bigbulli Samba Member
Joined: September 30, 2000 Posts: 575 Location: ENGLAND
Posted: Sun Feb 10, 2008 1:37 pm Post subject: Difficulty restarting after journey... |
I'm having difficulty restarting after journeys. It appears the choke /engine is flooding. My mate held open the accelerator lever to get more air in and it started ok. What do I need to do to fix it? Didint have this problem till I rebuilt fuel pump and cleaned carb, would turning the auto choke make a difference? _________________ 1954 Barndoor
1955 Oval |
Okie Adam Samba Member
Joined: November 07, 2003 Posts: 1347 Location: OOOOOOOOOOOOOOOOOklahoma
Posted: Sun Feb 10, 2008 2:59 pm Post subject: |
how long between when you shut it off and when you try and start it again? _________________ Oil Capital Air Cooled
55 Wolfsburg Kombi
60 Walkthrough Kombi
62 Single Cab
66 21window
67 so42
76 Westy
64 Karmann Ghia |
Posted: Sun Feb 10, 2008 3:02 pm Post subject: |
one percenter wrote: |
how long between when you shut it off and when you try and start it again? |
Anywhere between 5 and 30 mins, once it starts it drives good and does not stall when stopping. _________________ 1954 Barndoor
1955 Oval |
Culito 11010101
Joined: December 07, 2006 Posts: 5866 Location: Columbia Missourah
Posted: Sun Feb 10, 2008 3:04 pm Post subject: |
Check your fuel pressure. I've had the same problems. _________________ Copyright CJ Industries, Inc.
'64 standard w/2.0L type 4
'62 bug
johnnypan wrote: |
...dont pay no attention to Culito,he's a cornhole.. |
Posted: Sun Feb 10, 2008 3:07 pm Post subject: |
It seems that as long as you motor is warmed up good and it isnt super cold than for that short of a time period your choke shouldn't be kicking back on. If it is that might be the problem. You could also be dealing with a vapor lock issue, strange as it might sound. My old '58 would vapor lock if I let it sit after driving it but opening up the carb would get it flowing again. _________________ Oil Capital Air Cooled
55 Wolfsburg Kombi
62 Single Cab
66 21window
67 so42
76 Westy
64 Karmann Ghia |
Posted: Sun Feb 10, 2008 3:09 pm Post subject: Re: Difficulty restarting after journey... |
bigbulli wrote: |
Didint have this problem till I rebuilt fuel pump.... |
Is it a stock VW pump? If so did you pre load it when you rebuilt it? _________________ Oil Capital Air Cooled
55 Wolfsburg Kombi
62 Single Cab
66 21window
67 so42
76 Westy
64 Karmann Ghia |
Campy Samba Member
Joined: January 10, 2005 Posts: 4933 Location: Chico, CA
Posted: Mon Feb 11, 2008 12:45 am Post subject: |
Check the adjustment of the choke valve. _________________ Don't worry; be happy. (Baba) |
Lind Samba Member
Joined: November 06, 2000 Posts: 9915 Location: idaho
Posted: Mon Feb 11, 2008 12:49 am Post subject: |
sounds like the float level is too high, and it is draining the gas down the carb. that will make it hard to start between 5 and 30 minutes after it has run, but it will start right up after it turns off, or if it has had long enough for the fuel to dissipate. _________________ .
Wanted:
Campy Samba Member
Posted: Mon Feb 11, 2008 1:08 am Post subject: |
Check the crankcase oil to see if it has the odor of gasoline.
Maybe the float has a crack in it. _________________ Don't worry; be happy. (Baba) |
Posted: Mon Feb 11, 2008 11:25 am Post subject: |
Thanks guys, I will check all the options! _________________ 1954 Barndoor
1955 Oval |
Ian Samba Moderator
Posted: Mon Feb 11, 2008 6:09 pm Post subject: |
Lind wrote: |
sounds like the float level is too high, and it is draining the gas down the carb. that will make it hard to start between 5 and 30 minutes after it has run, but it will start right up after it turns off, or if it has had long enough for the fuel to dissipate. |
how do you fix this?? _________________ All your Buses are belong to us.
Love and good roads!
IN LOVING MEMORY OF ROB CRESS 1968-2012 |
Lind Samba Member
Posted: Mon Feb 11, 2008 6:11 pm Post subject: |
Ian wrote: |
Lind wrote: |
how do you fix this?? |
just bend the float a bit so it pushes the needle and seat closed when the fuel is at a lower level. if the fuel level is too high, then it siphons it out. _________________ .
Wanted:
Culito 11010101
Posted: Mon Feb 11, 2008 6:34 pm Post subject: |
Or you can add a washer underneath the needle valve... _________________ Copyright CJ Industries, Inc.
'62 bug
johnnypan wrote: |
mandysbus Samba Member
Joined: December 20, 2002 Posts: 567 Location: downtown womelsdorf
Posted: Mon Feb 11, 2008 7:01 pm Post subject: |
or the gas cap is not vented.......rebuilt carb,set float level,new fuel pump and used pressure guage to set fuel pressure..still had hard start after running just like you..........got a vented cap and it all went away...............phil |
Posted: Tue Feb 12, 2008 11:02 am Post subject: |
What height should the float be at and where do you measure it?
Cheers
Rich _________________ 1954 Barndoor
1955 Oval |
420GOAT Samba Member
Joined: March 31, 2006 Posts: 3343 Location: Wilmington, CA on a nice quiet street but still in the 'hood
Posted: Tue Feb 12, 2008 11:12 am Post subject: |
id check the cap too, and the needle, dont know if there is a spec on float height though. _________________ once you realize im not impressed we will get along just fine |
Campy Samba Member
Posted: Tue Feb 12, 2008 1:05 pm Post subject: |
Someone will point it out if I am wrong but I've rebuilt VW carburetors (30 PICT-1 to 34 PICT-3) and they have all had plastic floats, so there was no way to bend them and adjust them, and no mention of it in the directions with the rebuild kit or in my motor manual. The 28 PICT carburetor has a different float so I don't know about it.
The float needle valve that is in the rebuild kit comes with a washer (the washer moves the float needle valve down, a little, so the float won't be able to float up as high) but I can't remember in what cases it is to be used.
To check the float needle valve for any leaks, remove the top body from the carburetor, press up lightly on the needle in the needle valve, and blow air into the fuel inlet. If air comes out of the needle valve, replace it.
To check the float for a leak, push it down in some hot water; if there are any air bubbles, replace the float. _________________ Don't worry; be happy. (Baba) |
Posted: Sat Feb 16, 2008 12:35 am Post subject: |
OK, so I bent the float up, replaced the needle valve with a solex one and pre loaded the fuel pump. Again started and drove really well, once stopped and left for 15 mins wouldn't start. I took the fuel pipe off from the fuel pump and turned the engine over by hand, no fuel, I then got father-in-law to turn the engine over by the key and after more than a few turns petrol came thru. I left it 15 mins and it started again. Not convinced it fixed so I will try again tomorrow to see if I can get it not to start, if that make sense....any idea's?
1955 Oval |
tubdub Samba Member
Posted: Sat Feb 16, 2008 6:10 am Post subject: a |
as someone else stated. next time it happens take off the gas cap and listen to see if you can hear a swoosh or sucking sound as you take the gas cap off. your gas tank might not be venting
or drive the bus around with the gas cap off and see if this still happens. dangerous to a point but you might find out you need a different gas cap |
Clara Samba Member
Posted: Sat Feb 16, 2008 12:24 pm Post subject: |
The carb in the '56 westy sometimes has the choke butterfly stick.
It happened worse after I cleaned out the carb.
The moving bits need to be oiled from time to time. That helped. But sometimes it still sticks.
When it doesn't start, I have to go open the engine lid, manually move the arm that turns the choke butterfly so it is free again. Kinda annoying.
I intend to put a manual choke 30 pict carb on it, so have just been dealing with it so far.
Maybe this helps (?) _________________ The Obsolete Air-Cooled Documentation Project http://oacdp.org/ |
