Russ1967 Samba Member
Posted: Sat Dec 29, 2018 9:55 pm Post subject: Re: Removal of Steering Column Ignition locking unit |
Puerto Rico 1967 type 1 wrote: |
so looks like the issue is the switch not the tumbler. Airhead parts sells the switch
part number: 111 905 865 EBR
Its easy to change out, just unscrew the two screws on the back of the switch. |
Were you able to remove the two screws from the back of the switch and replace it with the new one?
Did it fix your problem?
Any issues or problems? |
Puerto Rico 1967 type 1 Samba Member
Posted: Sun Dec 30, 2018 9:29 pm Post subject: Re: Removal of Steering Column Ignition locking unit |
It was simple to swap out. The first switch was defective. It wouldn’t rotate. Got a replacement and worked no problem. |
Posted: Sun Dec 30, 2018 10:13 pm Post subject: Re: Removal of Steering Column Ignition locking unit |
OK, great.
I saw your other post where the key wouldn't turn with the new ignition switch.
Glad it worked out. |
JORGE ROBLES Samba Member
Joined: January 12, 2005 Posts: 4 Location: SALT LAKE CITY ,UT USA
Posted: Fri Dec 18, 2020 6:09 am Post subject: Re: Removal of Steering Column Ignition locking unit |
Does anyone has a wiring diagram for steering wheel locking mechanism? Regards Jorge _________________ VINTAGE PORSCHE 356 AND VINTAGE VOLKSWAGEN BEETLES ARE "THE CARS OF THE CENTURY" HAPPY TRAILS EVERYONE!!! |
hsosa1 Samba Member
Joined: January 17, 2005 Posts: 1897 Location: Fontana
Posted: Tue Apr 20, 2021 7:57 am Post subject: |
'67Vert wrote: |
Here is a parts break down of the bolts that you will have to drill the heads off of to remove the column. Look at the bolts and you'll see the part of the bolt that shears off once it tightened to the correct torque. Hope this helps.
what up guys . I have to replace the rubber grommet that goes on the bottom of the firewall it keeps the steering column centered . question what is the best way to install this seal? I thought I could unbolt the steering column from the bottom I see that the horn button tab is in the way to slide up the seal . then I figured I can slide the seal down the column from inside the car but I have a steering lock . which brought me to this thread. at one point my steering lock was removed it doesn't have the breakaway bolts and it has regular bolts where u can unfasten. now that I'm looking at it this it seems like so much work for just a stupid seal . now im thinking of just slicing the seal and installing it. without taking anything apart. _________________ Just Cruzin Sur Califas VW Car Club est♤1998 |
Murdlem Samba Member
Joined: February 06, 2004 Posts: 512 Location: Port Angeles, Washington
Posted: Tue Apr 20, 2021 8:53 pm Post subject: Re: Removal of Steering Column Ignition locking unit |
Thanks for bumping this. I have been wondering how to remove the bolts on my steering lock, but now I see that all I need is my drill.
Perfect! _________________ Eric Meldrum
68 Ghia
Check out my blog. https://vwlifenet.wordpress.com/ |
