Which Propex would you run for Winter Camping? |
HS2000 with 6500 btu and 1.9kwatts for $725 |
51% |
[ 17 ] |
HS2800 with 9500 btu and 2.8kwatss for $875 |
48% |
[ 16 ] |
Total Votes : 33 |
montanasurfer Samba Member
Joined: March 06, 2014 Posts: 319 Location: United States
Posted: Fri Dec 08, 2017 2:35 pm Post subject: Re: Which Propex: HS2000 or HS2800 |
[email protected] wrote: |
Seems to me you need more air flow. I am thinking you don't have sufficient circulation. What I mean is that you don't have a good return for your cold air to circulate. I would think that having a duct for cold air return would help. I would have your hot go towards your cabinets and run the cool were your hot is now. Never used a propex but a little buddy would easily heat up the van in 20-30 degree weather no window insulation pop top up and I think it's only 3800 btu |
That's what I'm thinking. I'm thinking the hot air is rising up from the output vent right beneath the bed and staying there long enough to get pulled back into the cool air intake. I hypothesize that the area under my bed gets nice and toasty while the rest of the van only slowly heats up as heat "spills out" from underneath the bed. |
Joined: April 29, 2015 Posts: 704 Location: Berkeley Ca
Posted: Fri Dec 08, 2017 3:09 pm Post subject: Re: Which Propex: HS2000 or HS2800 |
I actually think that your heater is starved for cold air. So lets say air goes in then comes out. And lets say it goes up by 1 degree per pass so in 30 out 31 degrees per 1/4 cubic feet. Total volume of van lets say 10x5x8 400 cubic feet. So you would need 1600 passes to raise temp by 1 degree. Once total temp is 31 then heater would raise to 32 and so on. If inlet volume is reduced it would take more total passes.
If you look at a house with forced air you will see inlet that is much larger than individual outlets, I'm guessing they match in area. I'm thinking that your heater is not drawing enough air and that there is a sensor limiting total heat output and its only heating a small percentage of it's total capacity. So if only 1/16 cubic feet is being heated (drawn in through inlet) per pass it will be on a long time to heat up your 400 cubic feet of air instead of 1600 passes it would require 6400 passes.
So it's not about heating air in one spot then moving and heating onother spot. Rather it's heating the total area. Remember heat moves from hot to cold. |
danfromsyr Samba Member
Posted: Fri Dec 08, 2017 4:34 pm Post subject: Re: Which Propex: HS2000 or HS2800 |
this is the heated output in Mom's espar install.
it's T-d into the base as well in case bedding blocks the outlet air still escapes..
more pics on page3 in my gallery
Abscate wrote: |
Witchdoc007 Samba Member
Posted: Fri Jun 22, 2018 5:58 pm Post subject: Re: Which Propex: HS2000 or HS2800 |
I installed a Propex HS2000 in a my rig a few years ago and used it for less than 20 hours tops when it failed. I had to pay a technician to uninstall it and then send it to the manufacturer (in England) because there was no local dealer and the factory rep said they wouldn't know what was wrong unless I sent it back. That cost $230. They then quoted me about $200 to replace the unit's logic board, and then I would also have to pay the shipping back because they would not warranty it since it was over a year old. This would amount to about the same cost as a brand new one. I will never buy another Propex product. |
ledogboy Samba Member
Joined: September 19, 2005 Posts: 578 Location: Scappoose, OR / Oakland, CA
Posted: Fri Jun 22, 2018 6:10 pm Post subject: Re: Which Propex: HS2000 or HS2800 |
Witchdoc007 wrote: |
Sweet first post! _________________ 1986 Westy Weekender
Now a full camper
1.8t Syncro conversion
Some people call him Maurice... |
westyventures Samba Member
Joined: December 29, 2004 Posts: 2306 Location: Oregon Outback
Posted: Sat Jun 23, 2018 12:15 am Post subject: Re: Which Propex: HS2000 or HS2800 |
Your experience reads rather odd and dishonest: Did you buy the unit in the USA? If so, did you attempt to contact ME - the USA distributor and warranty/repair center? Apparently not - OR you bought it on eBay from a UK seller who is forbidden to sell in the USA. These 'gray-market' units are not warrantied in the USA. Also, the warranty is TWO YEARS. No units sold inside the USA would have to 'be sent back to England' for warranty. Further, your quotes for shipping and a PCB are both false. Please explain the precise situation further. |
mugford Samba Member
Posted: Sat Jun 23, 2018 12:38 am Post subject: Re: Which Propex: HS2000 or HS2800 |
Hi Karl,
Bought a Propex and it works great but the vent covers broke within days, they couldn't withstand light finger pressure before the webbing broke. Can you recommend a stronger replacement that fits in the existing hole?
http://www.westyventures.com/hs2211%20(23).JPG |
Posted: Sat Jun 23, 2018 12:50 am Post subject: Re: Which Propex: HS2000 or HS2800 |
mugford wrote: |
Hi Karl,
Where were they installed that they received constant finger pokes? I've not seen on that fragile, unless it was already fractured by some other means.
The only option in that hole size is those or the 'closable' version, shown on the right here:
The 2000 style square / rotating ones can be used but require a 3.75" hole. |
Posted: Sat Jun 23, 2018 10:51 pm Post subject: Re: Which Propex: HS2000 or HS2800 |
I broke some of it during the install not knowing how fragile they were. The rest was taken care of by my 6yr old boys... urgh.
I think a replacement webbing made out of CNC'd aluminum would be a nice little project... : )
Thanks |
ianNJ Samba Member
Joined: December 31, 2015 Posts: 149 Location: New Jersey
Posted: Sat Nov 30, 2019 4:06 am Post subject: Re: Which Propex: HS2000 or HS2800 |
First real night with the Propex HS2000
The unit is under the bench seat. Both ports are right there coming out under the seat. The thermostat/switch is in the back of the trunk area. It is 23 F degrees. The unit temp is about 3/4. We have the window insulation on and top down. No other added insulation to door panels yet.
I’m sleeping in boxers and a t shirt and am comfortable. My wife is in a T and sweats and not complaining at all. The van fees perfect! The unit has not come off but you can feel the temp by the switch is definitely cooler vs where the main heat is.
I’m a happy camper! _________________ --Hardwork Pays Off--
90 GL Frankenstine w/Boxeer 2.0 TDI CR, Peloquin TBD
RIP - 2003 Eurovan
Instagram @ian.Surfside
*if you known someone that struggles with addiction let me know. |
Syncro Jael Samba Member
Posted: Sat Nov 30, 2019 10:17 am Post subject: Re: Which Propex: HS2000 or HS2800 |
Having a heater is a game changer for winter camping. Open up the cupboard doors so that stuff won't freeze when it really gets cold. Also hanging a divider between the chairs and sleeping area will let you stay warmer and conserve propane.
Cheers. _________________ 1987 Syncro Westfalia Hightop - NAHT
Subaru EJ25 Forged Frankenmotor, Triple Knob.
Jael = (Mountain Goat) |
SSWesty Samba Member
Joined: August 20, 2008 Posts: 732 Location: Bellevue
Posted: Sat Nov 30, 2019 11:25 pm Post subject: Re: Which Propex: HS2000 or HS2800 |
Syncro Jael wrote: |
hanging a divider between the chairs and sleeping area will let you stay warmer and conserve propane. |
+1. We hang a blanket to block off the cab area from the rest of the van when it's in the lower 30s. The propex was our best upgrade. Happy Winter Camping! |
Posted: Sun Dec 01, 2019 12:47 am Post subject: Re: Which Propex: HS2000 or HS2800 |
+++11
and not even for winter camping.. slept comfortably in Sept in 8in snowfall in Yellowstone and 18* nights at Grand Canyon's north rim.. I use the top bunk and am comfy.
Cheers. |
Abscate wrote: |
dobryan Samba Member
Joined: March 24, 2006 Posts: 16508 Location: Brookeville, MD
Posted: Sun Dec 01, 2019 7:00 am Post subject: Re: Which Propex: HS2000 or HS2800 |
An easy way to block off the upper bunk when sleeping down below is to fold out the bed platform then grab the far end of the cushion on the platform and fold it back to the front. The snaps act as a hinge point and you can push the cushion tight up against the front of the pop top. Works great and only takes 30 seconds to undo when you get up. _________________ Dave O
The Western Syncro build
