Anti-Trend Samba Member
Campy Samba Member
Joined: January 10, 2005 Posts: 4933 Location: Chico, CA
Posted: Tue Feb 12, 2008 11:15 pm Post subject: |
Avoid getting a cheap made-in-China air compressor and paint gun.
The air compressor is not only cheap, it is too small. I restore old buses and I got by, for years, with a Campbell Hausfeld air compressor, which had a 26 gallon tank, belt drive, oil bath, and a cast iron pump. Avoid any air compressors that are "oil-less" and not belt drive.
Recently, I picked up a real nice, used Devilbliss dual stage air compressor for $400. It has an upright 80 gallon tank, and I got a magnetic starter and electrical box thrown in with it. I will never have to wait to have the tank fill up with air when using air tools, again.
I have three Binks suction paint guns that I picked up, years ago, for $5.00 to $10.00 each. I cleaned them up and rebuilt them, and they work great.
When I rented a paint booth so I could paint my bus, to be legal, the owner made me get an HVLP paint gun. I bought a slightly used Devilbliss paint gun at a paint store for $150 (retail was $360 new) but it never atomized the paint as well as my Binks gun. _________________ Don't worry; be happy. (Baba) |
djkeev Samba Moderator
Joined: September 30, 2007 Posts: 32592 Location: Reading Pennsylvania
Campy Samba Member
Posted: Wed Feb 13, 2008 12:31 pm Post subject: |
When I painted my 1963 bus, I used dove blue acrylic-urethane paint because I didn't want to fool with a clear coat and I wanted the paint to look more like the factory paint (no high gloss). Because the paint is not just a plain enamel, yes, it does have to have a hardener (and reducer).
You really need a bigger air compressor so you won't have to keep stopping to wait for the air pressure to build back up. Also, without refrigerated air or at least a damn good filter, some water will get in the paint and some can fly out of the end of the coupler near the paint gun and get on your wet paint. I wrapped a rag around my coupler to catch any water. They have disposible plastic filters that are put on the air inlet of a paint gun but they are just for a last little bit of filtering and are not not meant to be the sole filter.
If you are going to be painting in an area or state where you are not required to use an HVLP paint gun, think about getting a good suction type paint gun because it will probably atomize the paint better than a cheaper HVLP paint gun. HVLP (high volume low pressure) paint guns were designed to have less air coming out of the cap (10 psi) so there is less overspray, hence, less pollution, when laws in some states were passed to crack down on the air pollution. My Binks suction type paint gun atomizes the paint much better than my expensive Devilbliss HVLP paint gun.
If you are going to be painting things in or around your garage, you can't have any source of ignition, such as an air compressor or fan, near the VOC because of the risk of an explosion. I put a long electrical cord on my air compressor and had it outside of my garage. Also, if people live nearby, you could get complaints or even get in trouble because the VOC will go out into the neighborhood. _________________ Don't worry; be happy. (Baba) |
marklaken Samba Member
Joined: March 19, 2004 Posts: 2416 Location: fort collins, CO
Posted: Wed Feb 13, 2008 3:23 pm Post subject: |
buy this respirator: http://www.tcpglobal.com/autobodydepot/ItemDetail.aspx?ItemNo=MMM%207192
consider Harbor Freight's turbine paint system stickied above (I have no experience, but it sounds like people are satisfied with it and it is dirt cheap)
TCP paint and primer should work good for a budget first time paint job - I sprayed some of their Acrylic Eurathane and thought it sprayed nicely -
Be aware that eurathane hardeners have very short shelf life (14 days after opening the container). Depending on how you are spraying, you may be better of buying a couple small sealed containers of hardener rather than 1 larger container
Make sure you spray a solid color and not a metallic or pearl - especially if spraying singel stage paint _________________ Wish List:
1967 Wesfalia SO-42 Parts Needed: Kitchenette, Cot Poles
'65 rear left beetle fender
15" Bus Wheels in fair condition
Mark Laken
Fort Collins, CO |
Posted: Wed Feb 13, 2008 5:10 pm Post subject: |
okay, so this is another stupid question.
But what EXACTLY are VOC's?
are they those chemicals that once you breathe in and you can never get out of your system? and are extremely volatile?.....
CAMPY, yeah, unfortunately I know for sure that my state (washington) requires HVLP guns, I live less than 20 miles direct from portland oregon (THE greenest city in the nation), so HVLP for me.
and I just realized, my furnace is in my garage as well, so I think that means no painting in my garage.... YES? no? _________________ money money money. |
Posted: Wed Feb 13, 2008 5:18 pm Post subject: |
Hi
Courtesy of the EPA
Organic Gases (Volatile Organic Compounds - VOCs)
Volatile organic compounds (VOCs) are emitted as gases from certain solids or liquids. VOCs include a variety of chemicals, some of which may have short- and long-term adverse health effects. Concentrations of many VOCs are consistently higher indoors (up to ten times higher) than outdoors. VOCs are emitted by a wide array of products numbering in the thousands. Examples include: paints and lacquers, paint strippers, cleaning supplies, pesticides, building materials and furnishings, office equipment such as copiers and printers, correction fluids and carbonless copy paper, graphics and craft materials including glues and adhesives, permanent markers, and photographic solutions.
Organic chemicals are widely used as ingredients in household products. Paints, varnishes, and wax all contain organic solvents, as do many cleaning, disinfecting, cosmetic, degreasing, and hobby products. Fuels are made up of organic chemicals. All of these products can release organic compounds while you are using them, and, to some degree, when they are stored.
EPA's Total Exposure Assessment Methodology (TEAM) studies found levels of about a dozen common organic pollutants to be 2 to 5 times higher inside homes than outside, regardless of whether the homes were located in rural or highly industrial areas. Additional TEAM studies indicate that while people are using products containing organic chemicals, they can expose themselves and others to very high pollutant levels, and elevated concentrations can persist in the air long after the activity is completed. _________________ Stop Dead Photo Links how to post photos
Ghia
Vanagon
Beetle
Posted: Wed Feb 13, 2008 5:30 pm Post subject: |
yeah, I probably could have handled that with a shot to Google.
since my furnace is a constant ignition source, do you thing a simple tarping off of the perimeter of the furnace area could make it safe? _________________ money money money. |
Posted: Wed Feb 13, 2008 5:51 pm Post subject: |
alright, well shit, unless I can rent a painting booth looks like I'm not painting it in the garage and more. A day that warm won't be around for a while and I need this bug outta my garage. _________________ money money money. |
Campy Samba Member
Posted: Wed Feb 13, 2008 6:11 pm Post subject: |
HVLP paint guns are required where I live at businesses such as auto body repair shops, which is why I had to use one when I rented a paint booth. I've used my Binks suction paint gun, elsewhere, because it works better. You can use a suction-type paint gun if you are just going to do the painting on your property.
I've done some painting in my garage; I shut off the gas to the water heater and, as I noted earlier, I moved my air compressor out of the garage.
I know of some people who have painted car bodies outside, when there was no breeze and insects and junk in the air. _________________ Don't worry; be happy. (Baba) |
Posted: Wed Feb 13, 2008 6:29 pm Post subject: |
well, I've been looking briefly for a place to rent a booth....I can't fing one on my area!
any help on that?! _________________ money money money. |
Campy Samba Member
Posted: Wed Feb 13, 2008 6:44 pm Post subject: |
I only found one business in Chico where I could rent a paint booth: $100 for the day, when available, and it included leaving my bus in it overnight. It had a side draft, a paint gun cleaner, and refrigerated dry air. It was well worth the expense.
Use your telephone and start calling auto body repair businesses. _________________ Don't worry; be happy. (Baba) |
Posted: Wed Feb 13, 2008 8:15 pm Post subject: |
I'm not frustrated, just under a time budget.
aaggh... _________________ money money money. |
Hophead Samba Member
Joined: January 03, 2005 Posts: 940 Location: Chico,Ca
Posted: Thu Feb 14, 2008 12:08 am Post subject: |
Another important thing to check on is the legality of painting a car in your locality. It might not be allowed outside of a booth. Call your environmental health/ air quality mgmt district and ask. Breaking environmental laws can cost thou$and$ if you get bu$ted.
Here in Butte county you can paint two vehicles a year on your property, no booth needed.
BUT..... you must be the registered owner of them. That keeps the side job guys from painting other peoples cars in their driveways. If your neighbors complain to them then you must cease painting.
The folks I talked to were really nice and helpful.
Getting a booth sounds better all the time. Doesn't it? _________________ 70' Beetle Pan off Resto
2110cc
82 X 90.5
P&P 043 40x35.5
9.6-1 comp
FK-8
48 IDA |
Major Woody Samba Enigma
Joined: December 04, 2002 Posts: 9010 Location: Portland, OR
Posted: Thu Feb 14, 2008 12:54 am Post subject: |
Washougal is podunk town. Nobody's gonna care about the smell from the paint, there's a huge paper mill nearby.
Get your paint and Industrial Finishes in Portland. Don't buy it online even if it's cheaper. Ask for "Omni" paint.
How about using craigslist? Find someone with a pole barn and rent that for a few days. Put up plastic to keep the spiders out of your paint.
As to the compressor and furnace, run a long extension cord and put the compressor in the house. Run the air line to the garage and that's one problem solved.
If the furnace has a standing pilot, shut it off. If it has electronic ignition, flip the breaker while you're painting and for an hour or so afterward. You can stand to have your house cold for a while. |
Posted: Thu Feb 14, 2008 4:35 pm Post subject: |
yep, finding a booth sounds good to me.
Well, "major woody", I know what parts you're thinking of in washougal if you're familiar with it. But I live as far east you that can go while living within city limits....as in as far away from the paper mill as you can get, plus, the mill is in the next town over, in camas. AANdd, I live in a housing developement, so yeah, getting a pole barn or a booth rented sounds like the right thing for me. Thanks for the place in Portland, I'll go check that out. _________________ money money money. |
