2type2 Samba Member
Joined: June 02, 2002 Posts: 969 Location: SW Colorado
Posted: Wed Jan 30, 2008 2:43 pm Post subject: brake issues/star nut adjuster |
Hey ya'll! treating my 66 Westy to many new brake parts and found that the spring clip holding the star nuts in place is gone and the "ears" which held it down are fubar (PO hammer job). The question is how best to reattach the new one so it wont fall in between the shoe and drum some day. Tack weld?? or what-------the clip is apparantly spring steel and the adjuster unit ,bolted to backing plate, is cast iron..... compatability issues?
anybody got suggestions having done this yourself?TIA,Paul _________________ "A life of peace and happiness depends on your own gratefulness" |
Lind Samba Member
Joined: November 06, 2000 Posts: 9905 Location: idaho
Posted: Wed Jan 30, 2008 2:49 pm Post subject: |
spring steel will not hold a weld to other types of steel.
I usually just replace the whole backing plate, although someone else might have an easier solution. _________________ .
Wanted:
skramyrral Samba Member
Joined: April 12, 2006 Posts: 82 Location: Naples, Florida
Posted: Wed Jan 30, 2008 3:36 pm Post subject: |
on my 67 camper they were rivited on. I drilled out the old rivits and used pop rivits to hold the new ones on. Worked good for me. |
campingbox Samba Member
Joined: November 14, 2000 Posts: 10192 Location: Petaluma, CA
Posted: Wed Jan 30, 2008 7:42 pm Post subject: |
I assume you're talking about the rear stars. These were originally peaned in place. I usually clean up the old peans (I think you called them ears), slip a replacement in, and pean it in place. |
mattcuddy Samba Member
Joined: October 22, 2003 Posts: 2035 Location: Philly, PA
Posted: Wed Jan 30, 2008 7:49 pm Post subject: Re: brake issues/star nut adjuster |
2type2 wrote: |
and the "ears" which held it down are fubar...
and the adjuster unit ,bolted to backing plate, is cast iron..... |
From your comments, do you mean the ones at the rear? Like in the link below:
http://www.wolfsburgwest.com/cart/DetailsList.cfm?ID=211609185A
If so, yank out the old ones, use a dremel or hacksaw blade to "refresh" the grove it slides in. Tap it a new one (the ones in the link above don't fit, I made my own). Once it is in, use a chisel and peen down the edges of the groove down over the spring you just slid in. |
Posted: Wed Jan 30, 2008 7:50 pm Post subject: Re: brake issues/star nut adjuster |
damn, beat me to it. i'm a slow typer and link looker upper. |
Culito 11010101
Joined: December 07, 2006 Posts: 5863 Location: Columbia Missourah
Posted: Wed Jan 30, 2008 9:22 pm Post subject: |
All of my springs, front and rear, are broken off. I've been driving without any for quite a while...the adjusters have never moved. _________________ Copyright CJ Industries, Inc.
'64 standard w/2.0L type 4
'62 bug
johnnypan wrote: |
...dont pay no attention to Culito,he's a cornhole.. |
Posted: Wed Jan 30, 2008 9:54 pm Post subject: |
Culito wrote: |
All of my springs, front and rear, are broken off. I've been driving without any for quite a while...the adjusters have never moved. |
That does NOT sound safe. Any time I do a brake job, I run a tap and die through the star and the adjuster so they move like butter. That combined with anti-seize ensures I won't have to fight stuck adjusters anytime soon. |
Culito 11010101
Posted: Wed Jan 30, 2008 10:15 pm Post subject: |
I wasn't sure about it at first. But, I use a dab of heavy grease on the threads and they stay put. I check them often. _________________ Copyright CJ Industries, Inc.
'62 bug
johnnypan wrote: |
2type2 Samba Member
Posted: Thu Jan 31, 2008 3:41 am Post subject: Brake issues/star nut |
Thanks to all! I think Ill give some attempt at refurbishing the peens and trying to reattach as per original. Im working on the presumption that the engineers put them there for good reason, so I dont want to go without them. Although it is considerably heavier,i have found that the F+R drum brakes on my 66 Chevyvan work hard to make a stop. and with a VW single master cyl. system, I want no chances and best efficiency possible! _________________ "A life of peace and happiness depends on your own gratefulness" |
BarryL Samba Member
Joined: November 01, 2004 Posts: 14218 Location: Casa de Oro, California
Posted: Thu Jan 31, 2008 8:24 am Post subject: |
A ghetto way to get you by is to bugger up the brake threaded clevis part slightly with plier marks prior to insertion. Just to enough to create friction but not enough to keep the star from turning. |
KaMa Samba Member
Posted: Thu Jan 31, 2008 1:54 pm Post subject: |
hey,
i'm new here
I've just made them myself , just be sure to use a hard drill (titanium)
Spring metal is kinda tough
grtzz |
Posted: Thu Jan 31, 2008 4:00 pm Post subject: |
KaMa wrote: |
hey,
i'm new here
grtzz |
Beautiful.
One of Clara's buses had a broken off star and it always was backing itself down. I fixed it at some point and the problem went away. I for one am a big fan of safe, reliable, good working brakes and do my best to keep them functioning as they should. |
BarryL Samba Member
Posted: Thu Jan 31, 2008 4:26 pm Post subject: |
KaMa
New but smart. Nice pieces. |
j.pickens Samba Member
Joined: December 03, 2002 Posts: 9787 Location: Exit 7, New Jersey
Posted: Thu Jan 31, 2008 6:42 pm Post subject: |
Isn't it more of a V shape in line with the long axis of the spring? _________________ Founder and Chairman Emeritus, ECMSAS
BeaterBarndoor wrote: |
i wish more people would actually drive their vws rather than just talking about what they have in the garage. |
Red Fau Veh wrote: |
If you've seen one sunroof swivel seat kombi, you've seen them all! |
Posted: Thu Jan 31, 2008 8:26 pm Post subject: |
j.pickens wrote: |
Isn't it more of a V shape in line with the long axis of the spring? |
On the rear springs, yes. Looks like he's making one ton front springs. |
Posted: Thu Jan 31, 2008 9:11 pm Post subject: |
campingbox wrote: |
j.pickens wrote: |
oops, too new for me... _________________ Founder and Chairman Emeritus, ECMSAS
Posted: Thu Jan 31, 2008 9:13 pm Post subject: |
j.pickens wrote: |
campingbox wrote: |
j.pickens wrote: |
oops, too new for me... |
Thought you had a baywindow beam under that deluxe? |
Posted: Thu Jan 31, 2008 10:54 pm Post subject: |
campingbox wrote: |
j.pickens wrote: |
campingbox wrote: |
j.pickens wrote: |
I do, but I don't remember the adjuster springs looking like that. I'll pay attention this spring when I grease the front bearings. _________________ Founder and Chairman Emeritus, ECMSAS
jeremyrockjock Samba Towbar Builder
Joined: January 01, 2002 Posts: 5008 Location: Richmond, Verjinya
Posted: Fri Feb 01, 2008 11:28 am Post subject: |
Bay drum brakes are basically the same as late split. _________________ Why buy what you can build.
Step away from the fiberglass and no one gets hurt!! |
