128vw Samba Member
Joined: April 05, 2006 Posts: 222 Location: Western Massachusetts
Posted: Tue Jan 22, 2008 2:50 pm Post subject: 1914 exhaust |
I'v got a 1914 that I'm just finishing. It has a W110 cam, .055 deck, 8.5/1 comp, 40/35.5 valves, 1.1 rockers, very mild porting(just cleaned up the bad lumps and edges). I have 40IDF carbs. I wonder if I could run 28mm vents with 118 mains and 1 3/8 exhaust and J pipes. I want low end power, maybe up to 4500. Will this work? Any problems? |
128vw Samba Member
Posted: Wed Jan 23, 2008 4:38 am Post subject: |
What, nobody has any comments on this setup? I'd like your ideas . |
mkmaxit Samba Member
Joined: June 02, 2007 Posts: 626 Location: Clear Spring Maryland
Posted: Wed Jan 23, 2008 4:41 am Post subject: |
Have to check your jetting once running for the main jet you mentioned. But all you posted should work just fine. As for low end tork.. to me thats more stroker crank than a cam.
But what your using should be just fine. Maybe go to 1 1/2 diameter exhaust though. |
vwracerdave Samba Member
Joined: November 11, 2004 Posts: 15309 Location: Deep in the 405
Posted: Wed Jan 23, 2008 6:28 am Post subject: |
You always tune the carbs for max power. I would use 32mm venturies with your combo. A W110 cam will make power to 5500 RPM so get all you can out of it. _________________ 2017 Street Comp Champion - Thunder Valley Raceway Park - Noble, OK
