KillerTux Samba Member
Joined: June 21, 2005 Posts: 434 Location: Odenton, MD
Posted: Fri Jan 18, 2008 9:06 am Post subject: Carb Problem |
I have a German 30-Pict1 and I need to manually close the choke plate to start. Once closed it runs great, but when I drive and put the car in second gear it cuts off. I look at the choke plate and it is open a bit. I have adjusted the auto choke 3 times and it will not keep the plate closed long enough for the engine to warm up. The upper half the the manifold looks like a frosty beer mug. How can I fix this? Thanks _________________ 1964 Beetle Convertible |
Randy in Maine Samba Member
Posted: Fri Jan 18, 2008 9:53 am Post subject: |
What do you know about cleaning out the heat risers? |
chillz1 Samba Member
Joined: August 03, 2002 Posts: 869 Location: Where You Least Expect
katalla Samba Member
Joined: March 15, 2006 Posts: 442 Location: los angeles
Posted: Fri Jan 18, 2008 11:15 am Post subject: |
do u have the stock air cleaner with preheat tube atached, if not the carb might be icing up, wolfsburgwest.com has replacement chokes too |
Posted: Fri Jan 18, 2008 12:17 pm Post subject: |
This carb is just rebuilt. My car ran before with a H30/31 but the carb developed a crack and I needed a new one. I have a stock paper filter setup with preheat tube. The manifold is about 1.5 years old and I don't think there is any carbon that is blocking. My timing is set at 7.5 and I set the points and adjusted the valves.
I really just need help with the choke plate. I don't remember how it is suppose to operate. It runs and drives but when the plate moves up just a bit it cuts out. How do I operate the choke? _________________ 1964 Beetle Convertible |
mnussbau Samba Member
Joined: August 26, 2006 Posts: 4589 Location: Central Maryland
keifernet Samba Search & Rescue
Joined: May 11, 2002 Posts: 19395 Location: Samba Center for Behavioral Science
Posted: Fri Jan 18, 2008 6:19 pm Post subject: |
Do you have the electric idle cut off style pilot jet on that carb or has it been replaced with a non electric pilot jet? |
Posted: Fri Jan 18, 2008 11:15 pm Post subject: |
keifernet wrote: |
I have the electric idle cut off jet. Would replacing it with a regular jet solve the issue? I have tested the jet and it clicks when I touch it with a live wire. _________________ 1964 Beetle Convertible |
Posted: Sat Jan 19, 2008 10:14 am Post subject: |
KillerTux wrote: |
keifernet wrote: |
I have the electric idle cut off jet. Would replacing it with a regular jet solve the issue? I have tested the jet and it clicks when I touch it with a live wire. |
If it is not loose in the carb and working then it's probably fine... but also if the end gets clogged up with a bit of trash ( just like the plain pilot jet) then clicking or not the engine will DIE at stop/run rough and generally not idle at all. You might want to pull it out and clean it and blow out the passage. |
