Bosch Hella SWF SHO Blaupunkt date codes
usariemen
usariemen is offline
PostPosted: Wed Oct 28, 2015 4:50 am    Post subject: Reply with quote
OK, so not for a car for sure with 90 Watt?
Is there a way to check if it works?
Master of my domain!
virtanen
virtanen is offline
PostPosted: Wed Oct 28, 2015 6:11 am    Post subject: Reply with quote
If you have a working 6V generator, you can make a test circuit and turn the generator for example by drill machine. I test my generators and regulators that way.
Mika
Split beetle restoration panels
Oval beetle restoration panels
New projects
mikeandkirsti
mikeandkirsti is offline
PostPosted: Wed Oct 28, 2015 10:38 pm    Post subject: Reply with quote
The date code is on the other side above the Bosch logo, usually very hard to read. As I recall early Kübelwagens had a 90W generator but utilized a different style relay. From 1943 it looked liked this but generator was 130W, also for Schwimmwagen and KdF Type 92/82E. It may be that the KdF-Wagen Type 60 utilized the 90W generator and this relay? Check the date code on it.
usariemen wrote:
I just found this strange D shaped regulator with a flat top.
It has an unusual writing that ends with 1Z
Is that the date code? So january 1944?
But what is between the scew holes? That looks like an N?
Inside there is an extra condensator?
From below a spiral (resistor?) that is also new to me.
Is that a typical KdF aera part?
usariemen
PostPosted: Thu Oct 29, 2015 8:11 am    Post subject: Reply with quote
You are right mate!
Some brushing and there it was. 1Y
That´s january 1943?
Would be good to know if that type was on a car.
mikeandkirsti
PostPosted: Thu Oct 29, 2015 11:59 am    Post subject: Reply with quote
Yes, it is January 1943.
Without checking I cannot say for sure but I am pretty certain the KdF-Wagen Type 60 uses the 90W generator and this is a regulator for it, correct for the KdF Type 60 1943-1944.
Worth it´s weight in gold maybe?
The 90W generator was used again in 1946-47 in the Type 11 Beetle and this regulator would work for on one too but the cover would have been with the cross pressing already.
usariemen
PostPosted: Thu Oct 29, 2015 1:24 pm    Post subject: Reply with quote
Now we are talking.
Sounds promising. Wink
johnshenry
johnshenry is offline
PostPosted: Wed Oct 25, 2017 6:49 pm    Post subject: Re: Bosch Hella SWF SHO Blaupunkt date codes Reply with quote
Ok, so here is a question regarding SWF date codes. Among many ribbed SWF sems I have, I have an "IB" and an "MB". Despite the first page of this thread stating that "I" was not used (for year anyway), "I" is the month on my "IB" and it is Sept 1950. What is "MB", or what letter between I and M is skipped because if none were skipped then "M" is the 13th month of the year.
Sorry if this was covered previously in this thread, I didn't read all the posts.
I propose that "M" is December and "L" was skipped because it looks too much like an "I". Just a theory.....
John Henry
'57 Deluxe
'56 Single Cab
johnshenry
PostPosted: Thu Oct 26, 2017 6:48 pm    Post subject: Re: Bosch Hella SWF SHO Blaupunkt date codes Reply with quote
Ok, scratch that theory, I am going through all of my sem pics and have found an "LD" that I restored years ago. So what is the missing letter???
John Henry
'57 Deluxe
'56 Single Cab
Bengt H
Bengt H is offline
PostPosted: Fri Oct 27, 2017 6:17 am    Post subject: Re: Bosch Hella SWF SHO Blaupunkt date codes Reply with quote
J ??
johnshenry
PostPosted: Fri Oct 27, 2017 8:20 am    Post subject: Re: Bosch Hella SWF SHO Blaupunkt date codes Reply with quote
Yes, would have to be J or K. Still going through my hundreds of pics of sems... Any one have ribbed SWF sem with a J or K letter for the month?
John Henry
'57 Deluxe
'56 Single Cab
GHIA
GHIA is offline
PostPosted: Sun Jan 07, 2018 1:09 pm    Post subject: Re: Bosch Hella SWF SHO Blaupunkt date codes Reply with quote
Someone would have it Garbe Lahmeyer date code ?
Peter_KG
Peter_KG is offline
PostPosted: Fri Mar 30, 2018 10:55 am    Post subject: Re: Bosch Hella SWF SHO Blaupunkt date codes Reply with quote
Hi y’all,
I have this NOS Bosch round voltage regulator, the only code I can find on it is; RS/TB/130-150/6/1. Any info (date) for this one, is much appreciated! Wink
VW Karmann Ghia '63
VW Kupla Dickholmer '64
VW Bubbla Oval '54
PostPosted: Fri Mar 30, 2018 10:42 pm    Post subject: Re: Bosch Hella SWF SHO Blaupunkt date codes Reply with quote
I'm used to this code:
The date code is on the other foot:
1K in this case
I see a pic with similar codes on the box in the Gallery but I don't have any close-up photos of the feet
Does your regulator have the rounded-off mounting feet?
If it's doesn't, it's not for a VW
PostPosted: Fri Mar 30, 2018 10:45 pm    Post subject: Re: Bosch Hella SWF SHO Blaupunkt date codes Reply with quote
Update, I found that part # RS/TB/130-150/6/1 listed as pre-A Porsche and some other models here on eBay:
https://www.ebay.com/itm/NOS-Bosch-Round-Voltage-R...1579558829
tasb Premium Member
The Distributor Distributor
tasb is offline
PostPosted: Sun Apr 01, 2018 2:50 am    Post subject: Re: Bosch Hella SWF SHO Blaupunkt date codes Reply with quote
Early distributors not really a code 3/55 for March 1955 for example. Later distributors do not have any date codes on them. Not sure on other components.
Roads Scholar &
Member# 2059
Peter_KG
Peter_KG is offline
PostPosted: Sun Apr 01, 2018 5:00 am    Post subject: Re: Bosch Hella SWF SHO Blaupunkt date codes Reply with quote
Thanks!! I found the ebay add, in my google searches, too... However, couldn’t find any 356 with a round Bosch voltage regulator though...
Couldn’t find any Bosch code, that would tell me the date, neither!
So still searching to find out what car it belongs to. Wink
VW Karmann Ghia '63
VW Bubbla Oval '54
tasb Premium Member
tasb is offline
PostPosted: Fri Nov 30, 2018 6:26 pm    Post subject: Reply with quote
xavi_242 wrote:
just got a BR8 centrifugal distributor... can't date it.
It only wears a little 10 stamped at the body... and a big 1 on one other side...
any thoughts? Oh, badge is french...
I realize that this post is over 8 years old but it would be cool to see a picture of this distributors badge if it is indeed French and Bosch?
There wasn't anyone in quality control inspecting the date code stamps so sometimes they are missing the month or year stamp or are indistinct. The big "1" is the terminal designation for the through bolt.
The VJU 4 BR 8 was used on the Beetle from August 1954 until July 1960. The Ghia only used this distributor for a shorter period compared to the Beetle of August 1955 until July 1959.The Ghia received the new vacuum only distributors on a trial basis.
Roads Scholar &
Member# 2059
James Davies
James Davies is offline
PostPosted: Thu Feb 06, 2020 9:21 pm    Post subject: Re: Bosch Hella SWF SHO Blaupunkt date codes Reply with quote
The round Bosch RS/TB 130..150/6/1 voltage regulator above is for a 1951 Mercedes 220. It matches to the LJ/GJH 130/6/2200 R 1 generator. It is listed in the 1952 Bosch parts book.
It also is for the 1952 Ford Taunus 12M, matched to the LJ/GE 130/6/2600 R 3 generator.
my3bugs
my3bugs is offline
PostPosted: Thu Nov 14, 2024 9:18 am    Post subject: Re: Bosch Hella SWF SHO Blaupunkt date codes Reply with quote
im looking for the date info on this and im a bit confused as its just a 1E code . is that January 1949 .???
i snapped a few pics for ya . looks like the box is also marked 1E ... i dont see many of these with the decal .
i have two of these regulators with the decal and there both dated 1E . seems most of these i see do not have decals on em . any more info is appreciated .
like what does it say on the decal ?
johnshenry
PostPosted: Thu Nov 14, 2024 9:31 am    Post subject: Re: Bosch Hella SWF SHO Blaupunkt date codes Reply with quote
I have a 12 volt version of that reg, dated 11E and it has that decal.
RS/6300/12/2
John Henry
'57 Deluxe
'56 Single Cab
Page 4 of 5
