VW Tri-Power
1961bluebug
1961bluebug is offline
PostPosted: Thu Mar 13, 2008 2:42 pm    Post subject: Reply with quote
can we have a video with sound? Looks perfect!
enghof rambeling.
|82x94|
1961 Deluxe beetle, 1971 type 181, 1968 T2a Baywindow, 1973 Type 147 "Swiss Fridolin"(sold), 1966 Deluxe sedan (sold), 1983 "Silver Bug" edition (sold), 1961 beetle (sold)
Ninamashr
Location: City of Round Rock in the Great State of Texas
Ninamashr is offline
PostPosted: Fri Mar 14, 2008 11:14 am    Post subject: Reply with quote
I have to get together with one of my friends to make the video wth audio. Maybe next week?!
1957 Karmann Kabriolet "Franky"
1957 Allstate trailer
billb
billb is offline
PostPosted: Fri Mar 14, 2008 11:19 am    Post subject: Reply with quote
If you make it out to the aircooler "unofficial meeting" next Thursday we can make a video then.
Ninamashr
PostPosted: Fri Mar 14, 2008 11:25 am    Post subject: Reply with quote
Thx Bill I think I can do that. As long as it's not raining I should be able to go.
billb
billb is offline
PostPosted: Fri Mar 21, 2008 9:54 am    Post subject: Reply with quote
There is a higher quality version located here on Divshare that you can download. I'd embed but thesamba doesn't support the needed html embedding code. It will probably play slowly due to its size, but you can download the entire file to watch.
http://www.divshare.com/download/4076006-57f
Ninamashr
PostPosted: Fri Mar 21, 2008 12:02 pm    Post subject: Reply with quote
Thank you Bill! That is an awesome camera, I really appreciate it!
ProjectX
Accessory Nut
ProjectX is offline
PostPosted: Fri Mar 21, 2008 2:07 pm    Post subject: Reply with quote
It looks like fuel is gurgling through the filter Evil or Very Mad
Awesome job!
Eric
Even my nuts are plated.....
195? Project "X"
1954 Oval Convertible
Ninamashr
PostPosted: Fri Mar 21, 2008 2:23 pm    Post subject: Reply with quote
Yeah, I have to completely rebuild that fuel pump. I think a one way valve is leaking a bit. It's all the way full when I 1st start it in the mornings ,but, as I drive it the glass fills with air, not really sure why?!?!
mr. warehouse
mr. warehouse is online now
PostPosted: Fri Mar 21, 2008 10:23 pm    Post subject: Reply with quote
Maybe the pump can't keep up with 3 float bowls
Just a thought??
Banzai KG
Banzai KG is offline
PostPosted: Fri Mar 21, 2008 10:57 pm    Post subject: Reply with quote
You can get a higher quality on the YouTube videos, just add &fmt=18 to the end of the YouTube URL.
Example: http://youtube.com/watch?v=qVJer-4KbMs&fmt=18
Jim Kikuchi
Sunnyvale (near San Jose), CA
1964 Karmann Ghia coupe
V.V.W.C.A. - Golden Gate Chapter: http://www.ggcvvwca.org/
B.L.T.N. (Better Late Than Never) late model VW Club (San Jose/Santa Clara, CA): https://www.facebook.com/groups/bltnvw/
NorCal Aircooled Group (NAG) Facebook Goup: https://www.facebook.com/groups/NAGVW/
Ninamashr
PostPosted: Sat Mar 22, 2008 6:13 am    Post subject: Reply with quote
Just a thought??
Wow, I did'nt think of that, I'll have to check that out after I rebuild the pump.
thx
Splitdog
Samba Split Personality
Splitdog is offline
PostPosted: Sat Mar 22, 2008 11:52 am    Post subject: Reply with quote
The car should still be using the same 'amount' of fuel. 1 bowl or 3. I just checked my stock fuel pump yesterday. It filled a coffee cup in 15 seconds.
CH³NO²
Z = z² + C
Der Blitzkrieg Kafers
#notacallooker
mr. warehouse
PostPosted: Sat Mar 22, 2008 2:50 pm    Post subject: Reply with quote
I was just offering a suggestion.
Maybe a stock worn pump isn't pumping as much fuel...
69 Jim
69 Jim is offline
PostPosted: Sat Mar 22, 2008 4:24 pm    Post subject: Reply with quote
The more bowls, the more fuel.
Splitdog
Splitdog is offline
PostPosted: Sat Mar 22, 2008 4:55 pm    Post subject: Reply with quote
Not once they're full. The engine will only 'use' a certain amount. With three bowls, each one is putting out a little less. Either that or he's running really rich.
CH³NO²
Z = z² + C
#notacallooker
69 Jim
69 Jim is offline
PostPosted: Sat Mar 22, 2008 5:04 pm    Post subject: Reply with quote
I'm not too sure about that.
You have to change the air/fuel ratio to get a richer condition, not necessarily the cfm. For example, if you run a single 44 Weber on a 1915cc motor and you then run dual 44's, it does not mean you are running in a rich condition now. More fuel can be burned with two carbs so you will have more power.
Splitdog
Splitdog is offline
PostPosted: Sat Mar 22, 2008 5:09 pm    Post subject: Reply with quote
An engine is an air pump. It will only pass so much air. And 11-12:1 fuel ratio. Period. He's still got plenty of pump.
CH³NO²
Z = z² + C
#notacallooker
69 Jim
69 Jim is offline
PostPosted: Sat Mar 22, 2008 5:14 pm    Post subject: Reply with quote
I agree it has plenty of "pump". There are many larger motors running stock pumps with 48ida's. That wasn't my point.
Your previous statement concerning it running rich was incorrect. Wink
Splitdog
Splitdog is offline
PostPosted: Sat Mar 22, 2008 5:18 pm    Post subject: Reply with quote
You insinuated he was burning three times the fuel. He would need to be passing 36 times the air through in order not to be running rich. Sorry, I thought that was what you meant. Once the 3 bowls are full, he's probably only using slightly more fuel.
CH³NO²
Z = z² + C
#notacallooker
69 Jim
69 Jim is offline
PostPosted: Sat Mar 22, 2008 5:24 pm    Post subject: Reply with quote
Agreed. Hopefully maybe even less fuel if the efficiency is there.
Page 4 of 6
