dillon schuh Samba Member
Joined: July 21, 2003 Posts: 343 Location: Sacramento
Posted: Tue Feb 12, 2008 8:40 pm Post subject: bad gas smell |
I drive a notch every day and it runs strong
But it seems to be not burning all the gas
My buddie always says that it smells horrible when he drives behind
I dont care about him but i dont want to be wasting gas i could use
What do i do
any ideas |
wolfman's brother Samba Member
Posted: Tue Feb 12, 2008 8:47 pm Post subject: |
what kind of carbs do you have?whatever they are make sure they are DIALED IN to as close to perfect as you can get,anything but solex and you may have to fine tune every couple of weeks depending on your driving style.give the car a good thorough tune up and see what it does for ya. _________________ insanity takes it's toll,please have exact change ready.
my imaginary friends keep telling me I have a mental problem. |
Anniehum Samba Member
Joined: November 23, 2003 Posts: 1197 Location: Kingston, Washington
replace all your fuel lines immediately, use fuel line hose clamps. Check your vent hose at the filler hole, make sure your tank isn't leaking. What are you getting for gas mileage?
Cheers _________________ Ho'oponopono |
Posted: Tue Feb 12, 2008 8:56 pm Post subject: |
i have solex carbs
i replaced the fuel lines 2 months ago
will higher grade gas effect it? |
COFBack Samba Member
Joined: July 05, 2005 Posts: 2148 Location: Colorado Springs
Posted: Wed Feb 13, 2008 7:43 am Post subject: |
When was the last time you:
Changed the plugs, cap, rotor, wires
Set the Timing
Adjusted the valves
Cleaned the carbs
Adjusted the Idle MIXTURE
Set the Idle SPEED _________________
iowegian wrote: |
Henceforth he shall be known as "Trameltoe".
Chickengeorge's wife wrote: |
bing chow ching fong fang T.J. fang ching dow fong |
