runamoc Samba Member
Joined: June 19, 2006 Posts: 5601 Location: 37.5N 77.1W
Posted: Mon Feb 18, 2008 6:34 am Post subject: Resolit Distributor |
How does a Resolit centrifugal distributor advance curve compare to Bosch centrifugal distributor curves like in the 009, 010, 050, 019? If you had one would you use it instead of a 009? |
blankmange Type 3 Darksider
Joined: July 17, 2004 Posts: 11498 Location: Bloßer Stahl-preapocalyptic MidCoast
Posted: Mon Feb 18, 2008 7:01 am Post subject: Re: Resolit Distributor |
runamoc wrote: |
I won an eBay auction for what I was led to believe was a Bosch 019 -- turned out it was a Resolit... as I understand it, they are Brazilian knock offs, but none of the Bosch parts fit the Resolit...
I sent it back for a refund... Bosch 019 for me... _________________ póg mo thóin
Certified DHS Technician
Samba Member # 24517 |
Bashr52 Samba Member
Joined: July 16, 2006 Posts: 5666 Location: On an island in VA
Posted: Mon Feb 18, 2008 8:38 pm Post subject: |
I had a dist on my baja when I bought it, marked Apex Resolute or Resolution. Worked well considering what it was. I took it aprat and it is constructed internally like an 010 or 019 with the weight and spring style. |
Glenn Mr. 010
Joined: December 25, 2001 Posts: 76937 Location: Sneaking up behind you
Posted: Tue Feb 19, 2008 3:57 am Post subject: |
They are old aftermarket copies. The quality is nowhere as good as the Bosch. If you get it for free then you got a nice wheel chock.
Personally I would find a Bosch. _________________ Glenn
Member #1009
#BlueSquare |
