vwracerdave Samba Member
Joined: November 11, 2004 Posts: 15309 Location: Deep in the 405
Posted: Sun Oct 13, 2019 2:19 pm Post subject: Re: GL 4 or GL 5 - "Official Gear Lube Topic" |
I currently use Valvoline in all my transaxles. It is all I have ever used in the last 30 years. _________________ 2017 Street Comp Champion - Thunder Valley Raceway Park - Noble, OK
Zundfolge1432 Samba Member
Posted: Mon Oct 21, 2019 11:03 am Post subject: Re: GL 4 or GL 5 - "Official Gear Lube Topic" |
vwracerdave wrote: |
I currently use Valvoline in all my transaxles. It is all I have ever used in the last 30 years. |
I believe you, there are plenty of folks here stuck in the glory days of yesteryear. If you are still using Dino 80w90 the technology moved beyond you about 25 years ago. I got a rotary dial phone that still works too. |
Posted: Mon Oct 21, 2019 12:48 pm Post subject: Re: GL 4 or GL 5 - "Official Gear Lube Topic" |
Valvoline make both dyno and synthetic. Just because a company is 150 years old does not mean they don't modernize their products. _________________ 2017 Street Comp Champion - Thunder Valley Raceway Park - Noble, OK
73buggy Samba Member
Posted: Sun Nov 10, 2019 9:11 pm Post subject: Re: GL 4 or GL 5 - "Official Gear Lube Topic" |
Hello Glenn:
Then I can use on my MEX 2003 the Valvoline VV831 80W-90?
Soon I want to replace the tranny oil, the car has about 14,000 km.
Thanks |
68IHscout Samba Member
Joined: March 10, 2010 Posts: 3122 Location: santa ana ca
Posted: Sun May 17, 2020 6:06 pm Post subject: Re: GL 4 or GL 5 - "Official Gear Lube Topic" |
(Safe GL5 , amsoil m/t mtf5w30 )synthetic ,anyone ever use this in their transaxle? |
Posted: Mon May 18, 2020 9:47 am Post subject: Re: GL 4 or GL 5 - "Official Gear Lube Topic" |
68IHscout wrote: |
A link would be nice |
Posted: Mon May 18, 2020 10:05 am Post subject: Re: GL 4 or GL 5 - "Official Gear Lube Topic" |
Wildthings wrote: |
68IHscout wrote: |
i just found a list on page 26 on this thread of safe gl5 ,i was just curious if anyone has used it . |
jim martin Samba Member
Joined: January 14, 2004 Posts: 217 Location: Vancouver, BC
modok Samba Member
Posted: Mon Jun 15, 2020 9:03 pm Post subject: Re: GL 4 or GL 5 - "Official Gear Lube Topic" |
Will add to list thanks.
How does the viscosity compare roughly? VS, say, syncromesh or 75-90? |
Posted: Mon Jun 15, 2020 10:57 pm Post subject: Re: GL 4 or GL 5 - "Official Gear Lube Topic" |
modok wrote: |
Sounds like an 80w90 |
Posted: Tue Jun 16, 2020 1:27 pm Post subject: Re: GL 4 or GL 5 - "Official Gear Lube Topic" |
uploaded the technical data sheet to the above link for quick reference.
good info and i have not really noticed any difference cold warm or hot , shifts smooth all the time .
my ring and pinion still going _________________ B.C's fastest street legal vw , June 2006 Hot VW's feature car 9.81 sec at 145.26mph.
Sponsored by :
LUCAS OIL PRODUCTS http://www.lucasoil.com
KROC head porting services
Dialedinperformance.com
Airspeedparts.com topic http://airspeedparts.com/forums/index.php?topic=914.0 |
Slip356 Samba Member
Posted: Wed Jun 17, 2020 5:51 am Post subject: Re: GL 4 or GL 5 - "Official Gear Lube Topic" |
Talked with Vic Skirmants (356 transmission guru) yesterday about my 356 transmission that he is just finishing up. Should be shipped to me this week.
Asked what oil he recommends. He like Valvoline 80/90 standard gear lube or any other major or brand. As for synthetic, he say’s OK but might have leaks. |
Chickensoup Samba Member
Joined: January 06, 2018 Posts: 5368 Location: Good Hope, GA
Posted: Wed Jun 17, 2020 8:55 pm Post subject: Re: GL 4 or GL 5 - "Official Gear Lube Topic" |
Slip356 wrote: |
i thought that the whole synthetic and leakage idea was a myth. yes? no? maybe so? _________________ -'85 c10 5.3 LS, 222 cam, long tubes, x pipe, 3 inch spin tech's
'65 Tourist Delivery Build
'66 RIP
'69 RIP
Hosea 4:6 "My people are destroyed for lack of knowledge" |
Posted: Wed Jun 17, 2020 9:48 pm Post subject: Re: GL 4 or GL 5 - "Official Gear Lube Topic" |
Chickensoup wrote: |
Slip356 wrote: |
i thought that the whole synthetic and leakage idea was a myth. yes? no? maybe so? |
If you have an engine that seeps with 40wt in it and then go to a 0w30 oil it may leak a bit worse but probably not by much. I strongly suspect that it is the same for transmissions.
i swapped all my old engines over the synthetic between 10 and 20 years ago and none leaked noticeable worse than they had been before. Most cars dripped a lot of oil before the advent of PCV ventilation systems in the mid sixties, so as synthetic oils became more popular it would have been easy to blame synthetics for making older rigs leak extra oil even if the leaks didn't actually get worse. When I was a kid all roads had a dark oily buildup down the center of each lane, which was caused by both draft tubes and the engines of the time constantly dripping, yet in this day and age where synthetics and 0w20 dino oils are common that slick it totally missing because today's engines almost don't leak whether dino or synthetic oils are used. |
Bruce Samba Member
Posted: Sat Jun 20, 2020 1:35 am Post subject: Re: GL 4 or GL 5 - "Official Gear Lube Topic" |
GL-6! _________________
EverettB Administrator
Joined: April 11, 2000 Posts: 69829 Location: Phoenix Metro
Posted: Sat Jun 20, 2020 10:06 am Post subject: Re: GL 4 or GL 5 - "Official Gear Lube Topic" |
bruce I know what you are thinking ,I called them on this and since the only machine made to test the gl-6 is no longer in this world and product exceeded all gl-5 tests that's where they came up with the gl-6 rating.
regardless gl-5 /gl-6 rating , high torque load and easy shifting the product works very well in transaxles regardless of application _________________ B.C's fastest street legal vw , June 2006 Hot VW's feature car 9.81 sec at 145.26mph.
Sponsored by :
mukluk Samba Member
Posted: Sat Jun 20, 2020 1:54 pm Post subject: Re: GL 4 or GL 5 - "Official Gear Lube Topic" |
jim martin wrote: |
regardless gl-5 /gl-6 rating , high torque load and easy shifting the product works very well in transaxles regardless of application |
They're using false logic and false advertising then. If it had been previously tested properly and met GL6 spec then they'd be right to claim it, but if it's only been tested for GL5, no matter if it just barely met the requirements or it completely blew them out of the water, it still only meets GL5 spec. _________________ 1960 Ragtop w/Semaphores "Inga" |
modok Samba Member
Posted: Sat Jun 20, 2020 4:10 pm Post subject: Re: GL 4 or GL 5 - "Official Gear Lube Topic" |
False acusations....!
Prove it doesn't meet the spec.
The GL rating is fairly meaningless as far as determining if an oil is suitable for use in a syncronized manual transmission anyway. The 60 pages is proof of that.
On the other hand if it DOES say it works good, and it doesen't, then that's newsworthy. Closest thing I heard to that was maybe redline, maybe. |
evanfrucht Samba Member
Joined: July 24, 2016 Posts: 2180 Location: Laurel Canyon, CA
Posted: Wed Oct 21, 2020 9:50 am Post subject: Re: GL 4 or GL 5 - "Official Gear Lube Topic" |
Good deal alert! German made conventional GL5 by Liqui-Moly
$6.60 a quart currently with free shipping over $49.
https://www.ecstuning.com/b-liqui_moly-parts/manua...OAQAvD_BwE _________________ 1967 Bug ( the daily rod )
1964 Fury Wagon ( the pavement shredder ) |
