'67Vert Samba Member
Joined: July 03, 2007 Posts: 117 Location: Santa Maria, CA
Posted: Fri Feb 15, 2008 11:23 am Post subject: |
Alan Willis wrote: |
Damn,$150 for just the lock??? I'm only asking $100 for my complete assembly WITH the key! |
I've sent a PM to Alan and offered to purchase his lock and column, hopfully he'll sell it to me and save me alot of time. I'll check with WW to see if they sell just the rubber and let everyone know. I'll also be checking with Gabriel to get my lock fitted for the K style key to be somewhat correct. I have all current ignition, doors, vert hood lock, and deck lid keyed alike to a K series key. _________________ "The bitterness of poor quality remains long after the sweetness of low price is forgotten."
'67 Convertible
'67 Sunroof
'67 Sedan (2)
'63 Rag Top
'62 Sedan
'70 Single Cab
'71 Bus |
Alan Willis Banned
Joined: November 22, 2004 Posts: 4181 Location: booted from the SEWR and stalked in here
Posted: Fri Feb 15, 2008 1:27 pm Post subject: |
Is this for a '67? '67 steering lock,as with most of the car,is one year only. _________________ die schwarzen Schafe #666 |
Alan Willis Banned
Posted: Fri Feb 15, 2008 1:31 pm Post subject: |
Mine is '60-'65.'66 is black with writing,'67 is black with no writing. _________________ die schwarzen Schafe #666 |
bill may Samba Member
Joined: August 27, 2003 Posts: 14160 Location: san diego,ca
Critter1 Samba Member
Joined: August 04, 2004 Posts: 1575 Location: Sacramento
Posted: Fri Feb 15, 2008 3:52 pm Post subject: |
bill may wrote: |
i have 4 K code locks for locking column and 3 complete units. i also have nos 61-66 keys (huff) i just don't advertise. |
67 Vert-
There you go... You don't even have to contact Gabriel. Bill May has what you need. _________________ Justin |
Posted: Fri Feb 15, 2008 4:00 pm Post subject: |
Now I need more technical info. I contacted Alan and he has a lock and column for sale. I need to know if this will work in 67 Vert??? His ad reads as follows.
Locking steering column Price: $65+shipping
I have a locking steering column out of a '63 euro ragtop. The column works like new,and the electrical portion is NOS. It also has the correct key.
Price includes the lock,electrical hookup,column,tube,and key;everything you need to install in your '60-'65 beetle(paint it black and it would be correct for a '66).
I think I need some advice here - Bill May, 67Delux or Critter1
Thanks in advance. _________________ "The bitterness of poor quality remains long after the sweetness of low price is forgotten."
'67 Convertible
'67 Sunroof
'67 Sedan (2)
'63 Rag Top
'62 Sedan
'70 Single Cab
'71 Bus |
Posted: Fri Feb 15, 2008 5:20 pm Post subject: |
'67Vert wrote: |
Thanks in advance. |
Yes it will work in your 67 vert.
The column and tube will fit. In order to make it correct for your year, you will need to paint the lock housing black, and change the keyed portion to the smooth 67 only type (which Bill May says he has). _________________ Justin |
Posted: Fri Feb 15, 2008 5:30 pm Post subject: |
Here is the difference:
This appears to be for a 66 since the lock housing is black and has the words surrounding the key hole. 58-65 lock housing would be an off white color.
67 only. Notice the smooth ring surrounding the key hole.
HERC Samba Member
Posted: Sat Feb 16, 2008 7:16 am Post subject: |
Yes...Here's mine in my 64
_________________ Herc |
zcraigs Samba Member
Joined: March 03, 2005 Posts: 63 Location: Capitola by the Sea, California
Posted: Mon Sep 29, 2008 5:58 pm Post subject: |
I have the steering wheel lock mechanism, but the cylinder is gone.
Where could I find one?
Thanks |
mooks73 Samba Member
Joined: June 08, 2006 Posts: 422 Location: fontana ca
Posted: Mon Sep 29, 2008 6:55 pm Post subject: |
hey,bill may are you intrested in selling a complete set up????i need it for a 1962 bug.. |
JamesDole Samba Member
Joined: July 18, 2007 Posts: 215 Location: Yakima, WA
Posted: Mon Sep 29, 2008 8:30 pm Post subject: |
I have a 66' Euro bug with a locking column. I had to drill out the shear bolts, not as easy as it sounds, but I did it. Anyway, I was wondering if anyone has a cylinder with the words on it that they may want to sell. Mine works great, but it is badly pitted. Thanx.... |
ilustr8tor Samba Member
Joined: November 07, 2010 Posts: 426 Location: Maryland
Posted: Mon Dec 06, 2010 6:00 am Post subject: |
I was looking at this schematic:
and wondering, can you remove and replace the key cylinder without removing the housing. There are a couple screws on the back of the key cylinder. My key is stuck in the run position, I can turn 45 degrees to start position but can not turn counter clockwise to Lock position so I can remove the key. |
gerg a.k.a. 6volt65
Joined: April 25, 2003 Posts: 5454 Location: Monroe, LA
Posted: Mon Dec 06, 2010 9:20 am Post subject: |
Try using the GrabIT bits. Probably the only thing I have seen on a TV infomercial that actually does what they say it will. Maybe some penetrating oil from the top to assist too . . . _________________ Gerg
. . . I got 99 problems and my bus ain't one . . .
'65 Sunroof Beetle
'65 Vert
'60 Singlecab |
Posted: Mon Dec 06, 2010 11:36 am Post subject: |
yeah it's pretty strange, The key will rotate 40 degrees clockwise to start but will not rotate counter clockwise to lock so I can pull out the key. The wheel rotates freely, just cant get the key to go into lock position. I have been soaking with Liquid Wrench for a couple days I will try again tonight |
Posted: Tue Dec 07, 2010 8:33 pm Post subject: |
you guys are awesome problem solved, the shaft cover had slipped down and was blocking locking hole.
: Check ou the pics:
Puerto Rico 1967 type 1 Samba Member
Posted: Thu Sep 13, 2018 5:37 pm Post subject: Re: Removal of Steering Column Ignition locking unit |
I have the same setup on my 67. I'm having problems with the tumbler. I turn the key to start and it doesn't spring back to the on position. To replace the tumbler and/or the ignition switch do I have to remove the steering lock? |
Russ67 Samba Member
Posted: Fri Sep 14, 2018 9:14 pm Post subject: Re: Removal of Steering Column Ignition locking unit |
Puerto Rico 1967 type 1 wrote: |
Same here. Same question. lol |
Posted: Sun Sep 23, 2018 8:36 am Post subject: Re: Removal of Steering Column Ignition locking unit |
so looks like the issue is the switch not the tumbler. Airhead parts sells the switch
part number: 111 905 865 EBR
Its easy to change out, just unscrew the two screws on the back of the switch. |
