evillrdnikon Samba Member
Joined: February 26, 2014 Posts: 180 Location: Las Vegas
Posted: Fri Mar 24, 2017 10:30 am Post subject: Re: GL 4 or GL 5 - "Official Gear Lube Topic" |
so I talked to Rancho and they said to use (EDITED) 80W-90 non synthetic (EDITED) in my transmission.
take it how you want fellas. Who is to argue with the company that sold you their product =/
Last edited by evillrdnikon on Fri Mar 24, 2017 11:06 am; edited 1 time in total |
Posted: Fri Mar 24, 2017 10:36 am Post subject: Re: GL 4 or GL 5 - "Official Gear Lube Topic" |
here is the stuff LAT has on their website for data.
http://latracingoils.com/product/lat-multipurpose-gear-oil/
Link to MSDS DATA:
http://latracingoils.com/wp-content/uploads/2015/06/80W90-RACING-GEAR-OIL-31237.pdf
LAT Multi-Purpose Gear Oil
LAT multi-purpose gear oil provides maximum heavy shock load and high carrying protection. Blended from the highest quality of petroleum base oils fortified with VI improvers, rust inhibitors, foam suppressants and LFR extreme pressure additives. Multi-viscosity protects your gears within a wide range of applications.
Exceeds API GL-5 and DOES NOT contain limited slip additives. Available in quart and 55 gallon drums.
Applications
Recommended for street performance engines, light duty drag racing, light duty off road racing.
Features
Exceeds API GL-5
Protects hypoid gears from wear and scuffing
Anti-foaming agents
Contains rust inhibitors & VI improvers
Attributes
Appearance AmberViscosity @100c 20.2cStViscosity @ 40c 179cSt |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76940 Location: Sneaking up behind you
Posted: Fri Mar 24, 2017 10:48 am Post subject: Re: GL 4 or GL 5 - "Official Gear Lube Topic" |
evillrdnikon wrote: |
so I talked to Rancho and they said to use 80-90 regular in my transmission.
take it how you want fellas. Who is to argue with the company that sold you their product =/ |
What does "regular" mean?
GL3, GL4 or GL5? _________________ Glenn
Member #1009
#BlueSquare |
Posted: Fri Mar 24, 2017 11:03 am Post subject: Re: GL 4 or GL 5 - "Official Gear Lube Topic" |
Glenn wrote: |
GL3, GL4 or GL5? |
in the link provided above for the PDF it states
"EP GO SAE 80W90 GL-5 w/Mo"
quoted by Rancho themselve "Use regular 80w-90, no synthetic"
Terminology is a bitch. |
vwracerdave Samba Member
Joined: November 11, 2004 Posts: 15309 Location: Deep in the 405
Posted: Fri Mar 24, 2017 11:38 am Post subject: Re: GL 4 or GL 5 - "Official Gear Lube Topic" |
Rancho recommends LAT gear oil because they are part owners of the company.
I use semi-synthetic gear oil in my street cars and full synthetic gear oil in my race car. _________________ 2017 Street Comp Champion - Thunder Valley Raceway Park - Noble, OK
Zundfolge1432 Samba Member
Posted: Mon Apr 03, 2017 12:37 pm Post subject: Re: GL 4 or GL 5 - "Official Gear Lube Topic" |
Synthetic here for years no problems works well in cold weather too. Amsoil |
Frodge Samba Member
Posted: Tue Apr 25, 2017 3:47 pm Post subject: Re: GL 4 or GL 5 - "Official Gear Lube Topic" |
Other than the Brad Penn, what other gl 4 80w90 is readily available? Online purchase is fine. |
modok Samba Member
Posted: Tue Apr 25, 2017 4:46 pm Post subject: Re: GL 4 or GL 5 - "Official Gear Lube Topic" |
acdelco 12346190 is available from summit racing.
It is a 75-90 synthetic gl-4 gear oil for synchronized transmissions |
79SuperVert Samba Member
Joined: May 31, 2002 Posts: 9758 Location: Elizabeth, NJ & La Isla Del Encanto
Posted: Tue Apr 25, 2017 6:14 pm Post subject: Re: GL 4 or GL 5 - "Official Gear Lube Topic" |
Red Line sells MT-90 full synthetic that meets 80W-90 specs:
https://www.redlineoil.com/product.aspx?pid=46 _________________ Central Jersey VW Society
Wanted: Art Collins VW (Savannah, Georgia) items - license plate surrounds and other items. Also ivory "AM", "FM" and "SW" buttons for a US Blaupunkt Frankfurt. |
Posted: Tue Apr 25, 2017 7:45 pm Post subject: Re: GL 4 or GL 5 - "Official Gear Lube Topic" |
Redline does not recommend Mt-90 for use with hypoid gears, from their website: "MTL, MT-85 & MT-90 are not for use in differentials with hypoid gears" |
EVfun Samba Member
Posted: Tue Apr 25, 2017 8:24 pm Post subject: Re: GL 4 or GL 5 - "Official Gear Lube Topic" |
Wildthings wrote: |
The Beetle transaxle does not have hypoid gears, however, the Bus transaxle does. _________________
Wildthings wrote: |
Frodge Samba Member
Posted: Wed Apr 26, 2017 12:36 am Post subject: Re: GL 4 or GL 5 - "Official Gear Lube Topic" |
I'd like to stay away from synthetics with old seals. |
Posted: Thu May 04, 2017 1:38 pm Post subject: Re: GL 4 or GL 5 - "Official Gear Lube Topic" |
Going with what ever the best GL5 synthetic oil is! Changed my mind from up above! lmao! |
Bruce Samba Member
Posted: Fri May 05, 2017 12:54 pm Post subject: Re: GL 4 or GL 5 - "Official Gear Lube Topic" |
EVfun wrote: |
The Beetle transaxle does not have hypoid gears, however, the Bus transaxle does. |
Correct.
The reason you must use GL-5 with hypoid gears is because the contact pressure is greater due to the pinion offset. This higher stress means you need an oil with a greater extreme pressure rating.
So you may be thinking that since a Type 1 gearbox doesn't use hypoid gears, you don't need to bother with GL-5 oil. Not so. It has now become common to find R&P gears that are simply worn out at the gear teeth. Wear that can be prevented by using an oil with a higher extreme pressure rating.
If you buy a rebuilt gearbox from Rancho now-a-days, there's a high likelyhood you're getting a new R&P. Because so many of the used ones are JUNK! _________________
modok Samba Member
Posted: Fri May 05, 2017 4:36 pm Post subject: Re: GL 4 or GL 5 - "Official Gear Lube Topic" |
I actually thought the opposite, from what I've seen, but I don't doubt it.
If that's what you are seeing then there must be a cause for it, although what that is.....not so easy to say, unless you know the history of it.
The oil companies don't tell you much. What WAS in there?
This delco trans oil and the valvoline MTF are recommended for a lot of the same apps but they look and smell and feel totally different. The valvoline IMO, seems more conventional, "smells right", but that's about all I have to go on, for now. |
Posted: Sun May 07, 2017 5:00 am Post subject: Re: GL 4 or GL 5 - "Official Gear Lube Topic" |
Frodge wrote: |
This is a fallacy started by big oil in the early 70s to discredit synthetic oil. It is based in fear and nothing else. How sad that over 40 years later this is still being repeated. |
Posted: Sun May 07, 2017 9:16 am Post subject: Re: GL 4 or GL 5 - "Official Gear Lube Topic" |
Zundfolge1432 wrote: |
Frodge wrote: |
Maybe, maybe not. When you go from a 40wt motor oil to a 5w40 you are apt to get more seepage as the thinner lubricant can more easily pass around gasket and seals. Same with going from a 140wt gear oil to an 85w140. If you already have a slow leak and you go to a thinner oil the leak is very apt to get worse, nothing to do with synthetic oil necessarily, just the way of any lubricant.
Lets face it 50ish years ago, seals didn't always seal all that well when new and certainly didn't last all that long. My '72 Dodge even came with leather seals on the front wheels, probably a design hold over from the 1930's. |
Bruce Samba Member
Posted: Sun May 07, 2017 11:15 am Post subject: Re: GL 4 or GL 5 - "Official Gear Lube Topic" |
Wildthings wrote: |
Frodge wrote: |
When you go from a 40wt motor oil to a 5w40 you are apt to get more seepage as the thinner lubricant can more easily pass around gasket and seals. |
Not true.
A 5W-40 oil at 100ºC is the same viscosity as a straight 40. No possible difference in leakage there due to different oils.
Then when the oil is cold, a 5W-40 is still way thicker than either of these oils at 100ºC. _________________
Glenn Mr. 010
Posted: Sun May 07, 2017 12:41 pm Post subject: Re: GL 4 or GL 5 - "Official Gear Lube Topic" |
Bruce wrote: |
Wildthings wrote: |
Frodge wrote: |
Not true.
Then when the oil is cold, a 5W-40 is still way thicker than either of these oils at 100ºC. |
And an engine spends how much of its time running? Maybe 5% and the rest of its time is sitting cold, so a weeping gasket or seal can leak quite a bit while the box is cold. |
