Pogel Samba Member
Joined: November 21, 2005 Posts: 38 Location: Florida
Posted: Mon Feb 18, 2008 7:34 am Post subject: Backfiring |
My bus had an enormous backfire then stopped. If I restart when cold it starts up and turns over ok. Then in starts to stall, has a large backfire then stops. The spark plugs were black and I have cleaned them. I also changed the inline fuel filter, but it does the dame thing. The distibutor is new. It has dual solex brosol carbs which I think are 34s. The engine is 1641 on a 1500. |
65Busstop Samba Member
Joined: January 06, 2004 Posts: 312 Location: Akron Ohio
Posted: Mon Feb 18, 2008 8:00 am Post subject: |
Check timing? |
Da TOW'D Samba Member
Joined: December 25, 2005 Posts: 1321 Location: Bella Coma Canada
Posted: Mon Feb 18, 2008 8:22 am Post subject: |
Backfiring out muffler or carb ? _________________ '57 type 1 Blackberry
'58 SC Ruf
'62 type 3 Notch
'92 Eurovan Willy DD
and NUTS |
caseyjones Samba Member
Posted: Mon Feb 18, 2008 10:35 am Post subject: |
Maybe old gas being burned? |
Pogel Samba Member
Posted: Mon Feb 18, 2008 10:48 am Post subject: backfiring |
The muffler is smoking and then the flame can be seen coming out it when it backfires. Gas is not old. I always use Shell 93 octane. I've got to wait till a friend comes over Saturday to check the timing, compression etc. A couple of people have thought maybe the float in the carb is sticking. |
ekimikem Samba Member
Joined: May 16, 2004 Posts: 438 Location: Coeur d'Alene, Idaho
Posted: Mon Feb 18, 2008 11:30 am Post subject: |
Was it running fine before the first backfire incident? |
Utiledulci Samba Member
Joined: January 06, 2005 Posts: 85 Location: Marlboro OH
Posted: Mon Feb 18, 2008 11:31 am Post subject: |
Busstop hit it on the head...timing is the first thing to check. A timing lite is cheap enough to buy at Autozone, anyone with a vintage car should have one of these along with a good fire extiguisher. Next thing I would check are the carbs to make sure they are configured/jetted/tuned the same way. This will cause it to run rough too. _________________ 'nuff said |
Posted: Mon Feb 18, 2008 12:13 pm Post subject: |
I don't think the compression on a VW engine is high enough to run that high of octane. You might research that as I am not positive on it. If you have Muirs idiot guide it tells you how to make a static timing light for near nothing. |
60freak Samba Member
Joined: October 08, 2002 Posts: 861 Location: Indiana
Posted: Mon Feb 18, 2008 12:44 pm Post subject: |
Is the distributor "loose", sometimes the clamp/bracket can be loose that holds the distributor in place and the distributor will pop up and loose it's physical connection with the driveshaft and cause problems similar to this. If the distributor has been changed recently and now you are having troubles, that would be one of the first things I'd check out, 2nd being the carbs to inspect for plugged jets, incorrect/stuck float level, etc. Good Luck. |
SurfCityRacing Samba Member
Joined: September 12, 2007 Posts: 1286 Location: Santa Cruz, CA
Posted: Mon Feb 18, 2008 1:39 pm Post subject: |
As these guys said, double check the timing. Sometimes if the advance mechanism is fouled up, the timing will look good, but it won't be. Dynamic timing with a light is the only way to eyeball the advance.
Hope that helps. _________________ Riding with Surf City had me thinking "F'n Piercy" was your real name. |
Alaskan Adventurer Samba Member
Posted: Mon Feb 18, 2008 2:31 pm Post subject: |
does it have points or electronic ing? Mine was doing the same thing at BB last nov. I discovered the electrionic modular was loose under the dist. cap.. Also has it been sitting long? The carbs could be gummed up/ Pluged jets... Kevin _________________ 63 DC
60 SC daily driver |
Pogel Samba Member
Posted: Mon Feb 18, 2008 8:20 pm Post subject: backfiring |
I checked the distributor and it was not loose.
It has points.
I recently had to change a brake drum. When I jacked it up it tilted over at quite an angle (bus is drastically lowered). A friend said the oil could have sloshed over and into the heads. He thinks I should run the engine to burn off the oil. |
Posted: Mon Feb 18, 2008 8:48 pm Post subject: |
Ok, Maybe cracked dist cap or rotor? Jacking up the bus did not do it, _________________ 63 DC
BarryL Samba Member
Joined: November 01, 2004 Posts: 14269 Location: Casa de Oro, California
Posted: Tue Feb 19, 2008 8:36 am Post subject: |
Black plugs = way too rich. See if the choke is opening and make sure the float and all that fuel pump pressure stuff has been checked. |
bill may Samba Member
Joined: August 27, 2003 Posts: 14160 Location: san diego,ca
Posted: Wed Feb 20, 2008 3:18 am Post subject: Re: backfiring |
Pogel wrote: |
It has points.
at high rpms the drivers side valve cover can fill with oil... your ignition is retarded - firing too late. do you have an original distributor clamp? check your rotor-the wire between center and tip is resistor wire and could be going bad(it is under epoxy) what is condition of cap? which distributor is in it? do you use 87 octane fuel? _________________ Admin note: Bill Passed away - July, 2017
1965 panel bus-Kermit
"Camping is cheaper than therapy"
www.sv2s.com
www.steeringboxscrapers.net
SBS #100
http://www.thesamba.com/vw/forum/viewtopic.php?t=453617 |
Posted: Wed Feb 20, 2008 11:38 am Post subject: |
When the distributor was replaced, did you hook up the wire from the distributor to the negative/correct side of the coil? I remember years ago a friend who hooked up the distributor and ignition "hot" backwards on the coil and the vw ran for a short while before backfiring and running like crap and then eventually catching his wiring on fire in the engine compartment, it was a mess. Good Luck, hope you get it figured out. I'd look into the last things you messed with for the problem, distributor first and then onto the carbs. |
Pogel Samba Member
Posted: Fri Feb 22, 2008 7:29 am Post subject: Backfiring |
Ok I've checked a few things. It is a pointless dizzie. I hve it running and not backfiring when the timing is 10BTDC. If I back it to TDC or ATDC it backfires. It is 1641cc on an H block with no vacuum advance and the dual carbs, blue coil. Is BTDC correct? I have yet to road test it. |
BarryL Samba Member
Posted: Fri Feb 22, 2008 8:51 am Post subject: |
Post up the distributor number and Glenn might pipe up; he's the distributor guru. My guesses have been off lately but I'm thinking 7.5 to 10 degrees static before. |
slow36hp scott wimberley
Joined: August 09, 2004 Posts: 3113 Location: mukilteo washington
Culito 11010101
Joined: December 07, 2006 Posts: 5866 Location: Columbia Missourah
Posted: Fri Feb 22, 2008 6:02 pm Post subject: |
If it's a 009, you want to time at full advance. 30degrees, I think. _________________ Copyright CJ Industries, Inc.
'64 standard w/2.0L type 4
'62 bug
johnnypan wrote: |
...dont pay no attention to Culito,he's a cornhole.. |
