Narrowing IRS...
Page: 1, 2, 3  Next
Merlin
Merlin is offline
PostPosted: Mon Jan 28, 2008 1:00 am    Post subject: Narrowing IRS... Reply with quote
's up all? Smile
I'm writing from South Africa, where IRS was not sold, and where we have very little info on IRS.
I've been reading this: http://www.germanlook.com/Html/Tech/Tech12NarrowingIRSArms.htm
...on narrowing IRS arms.
I do no want to use aircooled.net's custom arms, before that is suggested.
I have grafted an early double-spring plate setup into my '67 pan.
It is all that I could find here.
My rear wheels (EMPI 8s) stick out an inch or inch and a half, so I'm looking at this option.
My chassis builder is not keen to take on this job, and also wondered whether we would have to mess around with narrowing the driveshafts, etc.
Is it a straightforward-ish job of just cutting the arms, or do we have to modify driveshafts, etc.?
Thanks, Nic
the3rdrock.com - …musings, discoveries and postulating, by a restless itinerant in search of enlightenment.
iowegian wrote:
People who are allowed to have signature lines annoy me.
helowrench
helowrench is offline
PostPosted: Mon Jan 28, 2008 8:10 am    Post subject: Reply with quote
germanlook.com tech section has info with pictures.
Rob
Current VWs:
70 bug vert for wifey
73Thing bucket o rust
73 914 1.7
12 Passat 2.5 Highway cruiser
Merlin
Merlin is offline
PostPosted: Mon Jan 28, 2008 12:29 pm    Post subject: Reply with quote
Hey helowrench,
As in the link I posted? Very Happy
Yah, that's my reference, but it raised more questions for an IRS newb'. Wink
Cheers, N.
Flipper_1938
Flipper_1938 is offline
PostPosted: Mon Jan 28, 2008 5:23 pm    Post subject: Reply with quote
I'm in the same boat with the clearance issues on the rear. I think I'm going to get rid of the flange on the fender and roll the edge around a 1/8" steel rod. If that doesn't give me enough clearance, I'll widen my rear fenders a little bit.
Merlin
Merlin is offline
PostPosted: Tue Jan 29, 2008 1:13 am    Post subject: Reply with quote
Roll the flange? The outside edge of the fender?
If it makes any difference, I forgot to add that it's a '67. [Early shape]
I've sent a mail to a local guru asking him if he'll attempt the arm trick, as I'd prefer that over widened fenders - which imo look Shi-ite.
N.
helowrench
PostPosted: Tue Jan 29, 2008 8:29 am    Post subject: Reply with quote
Merlin, you are correct, I was not awake yet.
Looks to be a fairly straightforward job, but I see that they made a jig to keep everything lined up.
Rob
PS I rolled the fenderlips on my ghia with an aluminum baseball bat, using the tire as my backrest.
(use a T-ball bat, they are cheaper, and shorter, which helps)
Current VWs:
73 914 1.7
Bugs'n'Pugs
Bugs'n'Pugs is offline
PostPosted: Tue Jan 29, 2008 10:04 am    Post subject: Reply with quote
Rob
1978 Super Beetle Convertible (Project)
Post a Photo in the Forums
Rescue Man's Best Friend
helowrench
PostPosted: Tue Jan 29, 2008 3:20 pm    Post subject: Reply with quote
my turn to correct someone LOL Laughing
he posted it in the original post.
I see you need more coffee also.
Rob
Current VWs:
73 914 1.7
Merlin
Merlin is offline
PostPosted: Tue Jan 29, 2008 11:04 pm    Post subject: Reply with quote
*lol* @ the link saga.
I'm not keen on rolling fenders, and haven't yet heard back from my Guru mate - he sucks at email. Wink
Once I get his info, I'll post it up here for reference.
Cheers, Nic
westcoast-paul
westcoast-paul is offline
PostPosted: Wed Jan 30, 2008 12:42 pm    Post subject: Reply with quote
search here (this forum) for "narrrow 101"
type 3 automatic transaxle IRS LEFT (drivers) axle is what youa re looking for. you will need 2 of them. they bolt on to IRS stub axles.
get a set of extra stock trailing arms and narrow them 1.3-1.5" each side. this should work for you.
- Paul
Merlin
Merlin is offline
PostPosted: Wed Jan 30, 2008 11:03 pm    Post subject: Reply with quote
Thanks Paul,
Hmmm...I may have to save up for that lot. Sad
IRS here is seriously scarce.
Cheers, N.
helowrench
PostPosted: Thu Jan 31, 2008 9:31 am    Post subject: Reply with quote
Merlin, look for a Porsche 924 or early944 in the scrap yards.
the IRS components are almost identical, they vary only in the additional adjustments possible (you can adjust rear toe, camber, and small heaight adjustment) small issue with a couple of bolts clearing the shock tower, but a grinder fixes that.
Rob
Current VWs:
73 914 1.7
Merlin
Merlin is offline
PostPosted: Thu Jan 31, 2008 11:02 pm    Post subject: Reply with quote
Thanks Rob.
We need to import some scrapyards from you guys. Wink
I'll ask my mate in the US if he can source me some parts. I still haven't heard back from my machining guru here. Neutral
Cheers, Nic
Bruce
Bruce is offline
PostPosted: Thu Jan 31, 2008 11:31 pm    Post subject: Reply with quote
the IRS components are almost identical, ...
While the 924/944 TAs are indeed almost identical, they are not suitable for narrowing. They have a different internal reinforcement than a Beetle arm, making it extremely difficult to separate the bearing housing from the TA without destroying either.
Merlin
Merlin is offline
PostPosted: Thu Jan 31, 2008 11:36 pm    Post subject: Reply with quote
Good to know!
Thanks. Very Happy
N.
helowrench
PostPosted: Fri Feb 01, 2008 8:54 am    Post subject: Reply with quote
Thanks for the heads up Bruce.
I am ending up with an entire 924 for cheap, and was thinking of narrowing the arms before I install them. I willl have to set my backspacing on the rim alone then.
Rob
Current VWs:
73 914 1.7
Merlin
Merlin is offline
PostPosted: Mon Feb 04, 2008 12:11 am    Post subject: Reply with quote
OK, my VW guy here says he can narrow the arms, BUT...do I then have to modify the springplates and driveshafts too? Surprised
Sorry if it's a daft question, I'm clueless when it comes to IRS.
Here are pics of my arms...
Thanks, N.
westcoast-paul
PostPosted: Mon Feb 04, 2008 2:15 pm    Post subject: Reply with quote
if you want to go more than 1.5" then yes. actually - it depends on your wheel backspacing too, but for stock - 1.5" is no prob. just get 2 IRS T3 AT Left axles and cut / weld the rear trailing arms to match.
- Paul
Bruce
Bruce is offline
PostPosted: Tue Feb 05, 2008 12:12 am    Post subject: Reply with quote
The left T3 Automatic axle is 26mm shorter than a Beetle axle. This is a hair over 1". NOT 1.5".
I highly recommend you start with 71 and later single spring plate TAs. Narrowing the TA moves the wheel and tire closer to the spring plate. The extra spring plate that a 69-70 car has is extra crap in the way.
westcoast-paul
PostPosted: Tue Feb 05, 2008 1:47 pm    Post subject: Reply with quote
you can use the t3 at irs axles on the 1.5" narrowed trailing arms that aircooled sells. they confirmed that to me personally.
- Paul
Page: 1, 2, 3  Next
