lifeisgoodin29 Samba Member
Posted: Thu Feb 07, 2008 9:08 pm Post subject: hardtop |
Does anybody know if you need to remove the soft top pivots to install a hardtop. Or do they just slip over the pivots. Thanks Eric |
Ron Domeck Samba Member
Joined: August 05, 2007 Posts: 1466 Location: louisville Ky
Posted: Fri Feb 08, 2008 10:10 am Post subject: |
If you are using a VWoA hardtop it will set on with no modification. You cannot use the factory hardtop with a factory roll bar. Don't know about the Fiberjet tops. |
uberautowerks Samba Member
Joined: October 17, 2005 Posts: 1600 Location: Longmont Co
Posted: Fri Feb 08, 2008 10:26 am Post subject: |
Correct, an original VW factory hard top will fit with zero modifications.
Incorrect, sorry, a factory hard top WILL fit with a factory roll bar. However a factory top will NOT fit with an aftermarket roll bar. The factory roll bar has "Y" shaped rear bars. _________________ --- The major difference between a thing that might go wrong and a thing that cannot possibly go wrong is that when a thing that cannot possibly go wrong goes wrong it usually turns out to be impossible to get at and repair.
- Douglas Adams -
'74 Thing (White)
'71 Single cab (White too)
'70 Weekender (White three)
'05 Evolution VIII (White also!!!)
'68 F-250 (White over black) |
Posted: Fri Feb 08, 2008 10:58 am Post subject: hardtop |
Thanks guys, I think it is a voa top. eric |
Posted: Fri Feb 08, 2008 12:54 pm Post subject: |
Hey, your an Eric too? I'm Eric.
Anyway, the VWoA top is easy to spot, 5 ribs on the roof and a metal "hoop" around the rear which bolts to the body. _________________ --- The major difference between a thing that might go wrong and a thing that cannot possibly go wrong is that when a thing that cannot possibly go wrong goes wrong it usually turns out to be impossible to get at and repair.
- Douglas Adams -
'74 Thing (White)
eurotrashrabbit Samba Member
Joined: March 06, 2005 Posts: 46 Location: Sterling VA USA
Posted: Fri Feb 08, 2008 1:24 pm Post subject: |
I had a roll bar on on my 73 and had a factory hardtop and it fit with a Rogue accessories roll bar. I doubt this company is still around |
ZIACOMM Samba Member
Posted: Thu Feb 14, 2008 10:44 pm Post subject: |
any pictures of a factory roll bar? |
lowsquare Samba Member
Joined: May 29, 2004 Posts: 287 Location: Queen Creek, AZ
Posted: Fri Feb 15, 2008 11:10 am Post subject: |
I believe the VW accessory roll-bar is a 4 point. Basically a hoop at the front with 2 legs to the rear. Here is a picture from the '73 Thing Accessory Brochure.
I believe this is an actual picture of one from the gallery...
This is what I have in mine. It's a 5 point and I don't know if a hardtop will work with this type of bar or not? I have no problem with the soft-top at all...
_________________ PRAISE THE LOWERED.
1973 THING |
Posted: Fri Feb 15, 2008 1:21 pm Post subject: hardtop |
Thanks to all who helped me with this. I appreciate all the information. Eric |
laughatgravity Samba Member
Joined: September 19, 2009 Posts: 95 Location: Philly burbs
Posted: Wed Jul 28, 2010 8:19 am Post subject: |
lowsquare wrote: |
I thing I have the same 4 point bar (maybe be after market any way to tell?. Doesnt seem to fit with factory (? metal bracing, proper supports) hardtop |
yellow73kubel Samba Member
Joined: August 17, 2008 Posts: 789 Location: Columbia, SC
Posted: Wed Jul 28, 2010 5:23 pm Post subject: |
^ That is most likely a Thing Shop "show bar". Mine is roughly the same thing, minus the "V" bars. I have a factory hard top that was cut by a previous owner to fit the cage. I posted a few pictures in this thread by carterzest: http://www.thesamba.com/vw/forum/viewtopic.php?t=398522&highlight=roll+bar.
There is a lot of confusion over exactly what is a "factory" roll bar. Most people agree on the 3-tube 4-point design with brackets to bolt to the door pillars, as lowsquare said. There is no part number or documentation to confirm which cages are and are not factory. That said, I don't believe that VW ever added the "V" bars to their cages. |
SilverThing Samba Member
Posted: Wed Jul 28, 2010 5:49 pm Post subject: |
The issue with 'factory' roll bars is that they weren't factory per se. They were dealer installed options. My Thing came with one of the 5 point roll bars (not TTS remake) from the dealership, but a previous owner removed it before I bought the vehicle. Thingshop's remake has bend at the door pillar in the front hoop that the original 5 points did not have.
Two pages from a dealer accessory brochure showing the 5 point version of the roll bar:
_________________ "I like how everyone likes talking about Zeke's Thing yet he's the only one that's ever seen it." - Katie
"I've seen pictures..." - Jeremy |
Joined: February 21, 2003 Posts: 868 Location: Clifton Park NY Saratoga County
Posted: Thu Jul 29, 2010 6:55 pm Post subject: |
There are actually two factory roll bars, a 4 point, mainly used on the east coast and a five point used mainly on west coast.
if they use backing plates, they are most likely original.
the 4 points have two hoops not like the 4 pt in the picture. _________________ Michael Basso
http://www.thingparts.com
New and Used VW Thing Parts Free advice
CALL 518 630 0173 |
Posted: Thu Jul 29, 2010 8:17 pm Post subject: |
And just to add to the confusion...
As far as I know, my Thing traveled from Oregon to North Carolina before I picked it up. It has a 4 point cage with two hoops and backing plates. Is there any chance of that being a dealer install? |
Posted: Fri Jul 30, 2010 7:03 am Post subject: |
the factory 4 pt roll bar normally comes straight down in back. and also looks very similiar to the one in the catalog picture, so maybe there were three dealer roll bars.
i guess if its on a thing it must be a thing roll bar _________________ Michael Basso
CALL 518 630 0173 |
