Posted: Sun May 07, 2017 12:50 pm Post subject: Re: GL 4 or GL 5 - "Official Gear Lube Topic" |
Nice scream, people don't realize that a 75w90 oil has about the same viscosity as a typical 10w40 motor oil, they think of gear oils as being much thicker. FYI a 40wt or or maybe even 5w40 oil will pass specs for a GL-4 oil anyway. I certainly would not hesitate to run 5w40 nor even thinner oil in a gear box in arctic conditions. 40 years ago it was common for people to run ATF in a high offset hypoid box when the temps were apt to drop well below 0°F.
EVfun Samba Member
Posted: Sun May 07, 2017 2:29 pm Post subject: Re: GL 4 or GL 5 - "Official Gear Lube Topic" |
Frodge wrote: |
I'd like to stay away from synthetics with old seals. |
I've been running Redline MTL in a 40 horse box in my fiberglass buggy for 17 years. The only seals I've replaced have been the axle boots. I even skipped out of changing the axle seals and O rings when I did the rear brakes. _________________
Wildthings wrote: |
evillrdnikon Samba Member
Joined: February 26, 2014 Posts: 180 Location: Las Vegas
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76938 Location: Sneaking up behind you
Posted: Thu May 18, 2017 5:58 pm Post subject: Re: GL 4 or GL 5 - "Official Gear Lube Topic" |
Are you surprised that they found Amsoil ranked best? After all it was funded by...... AMSOIL.
They tested for differential, VWs have a transaxle that includes the gearbox. _________________ Glenn
Member #1009
#BlueSquare |
vwracerdave Samba Member
Joined: November 11, 2004 Posts: 15308 Location: Deep in the 405
Posted: Thu May 18, 2017 6:08 pm Post subject: Re: GL 4 or GL 5 - "Official Gear Lube Topic" |
I wouldn't put much faith in anything written by Amsoil. Things have changed a lot in 10 years since that was written so a lot of it doesn't really matter much today. A lot of the info will help people understand what they need to look for in a gear oil today, so the article is not a total waste of time. _________________ 2017 Street Comp Champion - Thunder Valley Raceway Park - Noble, OK
Zundfolge1432 Samba Member
Posted: Mon Jun 12, 2017 4:15 am Post subject: Re: GL 4 or GL 5 - "Official Gear Lube Topic" |
vwracerdave wrote: |
I wouldn't put much faith in anything written by Amsoil. Things have changed a lot in 10 years since that was written so a lot of it doesn't really matter much today. A lot of the info will help people understand what they need to look for in a gear oil today, so the article is not a total waste of time. |
Just wondering why you have such a negative attitude towards Amsoil? If you have proof please share it. |
scottyrocks Samba Member
Joined: August 19, 2016 Posts: 2665 Location: Long Island, NY
Posted: Mon Jun 12, 2017 4:49 am Post subject: Re: GL 4 or GL 5 - "Official Gear Lube Topic" |
I took it to mean that anything informative written by a company that makes the product in question can be suspect. Not necessarily bad or negative, just suspect. |
Posted: Tue Jun 13, 2017 11:47 am Post subject: Re: GL 4 or GL 5 - "Official Gear Lube Topic" |
Actually he's been posting these little digs for years, it's time to put up or? |
gears Samba Member
Joined: October 28, 2002 Posts: 4391 Location: Tamarack, Bend, Kailua
Posted: Tue Jun 13, 2017 2:43 pm Post subject: Re: GL 4 or GL 5 - "Official Gear Lube Topic" |
It doesn't take a genius to see which companies have "gamed" the internet. _________________ aka Pablo, Geary
'90 Syncro Westy SVX
'87 Syncro GL 2.5
https://guardtransaxle.com |
Posted: Wed Jun 14, 2017 11:08 am Post subject: Re: GL 4 or GL 5 - "Official Gear Lube Topic" |
Comparative analysis or bullshit ask your doctor if it's right for you. |
Glenn Mr. 010
Posted: Wed Jun 14, 2017 11:15 am Post subject: Re: GL 4 or GL 5 - "Official Gear Lube Topic" |
gears wrote: |
It doesn't take a genius to see which companies have "gamed" the internet. |
RUSSIA?
Member #1009
#BlueSquare |
calvinater Samba Member
Joined: September 06, 2014 Posts: 3330 Location: 802 The Pointless Forrest
Posted: Wed Jun 14, 2017 1:35 pm Post subject: Re: GL 4 or GL 5 - "Official Gear Lube Topic" |
Glen is that available at walmart? _________________ "Albatross"! |
Posted: Wed Jun 14, 2017 2:25 pm Post subject: Re: GL 4 or GL 5 - "Official Gear Lube Topic" |
Zundfolge1432 wrote: |
I generally DO NOT support any companies that only sell thru distributorships or multi layer pyramid systems. The end result is the consumer gets scammed. Why can't you get it at any public Walmart, Autozone, NAPA, etc.? _________________ 2017 Street Comp Champion - Thunder Valley Raceway Park - Noble, OK
Posted: Thu Jun 15, 2017 6:46 am Post subject: Re: GL 4 or GL 5 - "Official Gear Lube Topic" |
Ok that's not the answer I am looking for. Here's an example to think about concerning mass marketing. I buy auto detail products direct from a company that makes them. I buy in concentrated form in gallon or five gallon quantities. I skip the distributor and retail level which adds cost. I get to custom mix the product depending on need. Unit cost per car is about 5 dollars, I use five dollars of product each car and charge you between 2 to 3 hundred for a bumper to bumper top to bottom detail. Should I be buying my products at retail? |
Casting Timmy Samba Member
Joined: August 04, 2012 Posts: 1221 Location: Kansas City, Kansas
Posted: Sun Jul 02, 2017 6:49 pm Post subject: Re: GL 4 or GL 5 - "Official Gear Lube Topic" |
The local buggy shop started selling Lucas gear oil, has anyone actually used this stuff before? Kind of surprised to see it as I haven't seen those oil gear oil gear spinning things in years. |
termuehlen Samba Member
Joined: May 02, 2012 Posts: 994 Location: Redwood City
Posted: Tue Jul 11, 2017 10:53 am Post subject: Re: GL 4 or GL 5 - "Official Gear Lube Topic" |
Gowesty has switched from recommending GL-4 to GL-5 now...
http://www.gowesty.com/tech-article-details.php?id=87 _________________ 1988 Westfalia automatic Subaru OBD1
1986 syncro tintop wbx |
Posted: Tue Jul 11, 2017 1:14 pm Post subject: Re: GL 4 or GL 5 - "Official Gear Lube Topic" |
I generally DO NOT support any companies that only sell thru distributorships or multi layer pyramid systems. The end result is the consumer gets scammed. Why can't you get it at any public Walmart, Autozone, NAPA, etc.? |
I used Amsoil for a little bit, it's not bottom of the barrel stuff and certainly not top shelf either. Actually a local garage sold it cheaper than I could get Syn at Walmart for a bit, but then he figured out he sold it at cost and I switched oils for the daily driver as Walmart oil became a lot cheaper again.
It is nuts how good they show their oil against everyone else, I don;t believe any of their test reports or info. I'm really surprised that Amsoil doesn't show their oil winning a taste competition against light beers by a large margin and then also showing it has less calories as well. |
udidwht Samba Member
Joined: March 06, 2005 Posts: 3779 Location: Seattle, WA./ HB, Ca./ Shizuoka, Japan
Posted: Wed Oct 18, 2017 10:30 am Post subject: Re: GL 4 or GL 5 - "Official Gear Lube Topic" |
Casting Timmy wrote: |
All the others are guilty of the same thing. Bottom-line Amsoil is still miles ahead of any conventional gear oil used. _________________ 1972 Westy Hardtop/Type-4 2056cc
96mm Biral AA P/C's~7.8:1CR
71mm Stroke
73 Web Cam w/Web solids
Bosch W8CC plugs
S&S 4-1 w/Walker QP 17862
3 rib 002 Trans
185R14 Hankook tires |
modok Samba Member
Joined: October 30, 2009 Posts: 26788 Location: Colorado Springs
Posted: Wed Oct 18, 2017 5:36 pm Post subject: Re: GL 4 or GL 5 - "Official Gear Lube Topic" |
I like the amsoil tests.
They tend to have an aroma of true science, far as the results usually are not what was expected and raise more questions than they answer and so forth.
However, if they won't sell to my distributors then I not going to buy any either.
I'm not going to buy oil from the back alley of some guys house. They should get a clue. |
77charger Samba Member
Posted: Tue Oct 31, 2017 9:34 pm Post subject: Re: GL 4 or GL 5 - "Official Gear Lube Topic" |
Have used swepco and Lat in my my buggy just had trans gone thru after 6 seasons of sand dune use some abuse and ring and pinion was perfect as were the gears.
Lat has been used the past 2 changes and gonna stay with it. _________________ Click to view image
Bugpack 4 seater rail
2275 built by me
Auto linea alm case,82 dpr crank wedgemated by DK machine
cb 5.4 h beams,12 pound DPR f/w,Slr xv294cam,cb straight cuts,hpmx 44s,40x35 heads ported by brothers machine |
