Suboval Samba Member
Posted: Thu Feb 09, 2012 6:09 pm Post subject: |
Regarding the 55 SWF relay, not only does it not have the "6 Volt 2X20 Watt" stamped on the back of the mounting bracket, but it also does not have the "Typ:" and "BGB/51" script on the front of the bakelite below the "Made in Germany" script.
56-57 on left. 55 on right.
56-57 on left. 55 on right. _________________ It all works on paper.
There's two things we learn from history:
1.) History repeats itself.
2.) We don't learn from history. |
Posted: Thu Feb 09, 2012 6:17 pm Post subject: |
Does anyone knnow what these might go to? Ghia? The mounting bracket is originally straight - not bent.
Both are 55's. _________________ It all works on paper.
johnshenry Samba Member
Joined: September 21, 2001 Posts: 9401 Location: Northwood, NH USA
Posted: Thu Feb 09, 2012 7:37 pm Post subject: |
I don't know Kurt, but I have one with the red paint too. Never figured out what it was used in. _________________ John Henry
'57 Deluxe
'56 Single Cab |
Posted: Thu Feb 09, 2012 7:50 pm Post subject: |
What about the three terminal one, John? Any ideas? _________________ It all works on paper.
Posted: Thu Feb 09, 2012 8:07 pm Post subject: |
Suboval wrote: |
What about the three terminal one, John? Any ideas? |
No clue on that one, and I think I have one of those too. Puzzling because the missing terminal is the ground, and you can't get ground via the bracket because of the big grommet.
The ground, BTW is only needed for the speedometer bulb in the speedo pod as the indicator bulb in it is switched on the ground side, and tied to hot (all the bulbs there are actually, oil and gen lights too). So this flasher could be used in some other car which did not have the same type of flasher indicator setup in the speedo. One whose bulb was tied to ground and switched on the hot side (like the turn signal bulbs outside the car) would not need a ground connection on the flasher.
Ever seen the SHO bakelite flasher? I have one but it is packed away at the moment.... _________________ John Henry
'57 Deluxe
'56 Single Cab |
Posted: Thu Feb 09, 2012 8:45 pm Post subject: |
SHO? That would be kewl to see!
Here's the Fixlight:
Posted: Thu Feb 09, 2012 9:03 pm Post subject: |
The SHO I have is VERY similar in appearance to that. I'll post a pic of it when I unpack it. I am renovating my office an all my "museum" vintage parts are packed away right now... _________________ John Henry
'57 Deluxe
'56 Single Cab |
Loren Samba Member
Posted: Fri Feb 10, 2012 6:43 pm Post subject: |
Suboval wrote: |
Both are 55's. |
They are not Ghia. Ghias used the same ones as Beetles. |
Bruce Samba Member
Joined: May 16, 2003 Posts: 17479 Location: Left coast, Canada
Posted: Sat Feb 11, 2012 2:32 pm Post subject: |
I think the straight bracket is for Bus. _________________
Lind Samba Member
Joined: November 06, 2000 Posts: 10122 Location: idaho
Posted: Mon Feb 13, 2012 9:25 am Post subject: |
Here is what I believe to be an NOS bus flasher. date code CG (3/55). straight bracket. It has a sticker on top, which reads:
type:
BGB
6 Volt 3 X 15 Watt
I wonder if the sticker was present on all of the earlier style units?
also a difference is on the wattage.
_________________ .
Wanted:
Posted: Mon Feb 13, 2012 11:46 am Post subject: |
3 x 15 watt? Are there 3 turn signal bulbs per side on a bus??? _________________ John Henry
'57 Deluxe
'56 Single Cab |
Al Capulco Samba Member
Joined: October 31, 2005 Posts: 537 Location: Northridge, CA.
Posted: Sat Mar 30, 2013 11:58 pm Post subject: |
Does anyone happen to know what date codes were used on SWF parts (wiper motors) after 1968. I have wiper motors with date codes of 2F 54 and was wondering what year it was made. I know it was made in the '70's or '80's. |
cjsmitty Samba Member
Joined: November 12, 2006 Posts: 811 Location: Meadow Vista CA
eurodub Samba Member
Posted: Tue May 14, 2013 10:27 pm Post subject: |
october 52, from the conversion to 160 it seems it has been remanufactured later with parts from a 36hp generator? _________________ 1960 1200 model 117 deluxe ragtop
1976 MK1 Golf |
The Vdub Hub Samba Member
Joined: May 03, 2008 Posts: 193 Location: California USA
janerick3 Samba Member
Posted: Thu May 16, 2013 8:36 pm Post subject: |
11N = Nov 1957
10M = Oct 1956
Date codes (if any) for Bosch lenses are cast into the lip at 12 o'clock, under the rubber gasket, and consist of a Roman numeral (for quarter) and letter (for year). _________________ Thanks,
Jan K. |
nlorntson Crazy VW Lady
Joined: March 13, 2004 Posts: 3832 Location: Twin Cities, MN
Posted: Fri May 17, 2013 7:17 am Post subject: Re: Trying to understand how to make sense of the date codes |
markulves wrote: |
Trying to understand how to make sense of the date codes on the buckets and the markings on the glass or lack of. I didn't include a photo of the top of the glass lenses, but they do have the VW logo.
I'm also wondering if I have the correctly matched chrome light bezels?
Please forgive me if I've incorrectly posted the photos. If so, I'll try again.
Joined: April 27, 2002 Posts: 6506 Location: Pentwater, Michigan
Posted: Sat Mar 21, 2015 5:54 pm Post subject: |
On page 1 there is a set of pics and the question on the Z date code on a D shaped voltage regulator. The Z denotes 1944 a nice'n oldie The pre war date coding for Bosch started in 1920 at A. The post war date coding coincidently started at 1945 with A again. _________________ Roads Scholar &
Member# 2059 |
usariemen Samba Member
Joined: August 28, 2004 Posts: 1745 Location: Germany
Posted: Tue Oct 27, 2015 1:40 pm Post subject: |
I just found this strange D shaped regulator with a flat top.
It has an unusual writing that ends with 1Z
Is that the date code? So january 1944?
But what is between the scew holes? That looks like an N?
Inside there is an extra condensator?
From below a spiral (resistor?) that is also new to me.
Is that a typical KdF aera part? _________________ Master of my domain! |
virtanen Samba Member
Joined: January 08, 2006 Posts: 1478 Location: Finland
