Posted: Mon Jan 20, 2003 9:05 pm Post subject: What bus do I have. |
I am bran new to VW's. I just bought a 72 bus to cruise the country in this summer. How do I tell what it is. Ie, westfalia or what. It has a camper. Thats about all the info I know. Thanks for any help. Also, what are the first things to inspect to make sure it will be worthy of a long trip? Thanks
matt |
Posted: Mon Jan 20, 2003 11:09 pm Post subject: What bus do I have. |
check out www.wetwesties.org
they have a links site and there they have a buyer's guide checklist. I know you already have bought it but it is a really good place to start as far as what to look for regarding potential problems...good luck
joey |
chabanais Samba Member
Posted: Tue Jan 21, 2003 2:07 am Post subject: What bus do I have. |
Make sure the timing is right, the points are set, the valves are adjusted, CV joints, brakes, and carb are good. Maybe bring extra shift, brake, and gas cable, some tools, gas can, maybe install an oil sump. Take some 100 mile test drives before! Buy some books on it like Muir's Idiot's Guide and/or Bentley manual. |
vwsrus Samba Member
Posted: Tue Jan 21, 2003 5:59 am Post subject: What bus do I have. |
Chabanais is right but he left out one thing. Compression. Check it. It's like the motors heart beat. If it's weak, your bus won't last much longer. And replacing an engine on the road isn't all that much fun.
Also, join a local club. Attend their meetings a make friends with folks. They will be able to help you out too. |
TimGud Samba Member
Joined: March 03, 2002 Posts: 6459 Location: Rio Rico Arizona
Posted: Tue Jan 21, 2003 7:23 am Post subject: What bus do I have. |
Engine compartment seals need to be in perfect condition,especially on a heavy camper.If you can see light between the engine compartment tin and the ground anywhere it needs to be plugged up somehow,and print out the A.I.R.S. list before you go on any long trips.Good luck |
BusMonkey Samba Member
Posted: Fri Jan 24, 2003 6:22 am Post subject: What bus do I have. |
To answer the type-of-camper question, your biggest clue for the '72 will be the type of top - is it a pop-top, high roof, of hardtop? What stuff does it have in the interior--especially in appliances. What is the interior upholstery like? You can find info on the Westfalias (most common conversion) at http://busdepot.com/campers.htm. Other conversions (ASI/Riviera, Sundial, Sprtsmobile, Dormobile, etc.) you'll have to look for. Check out the tech articles at type2.com. There's some good stuff there. And good luck!! |
Posted: Fri Jan 24, 2003 1:41 pm Post subject: What bus do I have. |
It does have a pop-top. THe interior is stripped but I do believe it had a sink, stove and fridge before the guy before me tore them out. Thanks for all your help samba.
matt |
