Kadrons on a Type IV
m. bob
m. bob is offline
PostPosted: Fri Feb 08, 2008 11:27 am    Post subject: Kadrons on a Type IV Reply with quote
Anyone have any pictures or instructions on installation of Kadrons ? I'm having problems with the linkage.
melville
melville is offline
PostPosted: Fri Feb 08, 2008 12:35 pm    Post subject: Reply with quote
Use the search!
http://www.thesamba.com/vw/forum/viewtopic.php?t=188705&highlight=
Are you installing on a carbed application (74 and earlier US) or are you replacing FI?
2000 M Roadster
75 R75/6
65 Standard Micro
57 Sedan
TEXABUS
TEXABUS is offline
PostPosted: Mon Feb 11, 2008 8:33 am    Post subject: Reply with quote
The Kads are simple, reliable, easy to dial in and give great performance.
David
[/img]
79 Westy
72 Panel
60 Panel
busman78
busman78 is offline
PostPosted: Mon Feb 11, 2008 10:44 am    Post subject: Reply with quote
Texabus, nice set up, although the fuel pump location would be a bit safer outside the engine compartment. Which size Kadrons did you use?
TEXABUS
TEXABUS is offline
PostPosted: Mon Feb 11, 2008 4:32 pm    Post subject: Reply with quote
40MM with 32 vents, 65 idle and 165 mains. She runs cool and I get about 20MPG. The rest of the combo is 2L, bigger valves and a RAT9550
cam.
79 Westy
72 Panel
60 Panel
busman78
busman78 is offline
PostPosted: Mon Feb 11, 2008 4:44 pm    Post subject: Reply with quote
Thanks, that is the combo I am building, using a set of Hoffman 42X36 heads.
