WVVWFERG Samba Member
Joined: December 02, 2005 Posts: 233 Location: Charleston, West Virginia
Posted: Mon Feb 04, 2008 2:58 pm Post subject: sliding glass installation |
The "search feature" is temporarily not functioning, so I'll risk asking.I have an 86 westy that needs the sliding glass portion of the sliding window INSTALLED (we got the replacement glass out of a window that was out of the van, so there was some 'wiggle room'). Who can tell me how to install it?? thanks |
Posted: Mon Feb 04, 2008 3:53 pm Post subject: |
The sliding side windows are installed exactly like all of the other glass in a T3. In fact, it's a little easier than installing the other glass because it has a frame around it that supports the glass. This means that you don't need to be nearly as careful when doing the install.
Here is a good tutorial:
http://www.offroaders.com/info/tech-corner/project-cj7/project-cj7-windshield.htm _________________ "Sometimes you have to build a box to think outside of." - Bruce (not Springsteen)
mightyart Samba Member
Joined: March 24, 2004 Posts: 6188 Location: Portland, Oregon
Posted: Mon Feb 04, 2008 5:06 pm Post subject: |
If you are just trying to put in the sliding part, it won't work, you have to install the whole window. |
Pascal Samba Member
Joined: January 13, 2006 Posts: 825 Location: Fredericton, NB, Canada
Posted: Mon Feb 04, 2008 7:54 pm Post subject: |
You need to take the window channel material out first. This will give you more room to get the glass in. You also need to use some carpenters clamps to spread the window frame apart a little and then your replacement window will fit in. It helps if you have a helper to hold the clamps on the edge of the window frame while you work. Before you install it make sure the plastic guides are in the bottom part of your replacement window. _________________ '84 Westy - 2.2wbx, GT Torque-Biasing Differential
'91 EA Cabby
Posted: Mon Feb 04, 2008 8:12 pm Post subject: |
Jeez, I need to read this stuff better. I missed the part about the "sliding glass portion of the sliding window". Sorry about that! _________________ "Sometimes you have to build a box to think outside of." - Bruce (not Springsteen)
Mac_Daddy_Westy Samba Member
Joined: October 27, 2011 Posts: 154 Location: San Antonio, Tx
Posted: Wed Dec 25, 2019 9:51 pm Post subject: Re: Sliding glass & Felt installation |
Greetings folks,
read many post about window removal, its fairly straight forward, just with lots of patience is warranted.
Installing the felt strips is easy as well, see pics. Now installing the sliding window is a bit tricky, especially around the corners, I used the rope technique with lots of vasiline, worked but I did rip the inside lip of the seal a bit, but can be repair with glue, the important things is that the outer lip is not rip so not water leaking in.
Need to use popsical sticks to lessen the tension near corners, would make it much easier to get the inner seal lip over the panel.
I also used Sika flex on the bottom outer window sill to prevent water from pooling there.
hope this info helps
_________________ '87 Westy with 2.5 Subi (auto trans) |
