Very rotten Split panel.
baz76
baz76 is offline
PostPosted: Mon May 11, 2020 3:28 pm    Post subject: Re: Very rotten Split panel. Reply with quote
Savage work! What are you doing with the original gearbox set up?
BusJunky
BusJunky is offline
PostPosted: Thu May 14, 2020 9:37 am    Post subject: Re: Very rotten Split panel. Reply with quote
Damn, Homie! Thats a lot of hard work. Way to keep at it!
Leroux's Autowerks “like us on fb”
https://m.facebook.com/Lerouxs-Autowerks-942149562555768/?ref=bookmarks
Posty
Posty is offline
PostPosted: Fri May 15, 2020 5:59 am    Post subject: Re: Very rotten Split panel. Reply with quote
last few bits of required metal arrived. Looking forward to getting these in.
Tony C
http://www.facebook.com/tonys.vw.toys/
78 Westy
64 split panel project
64 Karmann Ghia
baz76
baz76 is offline
PostPosted: Fri May 15, 2020 7:34 am    Post subject: Re: Very rotten Split panel. Reply with quote
Nice. Silver weld panels?
Posty
Posty is offline
PostPosted: Sat May 16, 2020 3:11 pm    Post subject: Re: Very rotten Split panel. Reply with quote
Yep weld through primer.
Corners started. D post as expected need lots of work.
A lot of bits still missing back here.
Cleaned some of the primer off the side to check the sign writing out. So sorry I didn't preserve more of the original paint.
Tony C
78 Westy
64 Karmann Ghia
baz76
baz76 is offline
PostPosted: Sun May 17, 2020 12:39 pm    Post subject: Re: Very rotten Split panel. Reply with quote
Nothing broken inside that gearbox, the bearings in the reduction boxes were shot though and look like they were the originals. Perhaps the reason it was parked was noisey boxes.
Posty
Posty is offline
PostPosted: Sat Jan 16, 2021 1:10 pm    Post subject: Re: Very rotten Split panel. Reply with quote
Pottering away on the old girl and collecting all the missing parts. Maybe this year will be her year.
I had hopped to save the d posts but decided to replace them in the end. as they were toast and thankfully the panels are now available.
Replaced the ends of both chassis legs so id have something nice and solid to weld the d-posts too.
Lots of fun trying to line all the rear up. I now have both the d-posts welded to the top and lining everything up at the bottom before I commit to welding . Happy to have a bit to progress. I have a straight axle conversion complete and in. just to make sure it was all good. Starting making up the wiring loom.
Beam ready to build brakes back up.
I can actually see and end in sight.
Tony C
78 Westy
64 Karmann Ghia
Posty
Posty is offline
PostPosted: Sat Jan 23, 2021 12:37 pm    Post subject: Re: Very rotten Split panel. Reply with quote
Got the corners in. gaps are far from perfect but delighted to have them in. I finally have the external box complete. Now i am missing a lot of internal metal but a good days work.
Tony C
78 Westy
64 Karmann Ghia
LAGrunthaner
LAGrunthaner is offline
PostPosted: Sat Jan 23, 2021 3:40 pm    Post subject: Re: Very rotten Split panel. Reply with quote
Keep up the great work Posty! Nice wood stove to keep your warm and pushing through your hard work even in winter. Looks to be 32 degrees in Ireland today, about the same here in New Jersey, USA Very Happy
American Red Cross Safe And Well link:
https://safeandwell.communityos.org/cms/index.php?...OSmeUzh8l4
Maui Roadsters VW Logo
www.mauiroadsters.com
Lind wrote:
BulliBill
BulliBill is offline
PostPosted: Sat Jan 23, 2021 3:59 pm    Post subject: Re: Very rotten Split panel. Reply with quote
Awesome determination! You're getting there!
If this pandemic ever lightens up I gotta get back to Ireland and among other things (our family has a vacation home in Midleton, Co, Cork that none of has has been in for years!) it would be fun to see your progress in person! Keep up to great work!
Long live the P and T Panel!
Bill Bowman
Mission VW - San Fernando
Thornton VW - Stockton
Thanks for any help!
jeremyrockjock
Samba Towbar Builder
jeremyrockjock is offline
PostPosted: Sat Jan 23, 2021 6:13 pm    Post subject: Re: Very rotten Split panel. Reply with quote
good to see you are back at it
Why buy what you can build.
Posty
Posty is offline
PostPosted: Mon Jan 25, 2021 12:01 am    Post subject: Re: Very rotten Split panel. Reply with quote
Rear tube closing panels made and installed. Also finished the final little bit of the long side.
Have a rear end.
Tony C
78 Westy
64 Karmann Ghia
Posty
Posty is offline
PostPosted: Thu Jan 28, 2021 12:35 pm    Post subject: Re: Very rotten Split panel. Reply with quote
We have an engine bay .. I have included some of the earlier work on the same area. Its been a journey.
Tony C
78 Westy
64 Karmann Ghia
mandraks
mandraks is offline
PostPosted: Thu Jan 28, 2021 12:47 pm    Post subject: Re: Very rotten Split panel. Reply with quote
did you lose the VIN number? it should be right where your hand is.
regards
Uli
baz76
baz76 is offline
PostPosted: Thu Jan 28, 2021 2:28 pm    Post subject: Re: Very rotten Split panel. Reply with quote
Top job Tony getting close to running out of stuff to weld
Posty
Posty is offline
PostPosted: Thu Jan 28, 2021 3:02 pm    Post subject: Re: Very rotten Split panel. Reply with quote
Irish made bus didn't have it stamped or this one did not anyway only the plate in the bay. I have it but its tough to read the plate is crusty.
Tony C
78 Westy
64 Karmann Ghia
mandraks
mandraks is offline
PostPosted: Thu Jan 28, 2021 4:39 pm    Post subject: Re: Very rotten Split panel. Reply with quote
interesting, did not know that
regards
Uli
Blue Baron
Blue Baron is offline
PostPosted: Thu Jan 28, 2021 7:45 pm    Post subject: Re: Very rotten Split panel. Reply with quote
It's a CKD bus, so it's going to have some weird stuff.
nshaddox wrote:
Pictures to follow because no one reads words anyways.
lil_azza
lil_azza is offline
PostPosted: Mon Feb 01, 2021 12:52 pm    Post subject: Re: Very rotten Split panel. Reply with quote
great work keep it up
70 early bay
71 deluxe beetle
58 rhd beetle
69 karmann cabriolet
Posty
Posty is offline
PostPosted: Sat Feb 06, 2021 12:03 pm    Post subject: Re: Very rotten Split panel. Reply with quote
Preparing the donor panel for above the engine bay. Adding a bay window engine hatch before going in. lots of bits missing around the edges. The bus it came out of had the spare wheel well. I hope to use the bit I cut out for the hatch to make the ends meet. Also made the overflow pipe. Beer Time.
Tony C
78 Westy
64 Karmann Ghia
Page 8 of 9
