lowdowndub Samba Member
Posted: Tue Jan 28, 2003 10:24 am Post subject: Carb - Alternator Interferance |
Can anybody tell how to get a Solex Pict 34 to clear the alternator. When I pull the throttle lever, it hits on the alternator. There isn't a spacer kit for a PICT 34. Please Help
Thanks - Ben |
keifernet Samba Search & Rescue
Joined: May 11, 2002 Posts: 19395 Location: Samba Center for Behavioral Science
Posted: Tue Jan 28, 2003 10:38 am Post subject: Carb - Alternator Interferance |
You need the "opposite" style accel pump linkage from a 73-later model carb.
I would check with a local shop to see if they have some. I always strip that piece off when I "condemn" a carb to the scrap pile. I need to see how many I may have so if you cannot get one...
You can do a LIMITED amound of bending tweaking of the piece and grind the head of the small aduster bolt and on the alt housing to get it, but that's really not the best method.
or if you could find/make some kind of spacer... I do not know of anyone who sells them but. I think I remember seeing someone cut the flange off an old manifold that had rusted out pre heat pipes and ground it flat and used it... but them you need to put in longer studs ect.
Or using the 30/31 replacement carb will shift the carb to the left and youy would not have a problem...
I'll e- mail you if I find I have a bunch of the parts, I was just rebuilding some carbs yesterday and was digging through my car spare parts boxes... |
Posted: Tue Jan 28, 2003 1:31 pm Post subject: Carb - Alternator Interferance |
Thanks for the info, look forward to hereing from you about the opposite Style Linkage
Thanks Again
Ben |
Posted: Tue Jan 28, 2003 7:00 pm Post subject: Carb - Alternator Interferance |
You've got mail! |
