YOGIVW Samba Member
Joined: February 04, 2005 Posts: 263 Location: Olsztyn/POLAND
Posted: Fri Jan 25, 2008 2:29 am Post subject: 1915 with A1 sidewinder 1 ½ or 1 5/8 ???? new pictures |
OK, I have a new 1915 engine with Stive Tim heads stage 2 ( 42x37 valves ), engel 110, dual webbers 44. The question is: which A1 sidewinder works better on this set up? 1 ½ or 1 5/8?
My car is 79 super cabrio weekender.
I ordered from USA 1 5/8 but received 1 1/2 if the smaller one is fine I will stay with it if not I will need to buy bigger one which means for me on another side of the pond 9 -10 weeks waiting time. _________________ Pawel
Vw 1303 1979 Black&Beige convertible
VW T4 2001 Caravelle Business 2.8 V6
Westfalia James Cook 2.9TD
miniman82 Samba Swamp Donkey
Joined: March 22, 2005 Posts: 9515 Location: Southern Maryland
Posted: Fri Jan 25, 2008 2:34 am Post subject: |
What do the exhaust ports measure on your heads? If they're not bigger than 1.5", run what you got. It's only a 1915. _________________ Build thread: http://www.thesamba.com/vw/forum/viewtopic.php?t=212747
Glenn wrote: |
satterley_sr wrote: |
I just wanted to bitch but I'm getting no sympathy. |
Welcome to the Samba. |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76938 Location: Sneaking up behind you
Posted: Fri Jan 25, 2008 5:43 am Post subject: |
I'm running a 2180 with Steve Tims Stage 2s and a 1-5/8" header. _________________ Glenn
Member #1009
#BlueSquare |
Warner Samba Member
Posted: Fri Jan 25, 2008 6:48 am Post subject: |
It sounds like with those heads you'll probably want the 1 5/8" pipe. Those will definitely flow. Where do you want to make the bulk of your power? The bigger pipe might take a bit off of the low and mid-range, but will likely make a bit more power up top. Either one will work, but I'd probably opt for the 1 5/8". I have 44/37.5 valves on my 2276 and have a 1 3/4" header. I may suffer a BIT on the low and midrange, but it gave almost 10 more hp up top over the 1 5/8"
Warner |
vwracerdave Samba Member
Joined: November 11, 2004 Posts: 15308 Location: Deep in the 405
Posted: Fri Jan 25, 2008 9:02 am Post subject: |
The 1 1/2" header with a W110 cam. _________________ 2017 Street Comp Champion - Thunder Valley Raceway Park - Noble, OK
Warner Samba Member
Posted: Fri Jan 25, 2008 9:03 am Post subject: |
vwracerdave wrote: |
The 1 1/2" header with a W110 cam. |
Good point...didn't notice the smaller cam.....
Warner |
YOGIVW Samba Member
Posted: Fri Jan 25, 2008 9:27 am Post subject: |
Warner wrote: |
too small?
It is Serranos engine and tomorrow I will split the case to see what he put inside. I might have W125, is it better for my application? Now I have 1:1.1 rockers ( piad for 1.1:25 ) but if neede may upgrade to 1:1.25. I want as much power as possible
Thanks for your help _________________ Pawel
Westfalia James Cook 2.9TD |
74 Thing Samba Member
Posted: Fri Jan 25, 2008 9:42 am Post subject: |
I would buy the 1 5/8" since you will probably end up dropping a stroker crank in there in a year or so and then you won't have to buy a new header. If not then the 1 1/2" is perfect for your 1914 application. |
YOGIVW Samba Member
Posted: Fri Jan 25, 2008 9:45 am Post subject: |
74 Thing wrote: |
Today I would say NO, 1915 is more than enough but from what I see/read you are absolutly right. _________________ Pawel
krusher Samba Member
Joined: September 24, 2002 Posts: 7652 Location: europe
Posted: Fri Jan 25, 2008 11:11 am Post subject: |
I would wait to see what you find inside that engine, I have heard of a guy here in the uk that got a 1776 from him and when taken a part it was a pretty stock 1600. _________________ (06:31:07) RoachGhia: "i drink dick way too fast" |
YOGIVW Samba Member
Posted: Fri Jan 25, 2008 12:50 pm Post subject: |
krusher wrote: |
I would wait to see what you find inside that engine, I have heard of a guy here in the uk that got a 1776 from him and when taken a part it was a pretty stock 1600. |
with my longblock is not so bad. I call it LLE ( Last Limited Ldition ) I got it one week before Steve "retired". I pull the head and it is 1915 for sure. _________________ Pawel
DRD RACING HEADS Samba Member
Posted: Fri Jan 25, 2008 9:16 pm Post subject: Re: 1915 with A1 sidewinder 1 ½ or 1 5/8 ???? |
If your going to change the cam, put a engle 120 in it, and run a 1.25 rocker.
Pump the compression to around 9.0, and run a 1 5/8 sidewinder, it will ring out a 130hp easy. _________________ "DRD RACING HEADS"
"CNCHEADS and engine parts"
We sell What Works!
HTTP://WWW.DRDRACINGHEADS.COM
Email [email protected]
Phone-714-545-4100
DRD Online Store
HTTP://WWW.DRDRACINGHEADS.COM/Xcart/ |
YOGIVW Samba Member
Posted: Sat Jan 26, 2008 12:30 am Post subject: Re: 1915 with A1 sidewinder 1 ½ or 1 5/8 ???? |
Darren Gurrola wrote: |
Pump the compression to around 9.0, and run a 1 5/8 sidewinder, it will ring out a 130hp easy. |
thank you Darren. I said w125 because I have it already, engel 120 will need to buy but it is not a problem. My compresion is 8,5 and I do not want to change it .
Going back to A1, I was told by the vendor that headers are measured on the outside of the tubing and if so my is 1 5/8", I thought whole my life that the dimension is messured inside. _________________ Pawel
Posted: Sat Jan 26, 2008 2:48 am Post subject: Re: 1915 with A1 sidewinder 1 ½ or 1 5/8 ???? |
YOGIVW wrote: |
Going back to A1, I was told by the vendor that headers are measured on the outside of the tubing and if so my is 1 5/8", I thought whole my life that the dimension is messured inside. |
It makes sence to measure the inside as that gives you the actual size air can flow through, if you measure the inside then you have to take into account wall thickness etc, just extra hassle.
Sounds like you were lucky wioth your engine, but i would personally strip it and inspet everything.
Serrano's retired, I dont think most peoples see retirement as running away with your customers money.
Anyway hope the engine turns out great _________________ (06:31:07) RoachGhia: "i drink dick way too fast" |
YOGIVW Samba Member
Posted: Tue Jan 29, 2008 1:03 am Post subject: |
I spitted the case and it look like the crank was balanced. See pictures. In the reds circles are mars, it looks like it was grinded and drilled. If the crank was balanced it was balanced without the pressure plate and pulley. Should I balance it again or it is fine? It is not going be race engine, mostly weekender with occasionally green light action.
Generally the interior looks good, well assembled. But I paid for CB lifters got something else. Can you guys recognize it? What is the other lifter? Paid for SCAT I beam rods and I have EMPI H rods.
Now I going to replace a cam as Darren suggested for W120.
