coolant pipe leaks
m2008s
m2008s is offline
PostPosted: Thu Jan 31, 2008 2:03 pm    Post subject: coolant pipe leaks Reply with quote
i have probably 3 coolant pipe leaks now, thanks salt. theyre the all metal ones as i have an 84 1.9 wbx. has anyone just put good heavy duty hose in its place? let me know. its hard to find a good set of pipes, none of the junkyards have them.
if not, what else is there i can do? i have 3 leaks in the feed pipe and a leak on the front most side of the passenger side head. i thought a head gasket blew but it doesnt smoke and starts fine, i havent looked much but it looks like that its leaking from a hose or pipe or something there? its running down the side and along the bottom of the head itsself, right on the seam. according to a diagram its either the hose form the head to the T for the rear heater or the crossover pipe and the T for the rear heater. had anyone had a head leak so bad it makes a 1 or 2 inch diameter puddle on the ground within 30 mins or so of being parked? like i say, the van doesnt smoke, runs and idles fine, starts quick, etc. let me know.
http://www.vanagain.com/19lchc.htm -diagram...
thanks
mike
View user's profile Send private message Visit poster's website AIM Address Classifieds Feedback
mightyart
mightyart is offline
PostPosted: Thu Jan 31, 2008 2:12 pm    Post subject: Re: coolant pipe leaks Reply with quote
Do a search on stainless steel, you will get your answer.
Another argument on the subject isn't needed, not your fault, oil, tires and coolent pipes seem to bring out the passion in some board members.
And I haven't experianced it but I have heard of head leaks that bad, someone else will comment on it.
m2008s
m2008s is offline
PostPosted: Sat Feb 02, 2008 12:20 pm    Post subject: Reply with quote
thanks, ill keep checking for posts. turns out i dont think my head is leaking, i think its a piece of hose to the rear heater.
