hans j Samba Member
Joined: May 06, 2006 Posts: 2715 Location: Salt Lake City UT
Posted: Wed Oct 29, 2014 12:59 pm Post subject: |
Thanks Chris! I found this comparison today and it should shed some light on what is going on:
http://www.wagenswest.com/how_to/bus_vanagon_ball_comparison.php
I'd say if you have a smooth steel cap, it's going to wear out very fast! Look for the ones that look like cast or machined steel.
I checked the TRW LBJ we have, cast cap.
So it looks like the only good ball joints to use are Lemfoerdor, Moog, and TRW.
edit: After reading the thread for the third or fourth time, I realized the link I posted was already here! Hopefully linking the photo with it will help others (not me apparently) in finding quality lower ball joints. _________________ 1986 Canadian Syncro Westy TDI - 1989 Syncro Single Cab - 2001 Audi S4 - 1981 VW Caddy ABA - 1980 VW Caddy EV - 1973 VW T-181 |
hans j Samba Member
Posted: Tue Nov 04, 2014 3:02 pm Post subject: |
Skip the TRW's... The syncro I installed them on already has 1-2mm of play in both of them after less then one week and a couple hundred miles at most. _________________ 1986 Canadian Syncro Westy TDI - 1989 Syncro Single Cab - 2001 Audi S4 - 1981 VW Caddy ABA - 1980 VW Caddy EV - 1973 VW T-181 |
Escorial Syncro Samba Member
Joined: May 02, 2004 Posts: 437 Location: Manitou Springs, CO
Posted: Mon Nov 17, 2014 5:37 pm Post subject: |
hans j wrote: |
Skip the TRW's... The syncro I installed them on already has 1-2mm of play in both of them after less then one week and a couple hundred miles at most. |
Yep, I chose the TRW lower ball joints because they seemed to have more articulation...BUT, after about 800 miles of city driving, both TRW LBJ's have significant play. What junk. Just ordered some Moogs from T3, and so excited to replace the LBJ's.
FWIW, these are on my lifted syncro. _________________ Joel Lane
1985 Vanagon converted to syncro, ALH TDI, Reimo Primus top with Westy interior
2002 Toyota Tundra 4x4
1974 Honda CL360 Scrambler (for sale!) |
specialev Samba Member
Joined: March 25, 2011 Posts: 281 Location: Mukilteo WA
Posted: Sat Nov 29, 2014 3:46 pm Post subject: |
Does anyone have a source for the circlip /retainer for the lbj? I just picked up some new moog lbjs (amazon prime had both upper and lower) and I find that the old ones went into the bin. I must have thought they'd be included with the new part. Thanks. |
hans j Samba Member
Posted: Sat Nov 29, 2014 6:55 pm Post subject: |
specialev wrote: |
If you don't find some locally, I have some extra I can mail you. _________________ 1986 Canadian Syncro Westy TDI - 1989 Syncro Single Cab - 2001 Audi S4 - 1981 VW Caddy ABA - 1980 VW Caddy EV - 1973 VW T-181 |
Hodakaguy Samba Member
Joined: April 25, 2012 Posts: 661 Location: Eastern WA
dobryan Samba Member
Joined: March 24, 2006 Posts: 16505 Location: Brookeville, MD
hans j Samba Member
Posted: Sat Nov 29, 2014 8:35 pm Post subject: |
dobryan wrote: |
I replaced my ball joonts a few months ago but did not regrease. CAn this be done with them installed? |
You could probably use a needle grease injector and then put some silicon or other goop on the boot to make sure it sealed all the way. It's hard enough to get the boots back on the joints when they are out of the car! Especially the lowers. _________________ 1986 Canadian Syncro Westy TDI - 1989 Syncro Single Cab - 2001 Audi S4 - 1981 VW Caddy ABA - 1980 VW Caddy EV - 1973 VW T-181 |
Posted: Sun Nov 30, 2014 6:36 pm Post subject: |
hans j wrote: |
If you don't find some locally, I have some extra I can mail you. |
Thanks, Hans. I tried to find something I could use today but the biggest clips I found were still way too small. I may take you up on your offer but want to look a little harder first. They may have something I can use at Tacoma Screw.
I measured the new joint and it looks like a 45mm external circlip could work. Just need to find someone that has them. |
JPrato Samba Member
Joined: December 15, 2006 Posts: 791 Location: Livonia, NY
Posted: Sun Dec 20, 2015 6:05 pm Post subject: Re: Are all Ball Joints Created Equal? |
Rock Auto is carrying upper and lower Lemforder ball joints right now for Vanagons. A little pricey at $52.79 and $40.79 respectively but hey, it's the good stuff!
http://www.rockauto.com/ _________________ Joe
87 Syncro Tin Top project
84 Westy, 2.5L Subaru power
06 Subaru 2.5 turbo in waiting
46 Cessna 140 |
greebly Samba Member
Joined: August 27, 2009 Posts: 966 Location: Here and now
Posted: Tue Jan 26, 2016 1:39 pm Post subject: |
tencentlife wrote: |
I'm Chris, too. |
Shouldn't that be " I'm Chris II" ? |
andersonj Samba Member
Joined: January 17, 2011 Posts: 138 Location: Windhoek, Namibia - South Africa
Posted: Mon Feb 01, 2016 3:30 am Post subject: Re: Are all Ball Joints Created Equal? |
Has anyone used or heard of the "german" Hans Pries topran ball joints? |
AtlasShrugged Samba Member
Joined: October 30, 2008 Posts: 1605 Location: Decatur, Ga. USA
Posted: Mon Feb 01, 2016 5:26 am Post subject: Re: Are all Ball Joints Created Equal? |
andersonj wrote: |
Topran is an independent parts manufacture or reseller in Germany, kind of like Meyer. Probably hit or miss |
cmayna Samba Member
Joined: August 18, 2014 Posts: 1148 Location: SF Bay area, CA
Posted: Thu Mar 31, 2016 2:10 pm Post subject: Re: Are all Ball Joints Created Equal? |
This is a very good thread. Lots of info. Sounds like I might go with Moog or Lemforder. _________________ '90 Westy / automatic.
If I'm not working on the camper or my '50 Chebbie truck, I'm either fishing with the wife or smoking Salmon.
Craig |
Sodo Samba Member
Joined: July 06, 2007 Posts: 9616 Location: Western WA
Posted: Fri Dec 23, 2016 4:35 pm Post subject: Re: Are all Ball Joints Created Equal? |
Great pics by WagensWest http://www.wagenswest.com/how_to/bus_vanagon_ball_comparison.php
I have these Moog Lemforders (from T3Technique.com). I think I'm going to add grease fittings. I'll drill it like this, and use the press-in fittings. I ordered them frrom McMaster-Carr, $4 for 10 fittings. I hope they don't come out.
That top cap is steel. I'll pound one into a test hole and yank on it, see how well they hold. I have modern grease guns, but if someone else put one of those "permanent" grease couplings onto it might yank it out.
The general plan is drill until the tip almost breaks thru. Then pierce the thin steel with a sharp point, leaving the metal bits attached to the hole. Not sure this can be done but I will try; for the sport of it. I highly doubt metal shavings from the drill could damage this interface anyway. This joint is worn by stone. Dirt type abrasives. The simple fact that new grease expels the dirt has to be a million times better than not. After the rubber boots fail (after their few engineered years of service) then I'll tie a sock around it and remember to grease it more often. _________________
....KTMs, GasGas, SPOT mtb |
Abyss Samba Member
Joined: March 27, 2014 Posts: 9 Location: Brisbane, Australia
Posted: Wed Feb 13, 2019 7:54 pm Post subject: Re: Are all Ball Joints Created Equal? |
as of 2019 - I hear Lemforder - Moog has now stopped making these in Germany, and are now made in China, but that typically the quality has dropped and these are now the go-to ball joints? Other than old stock and greasing other poor brands, what is the go now? |
Sodo Samba Member
Posted: Thu Feb 14, 2019 10:27 am Post subject: Re: Are all Ball Joints Created Equal? |
I bet any ball joint is good enough if kept clean and lubed. Probably once they go dry is when the good outlast the bad.
But if you never let them go dry.....(and boots not cracked) they all "should" run a long time.
Main concerns seem to be:
1) insufficient grease inside when new (by mfr)
2) boots that may fall apart too soon
3) no re-lubrication method
4) I saw some pics showing Febi brand offering "lesser articulation" than the Moog Lemfoerder.
Anyway you can solve most of these problems by drilling a hole and needle-greasing the joint when new. Then cover the hole with silicone. Then it's easy to periodically renew grease from time to time. But you must have a strategy to avoid over-inflating the boot, because boot failure is a huge problem.
Probably the best way is to really pack the joint+boot full of synthetic grease when it's new, taking care to purge excess grease such that when the taper is inserted, the boot doesn't slide back and "become overinflated" at installation. Then you can relax, until 30k mi, or 50k miles you re-grease while paying attention to the boot inflation issue.
I added grease fittings to my ball-joints, but on second thought have concluded that's not the right way. Because somebody could just pump them full and over-inflate the boots, which are NOT designed for greasing. Whereas with the PLEWS needle-greaser method:
1) you get them full of grease in the beginning and they will probably run a full 100k miles or maybe 200k.
2) at 50k mi, since you're now retired etc, nothing else to do....you can dig out the silicone and re-grease carefully, paying attention to the boots, perhaps even replacing them.
Anyway here's a cross-link to another thread with some pics and discussion.
Vanagon Ball Joints - HOW TO add grease zerk fittings (new MOOG)
Sorry I don't know the current answer to the "go-to ball joint brand". In the USA T3Technique still lists german Moog units in stock. _________________
ALIKA T3 Samba Member
Joined: July 30, 2009 Posts: 6360 Location: Honolulu,Hawaii and France
Posted: Thu Feb 14, 2019 12:43 pm Post subject: Re: Are all Ball Joints Created Equal? |
The UBJ from Lemförder have moved to China, lowers and Moog are still German to this day, but for how long?
Meyle is pure garbage, Febi as well. I collect a lot of them at the shop, the last Febi were 9,000 miles, 2 years. A shit load of play.
What happens is no matter the brand, the boots are crappy rubber and prolly chinese, so that's what kills them like Sodo pointed above.
Quite a few people know my work with silicone and PU to put out good products on the market.
I'm testing polyurethane boots on old factory tie rod ends, so far so good.
I will prolly invest in the molds soon, tests are very promising!!
_________________ Silicone Steering Boots and 930 Cv boots for sale in the classifieds.
vwhammer Samba Member
Joined: May 20, 2006 Posts: 998 Location: Boulder CO.
Posted: Thu Feb 14, 2019 2:27 pm Post subject: Re: Are all Ball Joints Created Equal? |
To be brutally honest, I can't remember the last time I have ever changed a ball joint or tie rod end more than once on anything I have ever owned no matter what brand of joint I got or where it came from.
Perhaps I don't keep my cars as long.
ya might steer clear (no pun intended) of the generic 5 dollar tie rod ends and ball joints that you can find at Rockauto but, in my opinion, any of the mid priced units have worked fine for me and friends of mine.
We don't get too hung up on making sure all our crap is OEM, German made and all that.
Friend of mine has a MK4 Jetta with 340,000 miles that is practically a rolling Rockauto catalog and about the only time he has to replace a part ahead of a normal replacement time frame is when he crashes.
Its a commuter/autocross/track day/mountain twisty car.
He's pretty hard on it. |
