to degrade.
DougM _________________ 1987 2WD Wolfsburg Vanagon Weekender "Mango", two fully locked 80 Series LandCruisers. 2017 Subaru Outback boxer. 1990 Audi 90 Quattro 20V with rear locking differential, 1990 burgundy parts Vanagon. 1984 Porsche 944, 1988 Toyota Supra 5 speed targa, 2002 BMW 325iX, 1982 Toyota Sunrader |
zackalope Samba Member
Posted: Thu Nov 15, 2012 7:08 pm Post subject: |
insyncro wrote: |
Thanks again.
Have you done this? I ran my friend's driveshaft (standard design) in my van and it was smooth as glass so I know that's the issue. I tried rebuilding and balancing mine, but it eats u joints pretty fast, and the vibrations don't go away. If the damper or slip yoke isn't necessary, I'd rather not have them. I do take the van off road a lot, so I'm hesitant because the slip might be necessary for some flexibility in the drivetrain. Winter's coming and I want 4wd again, so ill do something soon. |
insyncro wrote: |
Thanks again.
insyncro Banned
Posted: Thu Nov 15, 2012 7:19 pm Post subject: |
My drivelines are all vibration free.
I have written about how to achieve this in numerous threads.
Many things must be checked and grease is your friend.
I just picked up a donut less driveshaft as they are on sale this month. |
goskiracer Samba Member
Joined: January 15, 2009 Posts: 339 Location: Oslo, Norway
Posted: Thu Nov 15, 2012 8:38 pm Post subject: |
I have a slip yoke style shaft with spicer joint that should land next week from wholesaleimportparts.com I will let folks know how it performs. My old shaft had a failing joint at the rear.
>>Edited the website _________________ 86' Syncro 2.2 Vanistan, WBXhaust, ski-pole shifter for +11hp
insyncro Banned
Posted: Thu Nov 15, 2012 8:40 pm Post subject: |
goskiracer wrote: |
I have a slip yoke style shaft with spicer joint that should land next week from wholesalecarparts.com I will let folks know how it performs. My old shaft had a failing joint at the rear. |
Gotta link, couldn't find it |
Posted: Thu Nov 15, 2012 9:05 pm Post subject: |
Sorry, long travel day
Wholesaleimportparts.com
Cheers _________________ 86' Syncro 2.2 Vanistan, WBXhaust, ski-pole shifter for +11hp |
insyncro Banned
insyncro Banned
Posted: Thu Nov 15, 2012 9:12 pm Post subject: |
A picture of the actual shaft would be appreciated after it arrives. |
Posted: Thu Nov 15, 2012 9:23 pm Post subject: |
No problem, I will post some photos of the joints etc. _________________ 86' Syncro 2.2 Vanistan, WBXhaust, ski-pole shifter for +11hp |
Posted: Fri Nov 16, 2012 5:15 am Post subject: |
insyncro wrote: |
Sorry, the reference in my question was unclear, I was asking if you had tried out the donutless shafts yet. The answer is no, but you seem to have perhaps changed your mind regarding them from a previous post where you advise against off road use.
Anyone have an opinion based on experience on the suitability of a donutless driveshaft for off road use? Nothing crazy, just a lot of not pavement around here. |
Dant Samba Member
Joined: November 15, 2007 Posts: 126 Location: T County, Ohio
Posted: Sat Nov 17, 2012 8:10 am Post subject: syncro driveshaft |
Goskiracer, how is the driveshaft mentioned above? Pics?
I have put new u-joints in mine. I think I lost track (dumb) of indexing parts though, still vibrates. There was a fair amount of slop in the slipyoke also.
So, I am thinking of getting one from somewhere.
Van Cafe and Gowesty have their versions. Is there an up to date list of who sells these?
Thanks as always for all the Samba info!
Dan _________________ 90 Carat
97 Jetta GLX
87 GL (nobody wanted it)
91 Syncro (Stripped,Plain Jane,fixed vent windows,no tach) also rusty. Hurray for me! |
Posted: Tue Nov 20, 2012 9:40 am Post subject: |
The prop shaft arrived today. I will be taking photos and installing it this afternoon on my lunch break.
Is there a recommended direction the slip-yoke should face? Front diff or transaxle side? Or does it matter? _________________ 86' Syncro 2.2 Vanistan, WBXhaust, ski-pole shifter for +11hp |
