TheVintageVw Samba Member
Joined: July 19, 2004 Posts: 654 Location: Porter Ranch California
Posted: Tue Feb 12, 2008 5:37 pm Post subject: need help guys..starting issue..... |
aight so i put in a new starter in the 54... 6v of course.... put everything back... cranked the car once... it cranked....then went to put in some starter fluid(cars been sitting) cranked it again... i could sorta hear grinding from the starter.... after that i get nothing.... no crank, no sound nada... its as if there is no starter... rechecked everything and its fine... banged it a few times with a wrench... still nothing?
any ideas? this is a rebuilt original german bosch starter.....
thanks |
djkeev Samba Moderator
Joined: September 30, 2007 Posts: 32632 Location: Reading Pennsylvania
Posted: Tue Feb 12, 2008 6:07 pm Post subject: |
hi,
Just curious, what was wrong that you put in a new starter???
If you say, doesn't crank, no noise, nada, it was as if there were no starter.......hmmmmmm, maybe your problem never was the starter but wiring/connection problems or a switch problem??
How is your ground strap from the tranny to the chassis? Clean tight?
starter nose shaft bushing good?, you put in a new one?
Just a thought
I'd take out your "new" starter and bench test it. (make sure you hang onto it or clamp it and make the correct connections) That will identify the starter as being bad, if it works on the bench, something in the car needs attention.
Ghia
Vanagon
Beetle
Posted: Tue Feb 12, 2008 6:11 pm Post subject: |
i replaced the starter because the other one was bad(it would crank super slow) replaced battery etc.. got the old starter tested and yeah it was bad, so i replaced it......
the tranny strap is nice and tight, tried 2 different batteries... undid the wires from the starter and reinstalled them etc etc...
whats weird is that first initial crank was perfect.... after that cranked 2 more times but with some grinding noise, starter is installed correctly and tighly so that isnt the problem.... |
ericktheelectrician Samba Member
Posted: Tue Feb 12, 2008 8:56 pm Post subject: |
sounds like the starter bushing , did you replace the bushing in your transmission? |
Posted: Tue Feb 12, 2008 9:33 pm Post subject: |
bushing is not replaced.. is that 100% required to replace? |
Posted: Wed Feb 13, 2008 8:43 am Post subject: |
yes it should be replaced when you change the starter , it is a little tough to get the old one out but when you get the old one out use a socket the same size as the bushing to get the new one in this will all make sense when you're actually doing the removal and installation of the bushing , good luck and let us know if that works |
Posted: Wed Feb 13, 2008 1:59 pm Post subject: |
but how would a bushing prevent a click, a turn or anything from the starter? could it cause the starter to do NOTHING?
thanks |
Posted: Wed Feb 13, 2008 2:21 pm Post subject: |
Hi,
If you take the starter out of the car, you can grab the nose shaft by the drive gear and wiggle it around.
That play can prevent the armature from turning for it binds against the windings on the side.
A solonoid uses an electro magnet to complete an electrical circuit.
A bad bushing most likely won't stop the solonoid from going click unless the drive pinion is stuck out in the ring gear for some reason (maybe a bad starter bushing??) there would not be any click for the steel shaft that the electromagnet draws back that makes the click sound is already drawn back and in position to start the car. That is another issue you need to check out.
If the solonoid is bad the electromagnet either doesn't move to make the connection or does move but doesn't make the connection to direct the current to the brushes.
The starter solonoid is just a giant electrical relay. While making the connection it uses a lever to push the drive pinion into the ring gear on most starter styles.
Just because it was "rebuilt" doesn't mean it is a good starter. Take an old starter, Clean it up, slap a coat of clear lacquer on it and there you have it, a "rebuilt" starter, throw it in the box and ship it out. _________________ Stop Dead Photo Links how to post photos
Ghia
Vanagon
Beetle
Posted: Wed Feb 13, 2008 2:23 pm Post subject: |
the starter you just bought might also be bad I just had this same issue less than 2 weeks ago , I replaced the starter with a rebuilt starter from Carquest and it was bad from the rebuilder took it back and the 2nd starter worked fine , but you still need to replace the bushing which should come with the starter when you buy them , and after all that is done if it still won't start you have electrical issues with the car itself and you'll have to figure out where you are losing voltage |
johnshenry Samba Member
Joined: September 21, 2001 Posts: 9364 Location: Northwood, NH USA
Posted: Wed Feb 13, 2008 2:40 pm Post subject: |
I know you said your new starter was 6volt, but I'll throw this out. I saw a 12 volt (130 tooth flywheel) starter installed on a 6 volt (108 tooth) flywheel/engine once.......
.......... and there was LOTS of grinding noise.
Doubt that is your case, but if you find that the starter gear teeth are all chewed up..... _________________ John Henry
'57 Deluxe
'56 Single Cab |
DMNCLNR Sir Camp'alot
Joined: November 12, 2003 Posts: 2897 Location: Newport Beach Ca
Posted: Wed Feb 13, 2008 3:43 pm Post subject: |
My guess would be that the bushing caused the starter to bind up, and if you were still cranking on it you could have blew a fuse, or grounded out a wire. _________________ To his their own PBJ
Pl@y@ #1 |
Posted: Wed Feb 13, 2008 6:35 pm Post subject: |
okay took the starter out.. went to a local starter shop and got it bench tested.... works fine... i put it back in.... cranked once.. after that just clicks and after bout like 5 clicks no nothing again..... no click nothing..... |
JonaWerks Samba Member
Joined: November 18, 2004 Posts: 19 Location: Red Sox Nation
Posted: Sat Jun 23, 2018 3:46 pm Post subject: Re: need help guys..starting issue..... |
Hi All,
I know this is an old thread but I thought I would add my recent experience in case it might help another VW enthusiast.
Issue: 57 Beetle, extremely slow crank, turns over once or twice, then makes a grinding noise and then nothing. Try again and simply get a click or nothing at all.
Background: Rebuilt 36HP, bench tested and broken in with all new wires, new O'Riellys starter and a new 6V Napa battery in a 57 tranny housing with brand new bushing.
Installed engine in the car. Used same new starter, new wires from battery to starter, new negative cable and new starter bushing. Replaced the trans ground strap and cleaned the contacts. This is the original tranny, original flywheel; just a new starter (why not), battery, bushing and wires. You would expect it to turn over and start right up just like it did on the bench. Nope. Extremely slow crank, turns over once or twice, then makes a grinding noise and then nothing.
Went out and bought a new Interstate 6V, tested the voltage (6.4), cranking voltage (4.7) and all wires appear to be fine. Still no luck.
Took out new battery, new starter and put them in the bench test harness. All works fine. Then I put the original 57 starter with the Napa battery in the harness. They work fine too.
So now I’m out of ideas. Why not put the Napa battery and the original starter back in the car and give it a try. Vroom, started right up!
The O'Riellys starter works on the harness but not in the car? Does it need additional grounding? (Tried that too. I put jumper cables from the starter to the frame. no improvement) Does the original starter have more torque? Not sure why the original starter works and the new O'Riellys doesn't. But for folks experiencing this issue it might be worth trying an older, original rebuilt VW starter over any auto parts store starter in your 6V car. _________________ 57 Ragtop Beetle
82 Rabbit Pickup Diesel LX
14 Passat SE - Totalled
21 Tiguan SE |
Eric&Barb Samba Member
Joined: September 19, 2004 Posts: 24764 Location: Olympia Wash Rinse & Repeat
Posted: Sat Jun 23, 2018 5:14 pm Post subject: Re: need help guys..starting issue..... |
Did you clean up the surfaces on the transaxle and starter so as to have a good ground connection between the two??
Maybe when you reinstalled the old starter, you got just enough connetion thru the mounting bolts. _________________ In Stereo, Where Available! |
Posted: Sat Jun 23, 2018 5:38 pm Post subject: Re: need help guys..starting issue..... |
Hi Eric&Barb,
Thanks for the good idea....everything was quoted down
I thought that would have been covered when I used the jumper cable from the starter to the frame too.
Perhaps I'll try again and make sure its spotless.
Thanks! _________________ 57 Ragtop Beetle
21 Tiguan SE |
Posted: Sat Jun 23, 2018 5:42 pm Post subject: Re: need help guys..starting issue..... |
JonaWerks wrote: |
Not sure what is "quoted down". _________________ In Stereo, Where Available! |
Posted: Sat Jun 23, 2018 6:43 pm Post subject: Re: need help guys..starting issue..... |
Ha! Sorry about that...it should have read 'wiped down'. I used brake cleaner _________________ 57 Ragtop Beetle
21 Tiguan SE |
